588,225 active members*
4,489 visitors online*
Thread: Hoss's G0704
Page 265 of 344 165215255263264265266267275315
Results 5,281 to 5,300 of 6871
  1. #5281
    Mar 2013
    124
    Hey Hoss, would you still take the G0704 in this price class?
    And for electronics, how are these new 3-in-1 setups from Keling? The competitors to the G540 but 60v/6a? Do you still prefer separate drivers?
  2. #5282
    Quote Originally Posted by Topdecking View Post
    Heck yeah, according to the catalog the g0758 is $895 with the stand optional, another $160, the website lists it as $895 with stand. wonder which is correct?
    If the catalog is correct then the G0704 is only another $140 with the stand factored in, no brainer if you ask me, the g0704 is a lot more mill.
    There are a few people here using the mx3660, if I started over I'd use at least one, maybe 2.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  3. #5283
    Mar 2013
    124
    Damn. I have a g540 sitting about since a while ago....
    Might have to resell that with it's 380oz motors.
  4. #5284
    Feb 2011
    110
    Hoss
    Did you ever build a spindle lock for the G0704. I know you don't need it now. But I could use one. And have you seen this one
    T26361 Priest Tools Spindle Brake Basic for G0704 Grizzly.com
    G0704, Craftsman 101.07403.4x6
  5. #5285
    Quote Originally Posted by kd4gij View Post
    Hoss
    I made a spanner wrench back when I still needed to tighten the drawbar by hand.
    Projects
    Yes I've seen that bracket from grizzly, pretty expensive for something that just clutters the spindle IMO, their spanner alone is good enough.
    Hoss
  6. #5286
    Feb 2011
    110
    I wasn't going to pay that price. LMS has that for half the price still to much, just looking for Ideas to build somthing for mine. My spindle isn't drilled for a wrench like the newer ones. Heck I still need to do the 3 bolt mod on mine.
  7. #5287
    You must have had it a while, they've been shipping with the hole in the side of the spindle to fit their spanner for a year or so. I had to drill my own, it's not hard to do, just be careful to only go about 3/16 deep to avoid breaking thru.
    Hoss
  8. #5288
    Feb 2011
    110
    Yes I got mine before you started the cnc conv. on yours. Your first review of the G0704 is what promted me to order it.
  9. #5289
    Nov 2012
    220
    Hoss do you think a 15 tooth pulley is big enough for me to use on the y-axis of my BF20? That would give me 7 teeth engaged per pulley with a .375 wide belt. I was staring at the pulley the other day thinking it looked a little small...
  10. #5290
    It should be fine as long as the tension is good, I used 24 tooth pulleys on mine though.
    Hoss
  11. #5291
    Jul 2008
    340
    Hoss, I'm interested in converting my HF 9x20 headstock to use a 5C collet spindle. I haven't decided if I will use the headstock as a 4th axis for my CNC'ed X3 or convert the HF 9x20 to CNC. I definitely like the idea of using either approach with the 5C collet and mounting a 5C three or four jaw chuck if needed.
    I saw your videos where you converted a 7x12 lathe headstock to use a spindle from a 5C spin index. I was thinking of using the same approach. Do you remember the dimensions of the 5C spin index spindle? I don't seem to be able to find any information on the dimensions on the net.
    Do you have any plans available for your 7x12 headstock conversion? When selecting a spin indexer for donor parts, is there any considerations I need to keep in mind?
    -Freeman
    Sent from my Xoom using Tapatalk
    CRP-4848 CNC Router, CNC G0463 (Sieg X3) Mill, 9"x20" HF CNC Lathe (current project)
  12. #5292
    Quote Originally Posted by Analias View Post
    -Freeman
    My spin indexer OD was 45mm which is probably typical but you should get one first to measure for your bearings.
    You may be able to get bearings with an OD that might fit your 9x head without boring it like I had to for the 7x, 85mm iirc.
    Keep in mind I cut threads on the end of the spin indexer spindle for nuts to keep it together.
    Don't have plans for it as all I basically did was bore the head for the bearings.
    Don't spend a lot, I used a Shars indexer as most of it goes to waste.
    Hoss
  13. #5293
    Jul 2008
    340
    Thanks for the information. The dimension I'm most concerned with is the length measured from the back of the face of the spindle head to the end of the spindle. That would tell me if it's long enough to pass through the headstock and how much clearance I would have to secure the spindle. It would also tell me if I need to purchase a 7x12 headstock from LMS and restrict my plans to the 4th axis only. Would you know what this dimension is?
    -Freeman
  14. #5294
    I'll go check at halftime.
    Hoss
  15. #5295
    Feb 2011
    110
    Hoss
    Here is the spindal lock I made today. I know you don't need one but some one not going cnc might like the Idea. It is held on by 3 m6 setscrews and can be removed if it is in the way. Works good and beats holding the spindle with pliers.
  16. #5296
    -Freeman
    It's about 7.125 from the flange to the end.
    Hoss
  17. #5297
    Hoss
    Looks good, like that much better than the thing from grizzly/lms.
    Hoss
  18. #5298
    Nov 2013
    143
    I really like this as well. I guess I'm going to have to put that 6" long 4" dia. block of aluminum that's been sitting on my work bench for three months to good use. Good excuse for another project!
  19. #5299
    Oct 2008
    19
    I think I ordered the wrong ball nuts when I got my C7 ballscrews from Chai on Ebay.
    Mine look like this:
    Attachment 217500
    Do I need different ones?
    How do I repack these with larger balls?
    -Tom
  20. #5300
    Aug 2010
    630
    Quote Originally Posted by tomk358 View Post
    Attachment 217500
    -Tom
    I think those are right.. The only thing I see different is they have a extra hole in them in the middle.. Not sure what that's for.. Looks like they even ground one of them for you which is good.. As long as they didn't get it hot enough to melt the plastic insert used to recirculate the balls.
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
