588,501 active members*
5,370 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > unipolar motor microstepping
Page 24 of 25 1422232425
Results 461 to 480 of 496
  1. #461
    Dec 2008
    51
    Hi everybody
    How many need spend for on MK unipolar stepper motor driver?
    thanks you
    Merry Chirsmas and Happy New Year
    Best Regards
  2. #462
    Aug 2006
    2758
    Quote Originally Posted by nhatson.elec View Post
    Thanks Kreutz info. High quality stepper driver need 32bit MCU, or DSP . Use FOC like PMSM control
    I have alpha step of vexta ( close loop control) it run very smooth. It use HD643704 ( Hitachi MCU 32bit)
    I have been thinking about Vector Flux Control for a while, the only problem is that a high count ppr encoder would be necessary, and the stepper motor should be paired to the drive.
    Most of the people don't have access to an specific model motor, so it will require to have the motors in stock. The price for the drives will increase to be about 60% of the price of the industrial distributors until reaching a manufacturing volume that allows to drop it. Using encoder-less vector flux control will solve part of the problem, but requires a more complex firmware and the need to pair the motor with the drive stays.
    Best regards,
    Kreutz.
  3. #463
    Dec 2008
    51
    Quote Originally Posted by kreutz View Post
    Best regards,
    Kreutz.
    Thanks Kreutz
    Alpha step use sub coil is encoder,
    http://www.orientalmotor.com/images/.../AS-sensor.jpg
    i think it work like in this link
    http://www.webx.dk/oz2cpu/20m/encoder.htm
  4. #464
    Aug 2006
    2758
    Thanks Kreutz
    Using steppers as encoders is good for MPGs or low resolution encoders, but for this application it is required to have high resolution encoders.
    Best regards,
    Kreutz.
  5. #465
    Dec 2008
    51
    i was open alpha step stepper motor, it is 2 phase motor ( bipolar) . Feedback like small stepper motor, I was check in PCB, dont have opam in reciver shecmatic. >> it dont work like resolver
    But close loop is expensive system
  6. #466
    Aug 2006
    2758
    Merry Christmas!!!
  7. #467
    Aug 2006
    2758
    I am working on a new revision of the firmware it will be Rev01P+
    Thanks, Tivoidethuong for your help finding this bug. The bug manifests itself after stalling the motor (or E-Stop) while running at high speed. On restart (without resetting the translator) the motor will start in full step mode (no steps are lost independent of the micro-step mode), the sound is different and the micro-step smoothness is lost.
    The solution, found by Tivoi, is simple and I will implement it in the next revision after I do a few more tests.
  8. #468
    Jan 2007
    31
    Wink Is the collaboration possible?
    Hi kreutz I call it "round limit square".
    I live in Japan.
    Because I do not understand English, I use an interpreter.
    It does not translate a complicated sentence.
    Please write one phenomenon in Line 1.
    I got "a document of the microstepping" by "tn2313" from you before.
    However, it was too complicated and did not match my preference.
    I regarded a method to constitute a circuit with "few transistors" "MP4401" "http://akizukidenshi.com/catalog/items2.php?q=%22I-00419%22&s=score&p=1&r=1&page=" "sw-7p", "few parts" as "tn2313" newly.
    "The circuit technology" is the upper grade, but, as for me, "the program" is inferior.
    I offer "a connection diagram" and "a way of thinking", and can you make the "program?"
    I want to complete this plan by "collaboration".
    kyoji Nonnno
  9. #469
    Aug 2006
    2758
    Quote Originally Posted by apollonono View Post
    Hi Kreutz
    I live in Japan.
    I got "a document of the micro stepping" by "tn2313" from you before.
    kyoji Nonnno
    Hello;
    Just replace the four Mosfets in the M-K schematics by your MP4401. It will not be as powerful as the Mardus-Kreutz, because maximum current for the MP4401 is only 3 Amps per Mosfet.
    Regards,
    Kreutz.
  10. #470
    Aug 2006
    2758
    I sent the new Rev01P+ firmware to Tivoidehuong for testing, if his results are positive, I will start distribution of the firmware as usual (the Private Message way).
    Happy New Year!!
  11. #471
    Aug 2006
    2758
    Happy New Year!!
    Tested OK. The firmware Rev01P+ is now available upon request.
    Kreutz.
  12. #472
    Jan 2009
    Happy New Year !!!
    How get source, hex file and full document store REV01P+?
    Cost Kreutz-4 Rev3.02SMD (K-4) (bipolar or unipolar) ???
  13. #473
    Aug 2006
    2758
    Quote Originally Posted by fominia View Post
    Happy New Year !!!
    How get source, hex file and full document store ?
    Thank You!!
    PM me with your e-mail address in order to send you the files.
    K-4 PC interface boards (assembled and tested) are available for M-K boards. PM me for prices. All Bipolar K-4 Sets were sold.
    Best regards,
    Kreutz.
  14. #474
    Jan 2009
    K4 board - bipolar or unipolar drivers ?
  15. #475
    Dec 2008
    51
    K4 is interface and tranlator board, u can driver all unipolar and bipolar. Need extander power board
    Regards
  16. #476
    Aug 2006
    2758
    I will be out of town for a month (working ).
    Kreutz.
  17. #477
    Apr 2007
    21
    After a long time in thread, here's a preview of latest revision. Main changes include :
    * Power Stage and Translator in one PCB
    * Motor Supply, PC Vcc, PC Gnd, Step and Dir inputs via Terminals
    * Microstep Tables are printed on Silkscreen
    * Due to conflicts on many revisions, values on Silkscreen
    * TLV2772AIP (8-dip) changed to TLV2772AID (8-soic)
    I will send for manufacture after final inspection and correction.
    Best Regards,
    Ozan
  18. #478
    Nov 2004
    174
    Looking forward to it...let us know when available.
    Bob
  19. #479
    Jan 2007
    31
    About the current measurement.
    hello. kreutz
    Because I use an interpreter, as for my sentence, it is it for the words that are random if there is not the subject.
    There were "ON", "PASS", a state of "OFF", and, as for me, what could measure an electric current with a current sense resistor knew the electric current of the uni-Paula drive only for a period of "ON".
    I use a thought whether I cannot measure me about a period except it.
    One method that I thought of is a method to use "a diode" and the current mirror circuit of "the transistor" in the common of the coil.
    When I make current SW "ON" for an instant, two methods that I thought of can read a certain current sense resistor voltage by "A/D" conversion on "GND".
    I think about whether the calculation of the expected electric current of the period when is in condition not to be able to read it by my two methods is possible.
    The next is not English, but please watch an image.
    http://den-nekonoko.blog.so-net.ne.jp/2009-04-19
  20. #480
    Aug 2006
    2758
    Kreutz.
    Hello;
    After finishing the above mentioned job I took an extended vacation. My extended vacation became a new business venture in an unrelated field (diagnostic imaging medical equipment). I haven't had any free time to continue any active development on this one or any other hobby related project. I will continue to drop by from time to time and will continue to answer all PMs as the time allows.
    Thanks a lot for your support!!
    Kreutz.
