588,191 active members*
7,404 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 231 of 253 131181221229230231232233241
Results 4,601 to 4,620 of 5053
  1. #4601
    Mar 2010
    35
    When Milltronics started, I designed a cast polymer base for their small miller. I then designed bases for some of thier other bed mills. We also supplied an epoxy grout to allow them to attach the machine bed to the base quickly and accurately. After I sold my company the new owner overcharged and lost the business.
  2. #4602
    Oct 2005
    375
    Would a UHPC (ultra high performance concrete) be a good material for a hobby machine base?
    It is easy to use since there is no vibration neccesary.
    Ant idea`s on this?
    [ame=http://www.youtube.com/watch?v=ftopsaGUZzs]Production of UHPC-Elements (English) using Ultra High Performance Concrete - YouTube[/ame]
  3. #4603
    Aug 2009
    291
    Quote Originally Posted by veteq View Post
    Ant idea`s on this?
    [ame=http://www.youtube.com/watch?v=naRoDinbbdc&feature=related]Concrete countertops: Using superplasticizer to increase workability without decreasing strength - YouTube[/ame]
  4. #4604
    Jul 2003
    586
    where do you get thins stuff.I am in the USA
  5. #4605
    Oct 2005
    375
    But why dont we all use this stuff to build a machine, what are the pro`s and con`s? I found a website that stated that the mechanical performance is the same or better as EG. What would be the problem, creep, the water?
  6. #4606
    Jul 2006
    1256
    UHPC
    uhpc can cost 10 times more than regular concrete.I may cost as much as EG but may be easier to use I doubt this is a material you can get at Home Depot
    Larry
    http://www.dhs.gov/xlibrary/assets/u...ialization.pdf
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  7. #4607
    Jul 2003
    586
    i would not expect to find it a home cheapo but i can not find a source for the additive.
  8. #4608
    May 2007
    68
    Hi All
    Hi performance concrete.
    Clearly a great material for building thin shells and slender bridges.
    And (possibly) machine bases as the video shows? were the machine bases in the video destined to be part of high performance CNC machines or were they for a use where less accuracy is required? Maybe materials handling or bases for pumping or processing machinery? The video did not make this clear.
    Even ordinary concrete has always been strong enough to build machinery frames ; it is let down by susceptibility to expansion due to moisture, long term shrinkage and cracking and micro-cracking. Not a serious problem as it is known and the design engineer allows for it when building say a reinforced bridge; but totally unsuitable for a precision machine tool where micron accuracy is required.
    Before getting excited about high performance concrete technology I would like to see detailed specifications. It has to perform physically at least equally to Epoxy/Aggregate before it is worthy of consideration.
    Can any forum member post a link to a site that gives that detail?
    Cheers
    John
  9. #4609
    Jul 2006
    1256
    durcrete
    characteristics
    value
    density
    < 2.500 kg/m³
    ultimate pressure strength
    > 100 [MPa]
    ultimate tensile strength in bending(acc. to recipe)
    up to 25,00 [MPa]
    young´s modulus
    ≈ 45.000 [MPa]
    water absorption in weight
    1 - 2 [Mass %]
    fire behaviour
    class A1
  10. #4610
    May 2007
    68
    Hi Lgalla
    From your post:
    "water absorption in weight 1 - 2 [Mass %]"
    I can only assume it expands.
    It is a pity they do not quote a figure.
    Without an accurate number it is a No Go zone.
    Cheers
    John
  11. #4611
    Jul 2006
    1256
    more links
    more links
    Durcrete GmbH
  12. #4612
    Jul 2006
    1256
  13. #4613
    Jul 2006
    1256
    homag
  14. #4614
    May 2007
    68
    Hi All
    Having downloaded all the brochures. I was not able to get a number for the effect of one or two percent water absorption as mentioned in their specification. I did notice that they forbid the use of kiln dried aggregates in the mix?
    As most CNC machines use coolant this is not a small issue.
    Cheers
    John
  15. #4615
    Jan 2008
    25
    John, What about to cover it with few layers of epoxy based paint(or just epoxy). You'll get couple mm of protection layer.
  16. #4616
    May 2007
    68
    Hi Alex
    Yes that would work for a time, however any sort of membrane just sits there waiting to be broken; and what about all the bolt holes and cast is steel fittings? If a tiny crack forms around one or two the membrane defence line is broken.
    What is the first life (purchased from new) of a machine? maybe 10 years.... A long time for water to seep in even through a pinhole.
    We don't actually know if water does expand High performance concrete but if it does no thanks. Epoxy/aggregate will do fine.
    I do wish the makers would publish and confirm that it is not affected by water (and or Oil); or if it is by how much?
    Cheers
    John
  17. #4617
    Jan 2008
    25
    Hi All
    Here is my first part, fresh, from oven (1hour at ~80C)
    First made epoxy-granite part . - YouTube
    Mix
    .7l of 5-8mm
    .6l of 1mm
    .5l of 0.1mm
    it made 2 liters of mix.
    epoxy 20% by volume. (hardener is 1:10)
    The consistence of mix is quite dry. Snowball holds form perfectly.
    Hand drill mixer do the job very well.
    Vibration table almost do nothing(visually). Probably neet to dramaticaly increase a vibration level. And i think that mix should be moister to use vibration.
    We will se it in next part
    PS: sorry for my english. :tired:
  18. #4618
    Jan 2008
    25
    Now I'v found one more negative side of part - it air conductive. So, it will suck water oil and so on.
    So, definitely should be more epoxy.
  19. #4619
    Feb 2010
    23
    Hi Alex,
    Like you I am experimenting to find a good formulation and construction process for EG. I am no expert.
    From my experimentation I think you could improve your formulation by having more sizes in the aggregate. The smaller sizes is suppose to fill the crack inbetween the bigger ones. You have a big jump in size from 1mm to 5-8mm.
    Regarding the usefulness of vibration, I use the exact same vibration motor as you for my experimentation and find vibration an important part of construction to eliminate air bubbles and spread the EG evenly. My vibration table uses four springs to isolate the vibration plate. Maybe a lot of the vibration power from the enigne is lost in the tire you use. If it is not the vibration table, it certainly could be the visocity of the EG mix. What epoxy are you using?
    Best regards
    Jacob
  20. #4620
    Jan 2008
    25
    Hi Jacob,
    Thanks for comment. I'll try one more size(marble flour) in my next part (the column).
    About vibrator - its my mistake. At begin i'v set it to minimal vibration level and found int quite enough. But it's not. So i'v change the setup to 50% of maximum vibration on both sides of vibrator, connect it to triangle. Now i feel the changes
    We will see.
    Best regards,
    Alex
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
