588,513 active members*
4,651 visitors online*
Page 24 of 29 142223242526
Results 461 to 480 of 563
  1. #461
    May 2006
    1469
    OEM code 301 is used to call a macro that has been set as trigger macro.
    The macropump/brain combination that you have used does not utilise the trigger macro.
    Your on-screen button should just call the M615 macro.
    Greg
  2. #462
    Feb 2011
    thanks I try it
    Al
  3. #463
    Aug 2008
    142
    Is there a keyboard shortcut to the auto tool zero button? I would like to map it to a controller..Thanks
  4. #464
    You can add a shortcut in Screen 4 in less than a minute.
  5. #465
    Aug 2008
    142
    How about 10 minutes for the new guy...Thanks Gerry as always!
  6. #466
    Jan 2011
    49
    hey, Ger when I use my auto zero plate the z axis comes down and touches off the plate once, it doesn't do the second touch. after the first touch the z rises and stops 1" above the material, why dosen't it do the second touch off?
    thanks'
  7. #467
    Are you using my Screenset? If so, probably noise is triggering the probe input before the second probe. Most who experience this add a capacitor to eliminate the noise.
  8. #468
    Jan 2011
    49
    no I'm useing the standard mach3 screen
  9. #469
    Jan 2011
    49
    you also sent me a script once and I seemed to have lost it, but when I tried useing it it gave me a notice that something to the affect that it was unable to read it? I am useing a peice of pcb 0.060 thick. Thanks'
  10. #470
    What script are you using?
  11. #471
    Jan 2011
    49
    Message( "Auto Zeroing..." )
    If IsSuchSignal (22) Then
    code "G31 Z-3 F20"
    While IsMoving()
    Wend
    Call SetDRO( 2, .060 )
    code "G1 Z1"
    End If
  12. #472
    why doesn't it do the second touch off?
    Because the script you're using only touches once. You need to edit the script to touch off twice.
  13. #473
    Jan 2011
    49
    I found that script at cockrum.net, being a newbie and always looking for more input, is it reallly necessary for the machine to touch off twice? and if so would you be able to send me the script I need?
    Thanks'
  14. #474
    Oct 2011
    218
    Subscribed
  15. #475
    Jun 2006
    82
    double touch
    Just skimmed over the past 40 pages looking for a auto touchoff that has a double touch... Did I miss it or has it not been posted?
    I had a quick attempt at making my own but no luck getting it to run.
    Could this double touch method also be put onto the homing macros for x y and z?
  16. #476
    Jan 2011
    49
    auto zeroing
    I used the script I found on cockrum.net and follwed the instructions and my machine only touches off once, but still works fine, I guess to make the machine touch off twice you have to edit the script to make it do that and I am not that savvy at editing script yet. Take your time and make sure to follow all the instructions.
  17. #477
    Dec 2004
    1137
    Why bother with a double touch?
    If you really want it though, try:
    Code:
    code "G31 Z-3 F20"
    While IsMoving()
    Wend
    code "G1 Z1"
    End If
    Message( "Double touch Zeroing..." )
    Rem **** Half the speed on the retouch
    code "G31 Z-3 F10"
    While IsMoving()
    Wend
    Rem **** The thickness of the touch plate is 0.06mm
    code "G1 Z1"
    End If
  18. #478
    Jan 2011
    49
    Thanks' I will save this so when I am done with my new and improved cnc machine I will use it.
    Thanks again
  19. #479
    Jan 2011
    49
    hello, I noticed that there is a setting in the script for 0.06mm I am useing standard units and not metric, How will this effect my machine?
    Thanks'
  20. #480
    Sep 2005
    371
    Quote Originally Posted by jzak3 View Post
    Thanks'
    Since Mach is only looking at units change them like this:
    (However, I doubt you'll be using a 0.002" thick plate).
    Maybe, this is really the amount to back off and retouch by.
    code "G31 Z-3 F20"
    While IsMoving()
    Wend
    Call SetDRO( 2, 0.002 )
    code "G1 Z1"
    End If
    code "G31 Z-3 F10"
    While IsMoving()
    Wend
    Rem **** The thickness of the touch plate is 0.002 in
    code "G1 Z1"
    End If
  1. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  2. Auto tool setter / touch plate ?
    By chrisnis in forum Machines running Mach Software
    Last Post: 04-06-2013, 12:24 AM
  3. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  4. Auto Tool Setter Button IH taylored !
    By Cruiser in forum Charter Oak Automation Support Forum
    Last Post: 08-06-2009, 03:25 PM
  5. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
