588,500 active members*
5,050 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 226 of 253 126176216224225226227228236
Results 4,501 to 4,520 of 5053
  1. #4501
    Jun 2006
    82
    Hi guys,
    Bit of shamless cross posting to try to get a few more replys on my thread as I am keen to cast a desktop mill column and base next week but would really like a few more eyes to my rock selection and machine design before committing to such a big pour!
    http://www.cnczone.com/forums/epoxy_..._-_please.html
    thanks a ton for having a look!
  2. #4502
    Oct 2010
    44
    Hello jestah.Make holes in the forms. Not only lighter but also gives structure and strength.For example, you can install pipes for cables at the base, tower and stand Spindle.This will make it more easily for casting concrete and save.For use steel pads, aluminum is soft.However, the machine is expected to operate for years.Success and good luck, because it is always necessary.Yancho
  3. #4503
    Jul 2011
    Hi jestah,
    your Z-motor looks a bit too small for my taste since I can't see a counter balance in your design either.
  4. #4504
    Jun 2006
    82
    Quote Originally Posted by yancho View Post
    I have added some small holes to run wiring as well as two post tensioning cables but cant help but think a solid block is going to be better for vibration damping than something with a cored centre.
    I have to buy 30L of resin so happy to cast two solid blocks as this will use most of it up in one hit, Can any one else confirm that I will have a better product (looking for vibration deadness and weight over trying to save some cost with using less material) by adding a core to this casting.
    Aluminium is soft BUT is cheaper for me to have machined post casting and most importantly has a far closer thermal expansion to the cast rock than steel. My fear with steel is that it will start pulling away from the casting over time due to it thermal expansion. Two people have said steel and a few have said aluminium, any one else have an opinion?
    Quote Originally Posted by stewi View Post
    Hi jestah,
    Each axis has a 960 oz/inch stepper motors that should be enough with a 5mm pitch ballscrew to raise and lower the 40kg or so for the z but they are being used as I have them for a wood router I was originally making. I am putting them on the mill to cut the parts to finish that at which point I plan to swap them onto that and upgrade this rig to servos.
    The counterbalance is a good idea, gas struts look popular but would a dead weight, a few pulleys and some wire work better?
  5. #4505
    Jul 2011
    Quote Originally Posted by jestah View Post
    It depends on the speed you want to go. If all motors and spindles are the same, than X and Y have much less to do against Z. Gas struts are only good until they leak. Pulleys should have as large of a diameter as possible. Look for an extra 40kg balance weight.
  6. #4506
    Nov 2007
    68
    Big Channel
    Quote Originally Posted by rowbare View Post
    It looks good Steven. Are those big channels on the front of the machine connected to the troughs on the top? if so, I would suggest running them left to right rather than front to rear. As they are, they would dump chips on the operator's feet...
    bob
    there's a tank for chips collection
  7. #4507
    Nov 2007
    68
    machine information
    It looks good Steven. Can you write more information about the machine-weight,size.
    Thanks ! Yancho.
    Weight:800Kg
  8. #4508
    Nov 2007
    68
    Quote Originally Posted by veteq View Post
    Is that full epoxy granite Steven..?
    Is that a machine for yourself as hobby or do you have a company that sells them.?
    It's full epxoy granite
    we have a company and sell them
  9. #4509
    Nov 2007
    68
    Quote Originally Posted by RomanLini View Post
    Nice work! Looks like you copied the gantry design from that nice German (Dutch?) machine we talked about earlier.
    I never copy anyone
    which German machine your talked about earlier?
  10. #4510
    Oct 2005
    2392
    Hi Steven.ji, sorry I was not accusing you of doing something wrong, but your gantry does look a lot like the German one by Thomas Zeitz, his machine is called FS2MG we talked about it in this EG thread, post #4059 around there.
    His build log;
    http://www.cncecke.de/forum/showthre...ght=andre+finn
    http://www.ktm-reiseenduro.de/tz/menue.htm
    To get to the photos of the FS2MG on his web page you navigate;
    (top menu) Maschinen -> (then left column) Neu im programm
    http://forums.anandtech.com/showthread.php?t=2022096
    Looks like he's got a new model there too (FS3MG);
    Anyway Steven.ji your machine looks very nice!
  11. #4511
    Jul 2011
    [QUOTE=
    The counterbalance is a good idea, gas struts look popular but would a dead weight, a few pulleys and some wire work better?[/QUOTE]
    If your spindle has a diameter of 15 mm, than the 5 mm pitch would convert the load of 40 kg to a torque of 0.0527 kgf*m or 73.18 ozf*inch. The ball screw has likely an efficiency of 60%, which cranks up the required motor torque to 121 ozf*inch.
    Even at low speed the motor only exerts the pull-in pull-out torque. When the full step is completed, we see something like the holding torque. Assuming we get only 30% of the holding torque, we are already at 406 ozf*inch. This is all without friction and at low speed of ~ 200 pulses or 1 rev per second. At 400 pulses per second, torque drops by another 30%. Go 600 pulses and the motor will only vibrate.
  12. #4512
    Oct 2010
    44
    Coefficients of Linear Expansion
    Look here the smaller number is less linear expansion.About your proposed steel.Success yancho
  13. #4513
    Nov 2007
    68
    Smallest machine base
    We produced a smallest machine base for engraving of 50Kg
  14. #4514
    Oct 2010
    44
    hello Steven.I wanted and working dimensions of the machine (what moves the axes). What use spindle?I have one more question-concrete for epoxy resin using a resin or unsaturated?Many thanks Yancho
  15. #4515
    Nov 2007
    68
    XYZ 400x400x150
    spindle diameter is less than 85mm
  16. #4516
    Nov 2007
    68
    epoxy resin
  17. #4517
    Oct 2010
    44
    Thanks Steven.Yancho
  18. #4518
    Jun 2006
    82
    Hi Yancho,
    Thanks for posting that data, I was going of the info in the index thread that states
    E/G and aluminum match well thermal expansion wise and good for embedment of 80/20 etc.<A href="http://www.cnczone.com/forums/showthread.php?p=246652?postnum=113"> Link to Post113</A>
    but as I can see from your data that steel is a better option. thanks for the heads up and guess I should get out to a steel yard asap
    thanks
    jestah
  19. #4519
    Oct 2010
    44
    Hello jestah.I also want to make such a machine-CNC.I have a master degree machine tools and 20 years of the conventional work.I think that concrete is best, because when the foundation for the rails and aligned them correctly, avoiding costly and heavy machining.Not so fast, consider it well, once the mold is made.Of course you can always improve it.Ask for me will be happy to help.I use Solidworks 2008/2011.Yancho
  20. #4520
    Jun 2006
    82
    Thank you so much for you help, to be honest I am only 25 and have no formal training. I have spent 3 years reading different posts on the zone and based my design around my finding and often feel unsure if I have a good design as I have never worked with metals before.
    a few post back the German machine looks like a far better solution as well as being easy for me to cast so I am now rethinking my ideas and considering building something very much like the first smaller blue machine.
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
