Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
A bit of an update on the things I've been working on for the mill.
An outlet box for the side of the head to plug in the probe, the dewalt spindle and a spare.
A new y home switch cover that will take the tubing I'm using as wire protection.
A cover for the rear y belt drive.
The new bigger terminal box with more room for expansion.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Thanks a lot.
Hoss
You are doing INCREDIBLE work Hoss.
Hammer on!
Thanks very much.
Hoss
Nice Work Hoss Man, You will have it back up and running real soon.
Joe
www.joescnc.com
joecnc2006 at yahoo
Thanks Joe.
Hoss
I remember a time not too long ago it seems. Where I thought, if this Hoss guy would start tinkering with 3D printing, we would all benefit the same way we do in machining. ?mmm ;-)
Yeah some people think 3D printers are only good for making whistles and other trinkets.
Hoss
Hoss, quick question on the spindle control via Mach3 through a C6/C11 board - did you replace/bypass the start/stop switch with a relay?
Hi Hoss
That 0704 of yours is incredible. It just keeps getting better, like fine wine.
Peace
CH
Well I think it was more the pot on the c6 being adjusted correctly.
Hoss
The new and improved terminal box is wired, lots more room for extras later.
The cover came with a big hole in it so I filled it with a custom insert.
Hoss
Thanks for upping the bar once again!! Now I really need to step up my game on my Hurco conversion!
Electrical box is amazing...very organized. Love the tubing idea.
Thanks, I wish the console was as tidy, maybe someday.
Hoss
The mill wiring is basically complete now.
Used the former terminal box to organize the wiring on the rear of the stand that connects to the pumps and valves, etc.
Made a newer switch box that goes under the tray at the front to give manual control of the things that are normally under relay control.
Used different switches so I could basically feel which is which without looking.
Left to right is power drawbar, oiling system pump momentary, coolant, spare and air blast momentary.
Now to connect it all to the console which will get a little reorganization too.
Hoss
