603,976 active members*
3,083 visitors online*
Page 27 of 29 172526272829
Results 521 to 540 of 574
  1. #521
    24260
    Re: Huanyang VFD Macro/ Plugin
    Quote Originally Posted by OlfCNC View Post
    Do you think that this cheap chinese spindle has the same features as a spindle in a Fanuc machine? I don't think so.
    No of course not, but it was a suggestion of a possible work around, to simulate the feature!
    Al.
    Albert E.
  2. #522
    Apr 2014
    215
    It may be possible to use the plasma THC function with M3 to wait for an arcok signal to be given which means that when you issued an M3 the spindle will spin up, and if it exceeds the target speed - a hysteresis value the arc ok is given and motion begins.
    If the spindle speed drops below the target speed - the hysteresis value (spindle is stalling) motion can stop as a plasma arc fail signal.
    I know this is controversial but you should not be running and stopping a spindle via modbus.... It should be hardwired because if modbus is lost how will you stop the spindle.
    Modbus could be lost because the pc locks up, cable or hardware failure..... You then hit the estop and nothing will happen to the spindle.
    Use modbus to set and monitor values.... But slow for a hard interface interlock too (charge pump relay?). When bad things happen something spinning at 24000 rpm needs stopping in a controlled way as quick as possible imho ymmv.
  3. #523
    35494
    Best way to do that is just send a stop command to the VFD.
  4. #524
    Apr 2014
    215
    Could be difficult is you are relying on modbus for run, stop and spindle speed to be sent as data messages and have no other interlock with the vfd.
    No? Have I missed something?
  5. #525
    35494
    No, I was quickly scanning through the post and replied out of context I guess.
    I'm doing what you suggest, using a relay for Start/Stop, and the plugin for RPM only.
    The circuit with the relay should probably be in the Estop circuit, too.
  6. #526
    May 2018
    17
    I’m running screenset and at present I still can’t make this work. I ordered a new vfd thinking that might be the problem but still the same. I installed spindle talker and it shows it’s talking, but no return reply. What am I doing wrong?
  7. #527
    35494
    Do you mean the 2017 Screenset? If so, you need to edit the screen and change the RPM field number from 870 to 2451.
    Can you post your profile?
    What version of UCCNC, and what version of the plugin?
    What RS-485 adapter are you using?
  8. #528
    May 2018
    17
    ver 1.2049. Its set to 2451.everything seems to be functioning correctly in screenset. diagnostic shows the spindle is on, you can vary the rpm with the slider. but the vfd doesn't seem to be getting a signal, its just sitting there flashing
  9. #529
    May 2018
    17
    plugin is hy12
  10. #530
    May 2018
    17
    plugin is hy12
  11. #531
    May 2018
    17
    [Screensetsettings]
    mainscreenfilename=2017
    splashscreen=0
    [axessettingscontrolX]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=2
    Steppinnegate=False
    Dirpinnumber=3
    Dirportnumber=1
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=11
    Limitminuspinnegate=True
    Limitpluspinnumber=11
    Limitpluspinnegate=True
    Homepinnumber=0
    Homepinnegate=False
    Homedirectionpositive=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=100
    Homingspeeddown=250
    Stepsperunit=680.73519400953
    Velocity=2000
    Acceleration=200
    Softlimitpositive=0
    Softlimitnegative=0
    Backlashenable=False
    Backlashdistance=0
    Slaveaxis=None
    Homeportnumber=0
    Limitminusportnumber=1
    Limitplusportnumber=1
    Compaccel=240
    [axessettingscontrolY]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=4
    Steppinnegate=True
    Dirpinnumber=5
    Dirportnumber=1
    Dirpinnegate=True
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=10
    Limitpluspinnumber=10
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=100
    Homingspeeddown=250
    Stepsperunit=679.11714770798
    Velocity=2000
    Acceleration=200
    Softlimitpositive=0
    Softlimitnegative=0
    Backlashdistance=0
    Slaveaxis=A
    Homeportnumber=0
    Compaccel=240
    [axessettingscontrolZ]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=6
    Steppinnegate=False
    Dirpinnumber=7
    Dirportnumber=1
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=12
    Limitpluspinnumber=12
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=50
    Homingspeedup=100
    Homingspeeddown=250
    Stepsperunit=4040.40404040404
    Velocity=352.6875
    Acceleration=200
    Softlimitpositive=0
    Softlimitnegative=0
    Backlashdistance=0
    Slaveaxis=None
    Homeportnumber=0
    Compaccel=240
    [axessettingscontrolA]
    Axisenabled=True
    Stepportnumber=1
    Steppinnumber=8
    Steppinnegate=False
    Dirpinnumber=9
    Dirportnumber=1
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Limitminuspinnumber=0
    Limitminuspinnegate=False
    Limitpluspinnumber=0
    Limitpluspinnegate=False
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=100
    Homingspeeddown=250
    Velocity=2000
    Acceleration=200
    Softlimitpositive=0
    Softlimitnegative=0
    Backlashdistance=0
    Homeportnumber=0
    Limitminusportnumber=0
    Limitplusportnumber=0
    Compaccel=240
    [axessettingscontrolB]
    Axisenabled=False
    Stepportnumber=0
    Steppinnumber=0
    Steppinnegate=False
    Dirpinnumber=0
    Dirportnumber=0
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=500
    Homingspeeddown=250
    Stepsperunit=200
    Velocity=2000
    Acceleration=200
    Softlimitpositive=0
    Softlimitnegative=0
    Backlashdistance=0
    Homeportnumber=0
    Compaccel=240
    [axessettingscontrolC]
    Axisenabled=False
    Steppinnumber=0
    Stepportnumber=0
    Steppinnegate=False
    Dirpinnumber=0
    Dirportnumber=0
    Dirpinnegate=False
    Enapinnumber=0
    Enaportnumber=0
    Enapinnegate=False
    Homepinnumber=0
    Homepinnegate=False
    Homeautozero=True
    Homingvalue=0
    Homingspeedup=500
    Homingspeeddown=250
    Stepsperunit=200
    Velocity=2000
    Acceleration=200
    Softlimitpositive=0
    Softlimitnegative=0
    Backlashdistance=0
    Homeportnumber=0
    Compaccel=240
    [Spindlesetupsettings]
    IsSpindleinPWMMode=True
    SpindlePWMoutpin=0
    SpindlePWMoutpinnegate=False
    SpindlePWMdirpin=0
    SpindlePWMdirpinnegate=False
    SpindlePWMfrequency=200
    SpindlePWMminpercent=0
    SpindlePWMmaxpercent=100
    Spindlesteppin=0
    Spindlesteppinnegate=False
    Spindledirpin=0
    Spindledirpinnegate=False
    Spindlestepsperunit=500
    Spindleacceleration=200
    Spindleminvelocity=6000
    Spindlemaxvelocity=24000
    Spindlerelaysenabled=True
    M3relaypin=0
    M3relaypinnegate=False
    M4relaypin=0
    M4relaypinnegate=False
    M3ondelay=3000
    M3offdelay=10000
    M4ondelay=1000
    M4offdelay=3000
    Floodmistrelaysenabled=False
    M7relaypin=0
    M7relaypinnegate=False
    M8relaypin=0
    M8relaypinnegate=False
    M7ondelay=1000
    M8ondelay=1000
    M9delay=0
    SpindlePWMoutport=0
    SpindlePWMdirport=0
    Spindlestepport=0
    Spindledirport=0
    M3relayport=0
    M4relayport=0
    M7relayport=0
    M8relayport=0
    EncoderApin=0
    EncoderAport=0
    EncoderBpin=0
    EncoderBport=0
    Encoderreversedirection=False
    EncoderPPR=400
    Pulleyratio1=1
    Pulleyminvel1=1
    Pulleymaxvel1=1
    Pulleyinuse=1
    Pulleyratio2=1
    Pulleyminvel2=1
    Pulleymaxvel2=1
    Pulleyratio3=1
    Pulleyminvel3=1
    Pulleymaxvel3=1
    Pulleyratio4=1
    Pulleyminvel4=1
    Pulleymaxvel4=1
    Pulleyratio5=1
    Pulleyminvel5=1
    Pulleymaxvel5=1
    Pulleyratio6=1
    Pulleyminvel6=1
    Pulleymaxvel6=1
    Pulleyratio7=1
    Pulleyminvel7=1
    Pulleymaxvel7=1
    Pulleyratio8=1
    Pulleyminvel8=1
    Pulleymaxvel8=1
    Pulleyratio9=1
    Pulleyminvel9=1
    Pulleymaxvel9=1
    Pulleyratio10=1
    Pulleyminvel10=1
    Pulleymaxvel10=1
    Pulleyratio11=1
    Pulleyminvel11=1
    Pulleymaxvel11=1
    Pulleyratio12=1
    Pulleyminvel12=1
    Pulleymaxvel12=1
    Pulleyratio13=1
    Pulleyminvel13=1
    Pulleymaxvel13=1
    Pulleyratio14=1
    Pulleyminvel14=1
    Pulleymaxvel14=1
    Pulleyratio15=1
    Pulleyminvel15=1
    Pulleymaxvel15=1
    Usepulleys=False
    [Generalsettings]
    Constantvelocitymode=True
    Stopatangle=89
    Lookaheadlines=300
    Softlimitsenable=False
    Homesequence1=Z
    Homesequence2=X
    Homesequence3=Y
    Homesequence4=None
    Homesequence5=None
    Homesequence6=None
    Linearerror=0.03
    Cornerserror=0.03
    USBbuffersize=0.1
    POSDROsdigits=4
    Doontoolchange=0
    MaxLinearaddlenght=1
    MaxLinearunificationlenght=2
    Kernelfreq=0
    SafeZ=25
    G73_backoff=0.4
    Maximisescreenonstartup=True
    Dwellinseconds=False
    Runmodewhenunknowngcode=1
    Softlimitsgcodeprecheck=False
    Precompilemacrosonstartup=False
    Arcradiustolerance=0.1
    ResetG68onfileload=False
    ResetG51onfileload=False
    [IOsetupsettings]
    Estoppinnumber=15
    Estoppinnegate=False
    Probepinnumber=0
    Probepinnegate=False
    Chargepumppinnumber=0
    Chargepumppinnegate=False
    Chargepumplasermodeon=False
    Chargepumpalwayson=False
    CurrentHiLopinnumber=0
    CurrentHiLopinnegate=False
    Indexpinnumber=0
    Indexprescaler=1
    THCenable=False
    THConpin=0
    THConpinnegate=False
    THCuppin=0
    THCuppinnegate=False
    THCdownpin=0
    THCdownpinnegate=False
    THCmin=0
    THCmax=10
    THCfeed=1000
    THCalwayson=False
    THCondelay=0
    Estopportnumber=1
    Chargepumpportnumber=0
    CurrentHiLoportnumber=0
    Indexportnumber=0
    Probeportnumber=0
    THConport=0
    THCupport=0
    THCdownport=0
    MPG1pinA=0
    MPG1pinB=0
    MPG1portA=0
    MPG1portB=0
    MPG1prescaler=1
    MPG1filter=10
    MPG1speedmultiplier=10
    FROchannel=0
    SROchannel=0
    JROchannel=0
    FROminpercent=0
    FROmaxpercent=0
    SROminpercent=0
    SROmaxpercent=0
    JROminpercent=0
    JROmaxpercent=0
    SPPWMchannel=0
    Ana1invarnum=0
    Ana2invarnum=0
    Ana1outvarnum=0
    Ana2outvarnum=0
    MPG1attachtoJRO=False
    Laseroutputpinnumber=0
    Laseroutputportnumber=0
    Laseroutputpinnegate=False
    THCantidiveenable=False
    THCantidivepercent=0
    Plasmapierceheight=0
    Chargepump2pinnumber=0
    Chargepump2portnumber=0
    Chargepump2pinnegate=False
    Probepin2number=0
    Probeport2number=0
    Probepin2negate=False
    THCdelayenable=False
    THCenableoutpin=0
    THCenableoutport=0
    THCenableoutpinnegate=False
    THCantidiveoutpin=0
    THCantidiveoutport=0
    THCantidiveoutpinnegate=False
    THCantidownoutpin=0
    THCantidownoutport=0
    THCantidownoutpinnegate=False
    THCantidownenable=False
    Ana3invarnum=0
    Ana4invarnum=0
    Ana3outvarnum=0
    Ana4outvarnum=0
    [Appearancesetupsettings]
    2DTLCmarker=True
    Viewerundonepathcolor=3381759
    Viewerdonepathcolor=-5374161
    Viewerrapidpathcolor=16711680
    ViewerTCPmarkercolor=16776960
    ViewerBackgroundcolor=0
    Viewerboundariescolor=16777215
    GVgcodecolors=16777215
    GVmcodecolors=-233
    GVscodecolors=-32513
    GVfcodecolors=-21931
    GVbackgroundcolor=-12698050
    GVactualcodecolor=-16777216
    GVactualcodemidlinescolor=-16777216
    GVnotinterpretedcodecolor=16711680
    GVaxiswordcolor=-8323328
    GVcoordinatecolor=-9250052
    TCPcone=True
    TCPcross=False
    RotateTCPwithplaneselection=True
    Showzeromark=True
    Zeromarkcolor=-16711681
    DROwarningcolor=-65536
    rotationpointmarkcolor=-65536
    Showrotationmark=True
    Showtoolpathboundaries=True
    Highlightcolor=-1
    Showmessageonsoftlimits=True
    ValidateTextfieldsonEnteronly=True
    Disablejogpanelautopopup=False
    ShowtoolpathZzeroplate=False
    ZplateXextents=100
    ZplateYextents=100
    ZplateZposition=0
    ZplateZpositiononbottom=False
    ZplatePlateOpacity=25
    ZplateColor=-65536
    ZplateXgrid=10
    ZplateYgrid=10
    ZplateGridOpacity=25
    ZplateGridColor=-1
    ZplateShowSoftlimits=False
    ZplateSoftlimitsColor=-16711936
    ZplateSoftlimitsOpacity=100
    [Tooltablevalues]
    TooloffsetZ0=0
    TooloffsetZ1=0
    TooloffsetZ2=0
    TooloffsetZ3=0
    TooloffsetZ4=0
    TooloffsetZ5=0
    TooloffsetZ6=0
    TooloffsetZ7=0
    TooloffsetZ8=0
    TooloffsetZ9=0
    TooloffsetZ10=0
    TooloffsetZ11=0
    TooloffsetZ12=0
    TooloffsetZ13=0
    TooloffsetZ14=0
    TooloffsetZ15=0
    TooloffsetZ16=0
    TooloffsetZ17=0
    TooloffsetZ18=0
    TooloffsetZ19=0
    TooloffsetZ20=0
    TooloffsetZ21=0
    TooloffsetZ22=0
    TooloffsetZ23=0
    TooloffsetZ24=0
    TooloffsetZ25=0
    TooloffsetZ26=0
    TooloffsetZ27=0
    TooloffsetZ28=0
    TooloffsetZ29=0
    TooloffsetZ30=0
    TooloffsetZ31=0
    TooloffsetZ32=0
    TooloffsetZ33=0
    TooloffsetZ34=0
    TooloffsetZ35=0
    TooloffsetZ36=0
    TooloffsetZ37=0
    TooloffsetZ38=0
    TooloffsetZ39=0
    TooloffsetZ40=0
    TooloffsetZ41=0
    TooloffsetZ42=0
    TooloffsetZ43=0
    TooloffsetZ44=0
    TooloffsetZ45=0
    TooloffsetZ46=0
    TooloffsetZ47=0
    TooloffsetZ48=0
    TooloffsetZ49=0
    TooloffsetZ50=0
    TooloffsetZ51=0
    TooloffsetZ52=0
    TooloffsetZ53=0
    TooloffsetZ54=0
    TooloffsetZ55=0
    TooloffsetZ56=0
    TooloffsetZ57=0
    TooloffsetZ58=0
    TooloffsetZ59=0
    TooloffsetZ60=0
    TooloffsetZ61=0
    TooloffsetZ62=0
    TooloffsetZ63=0
    TooloffsetZ64=0
    TooloffsetZ65=0
    TooloffsetZ66=0
    TooloffsetZ67=0
    TooloffsetZ68=0
    TooloffsetZ69=0
    TooloffsetZ70=0
    TooloffsetZ71=0
    TooloffsetZ72=0
    TooloffsetZ73=0
    TooloffsetZ74=0
    TooloffsetZ75=0
    TooloffsetZ76=0
    TooloffsetZ77=0
    TooloffsetZ78=0
    TooloffsetZ79=0
    TooloffsetZ80=0
    TooloffsetZ81=0
    TooloffsetZ82=0
    TooloffsetZ83=0
    TooloffsetZ84=0
    TooloffsetZ85=0
    TooloffsetZ86=0
    TooloffsetZ87=0
    TooloffsetZ88=0
    TooloffsetZ89=0
    TooloffsetZ90=0
    TooloffsetZ91=0
    TooloffsetZ92=0
    TooloffsetZ93=0
    TooloffsetZ94=0
    TooloffsetZ95=0
    TooloffsetZ96=0
    [Workoffset_G54]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=50
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G55]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G56]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G57]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G58]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Workoffset_G59]
    WorkoffsetX=0
    WorkoffsetY=0
    WorkoffsetZ=0
    WorkoffsetA=0
    WorkoffsetB=0
    WorkoffsetC=0
    [Machinecoords]
    MachinecoordsX=18.190627
    MachinecoordsY=-9.13539
    MachinecoordsZ=50
    MachinecoordsA=0
    MachinecoordsB=0
    MachinecoordsC=0
    [Tooloffsetcoords]
    TooloffsetZ=0
    [Systemmessages]
    Message0=Valid license key was not found! Application will run in demo mode!
    Message1=Firmware update done!
    Message2=No UC100 connection was found! Application will run in demo mode!
    Message3=Firmware update in progress! Please wait and do not close the application...
    Message4=The application lost the connection with the motion controller device. [nl] Check the connection. The application is closing now! [nl] Save offsets?
    Message5=A machine axis position software limit was reached. The axis was now stopped.
    Message6=The reset logic of the software is active! [nl] Remove the reset condition with pressing the blinking reset button on the screen. [nl] If the reset condition cannot be removed can be due to an external e-stop button is pressed in or a limit switch on the machine tool is active. [nl] Please check the Diagnostics page for the input signals condition.
    Message7=The current job workspace is out of the set software limits.[nl] Adjust the softlimits to fit the job extents or disable the softlimits.
    Message8=The axis is disabled. To calibrate this axis enable the axis first.
    Message9=An internal error occured. The application is closing now.
    Message10=Enter a valid distance in absolute value!
    Message11=The calculated steps per value was saved.
    Message12=Please enter valid data.
    Message13=Active fixture:
    Message14=Are you sure you want to close?
    Message15=
    Message16=
    Message17=
    Message18=
    Message19=
    Message20=
    Message21=
    Message22=
    Message23=
    Message24=
    Message25=
    Message26=
    Message27=The Default profile cannot be deleted!
    Message28=File error.Could not delete the profile's macro library!
    Message29=Do you really want to delete the profile :
    Message30=File error.Could not copy default macros to profile!
    Message31=was loaded!
    Message32=The axis calibration makes a measurement to calibrate the steps per units resolution value for the machine axis. To abort and close this window press the cancel button.
    Message33=Mark the current position of the machine axis. Set the distance and the feedrate on this page and press the OK button to make a movement.
    Message34=Measure the travel distance on the machine axis from the previously marked point to the current point. Type the measured value to the field below and press OK.
    Message35=The new steps per value was calculated and written to the below field. To save the new value press OK. The process is then finished.
    Message36=Switch spindle on first
    Message37=Move Z-axis first to safeZ height:
    Message38=Make movement with safeZ to:
    Message39=Start position(Units):
    Message40=Actual steps per Unit:
    Message41=Distance to move(Units):
    Message42=Feed rate(Units/min):
    Message43=Distance measured(Units):
    Message44=Steps per Units calculated value:
    Message45=The software limits is lower than the safeZ height. Execute the command anyways?
    Message46=was created!
    [Hotkeysettings]
    Keycode1=39
    Buttoncode1=147
    Keycode2=37
    Buttoncode2=148
    Keycode3=38
    Buttoncode3=149
    Keycode4=40
    Buttoncode4=150
    Keycode5=33
    Buttoncode5=151
    Keycode6=34
    Buttoncode6=152
    Keycode7=45
    Buttoncode7=153
    Keycode8=46
    Buttoncode8=154
    Keycode9=81
    Buttoncode9=155
    Keycode10=65
    Buttoncode10=156
    Keycode11=87
    Buttoncode11=157
    Keycode12=83
    Buttoncode12=158
    Keycode13=27
    Buttoncode13=130
    Keycode14=0
    Buttoncode14=0
    Keycode15=0
    Buttoncode15=0
    Keycode16=0
    Buttoncode16=0
    Keycode17=0
    Buttoncode17=0
    Keycode18=0
    Buttoncode18=0
    Keycode19=0
    Buttoncode19=0
    Keycode20=0
    Buttoncode20=0
    Keycode21=0
    Buttoncode21=0
    Keycode22=0
    Buttoncode22=0
    Keycode23=0
    Buttoncode23=0
    Keycode24=0
    Buttoncode24=0
    Keycode25=0
    Buttoncode25=0
    Keycode26=0
    Buttoncode26=0
    Keycode27=0
    Buttoncode27=0
    Keycode28=0
    Buttoncode28=0
    Keycode29=0
    Buttoncode29=0
    Keycode30=0
    Buttoncode30=0
    Keycode31=0
    Buttoncode31=0
    Keycode32=0
    Buttoncode32=0
    Keycode33=0
    Buttoncode33=0
    Keycode34=0
    Buttoncode34=0
    Keycode35=0
    Buttoncode35=0
    Keycode36=0
    Buttoncode36=0
    Keycode37=0
    Buttoncode37=0
    Keycode38=0
    Buttoncode38=0
    Keycode39=0
    Buttoncode39=0
    Keycode40=0
    Buttoncode40=0
    Keycode41=0
    Buttoncode41=0
    Keycode42=0
    Buttoncode42=0
    Keycode43=0
    Buttoncode43=0
    Keycode44=0
    Buttoncode44=0
    Keycode45=0
    Buttoncode45=0
    Keycode46=0
    Buttoncode46=0
    Keycode47=0
    Buttoncode47=0
    Keycode48=0
    Buttoncode48=0
    Keycode49=0
    Buttoncode49=0
    Keycode50=0
    Buttoncode50=0
    Keycode51=0
    Buttoncode51=0
    Keycode52=0
    Buttoncode52=0
    Keycode53=0
    Buttoncode53=0
    Keycode54=0
    Buttoncode54=0
    Keycode55=0
    Buttoncode55=0
    Keycode56=0
    Buttoncode56=0
    Keycode57=0
    Buttoncode57=0
    Keycode58=0
    Buttoncode58=0
    Keycode59=0
    Buttoncode59=0
    Keycode60=0
    Buttoncode60=0
    Keycode61=0
    Buttoncode61=0
    Keycode62=0
    Buttoncode62=0
    Keycode63=0
    Buttoncode63=0
    Keycode64=0
    Buttoncode64=0
    Keycode65=0
    Buttoncode65=0
    Keycode66=0
    Buttoncode66=0
    Keycode67=0
    Buttoncode67=0
    Keycode68=0
    Buttoncode68=0
    Keycode69=0
    Buttoncode69=0
    Keycode70=0
    Buttoncode70=0
    Keycode71=0
    Buttoncode71=0
    Keycode72=0
    Buttoncode72=0
    Keycode73=0
    Buttoncode73=0
    Keycode74=0
    Buttoncode74=0
    Keycode75=0
    Buttoncode75=0
    Keycode76=0
    Buttoncode76=0
    Keycode77=0
    Buttoncode77=0
    Keycode78=0
    Buttoncode78=0
    Keycode79=0
    Buttoncode79=0
    Keycode80=0
    Buttoncode80=0
    Keycode81=0
    Buttoncode81=0
    Keycode82=0
    Buttoncode82=0
    Keycode83=0
    Buttoncode83=0
    Keycode84=0
    Buttoncode84=0
    Keycode85=0
    Buttoncode85=0
    Keycode86=0
    Buttoncode86=0
    Keycode87=0
    Buttoncode87=0
    Keycode88=0
    Buttoncode88=0
    Keycode89=0
    Buttoncode89=0
    Keycode90=0
    Buttoncode90=0
    Keycode91=0
    Buttoncode91=0
    Keycode92=0
    Buttoncode92=0
    Keycode93=0
    Buttoncode93=0
    Keycode94=0
    Buttoncode94=0
    Keycode95=0
    Buttoncode95=0
    Keycode96=0
    Buttoncode96=0
    [Inputtriggersettings]
    Pin1=0
    Port1=0
    Buttoncode1=0
    Activelow1=False
    Pin2=0
    Port2=0
    Buttoncode2=0
    Activelow2=False
    Pin3=0
    Port3=0
    Buttoncode3=0
    Activelow3=False
    Pin4=0
    Port4=0
    Buttoncode4=0
    Activelow4=False
    Pin5=0
    Port5=0
    Buttoncode5=0
    Activelow5=False
    Pin6=0
    Port6=0
    Buttoncode6=0
    Activelow6=False
    Pin7=0
    Port7=0
    Buttoncode7=0
    Activelow7=False
    Pin8=0
    Port8=0
    Buttoncode8=0
    Activelow8=False
    Pin9=0
    Port9=0
    Buttoncode9=0
    Activelow9=False
    Pin10=0
    Port10=0
    Buttoncode10=0
    Activelow10=False
    Pin11=0
    Port11=0
    Buttoncode11=0
    Activelow11=False
    Pin12=0
    Port12=0
    Buttoncode12=0
    Activelow12=False
    Pin13=0
    Port13=0
    Buttoncode13=0
    Activelow13=False
    Pin14=0
    Port14=0
    Buttoncode14=0
    Activelow14=False
    Pin15=0
    Port15=0
    Buttoncode15=0
    Activelow15=False
    Pin16=0
    Port16=0
    Buttoncode16=0
    Activelow16=False
    Pin17=0
    Port17=0
    Buttoncode17=0
    Activelow17=False
    Pin18=0
    Port18=0
    Buttoncode18=0
    Activelow18=False
    Pin19=0
    Port19=0
    Buttoncode19=0
    Activelow19=False
    Pin20=0
    Port20=0
    Buttoncode20=0
    Activelow20=False
    Pin21=0
    Port21=0
    Buttoncode21=0
    Activelow21=False
    Pin22=0
    Port22=0
    Buttoncode22=0
    Activelow22=False
    Pin23=0
    Port23=0
    Buttoncode23=0
    Activelow23=False
    Pin24=0
    Port24=0
    Buttoncode24=0
    Activelow24=False
    Pin25=0
    Port25=0
    Buttoncode25=0
    Activelow25=False
    Pin26=0
    Port26=0
    Buttoncode26=0
    Activelow26=False
    Pin27=0
    Port27=0
    Buttoncode27=0
    Activelow27=False
    Pin28=0
    Port28=0
    Buttoncode28=0
    Activelow28=False
    Pin29=0
    Port29=0
    Buttoncode29=0
    Activelow29=False
    Pin30=0
    Port30=0
    Buttoncode30=0
    Activelow30=False
    Pin31=0
    Port31=0
    Buttoncode31=0
    Activelow31=False
    Pin32=0
    Port32=0
    Buttoncode32=0
    Activelow32=False
    Pin33=0
    Port33=0
    Buttoncode33=0
    Activelow33=False
    Pin34=0
    Port34=0
    Buttoncode34=0
    Activelow34=False
    Pin35=0
    Port35=0
    Buttoncode35=0
    Activelow35=False
    Pin36=0
    Port36=0
    Buttoncode36=0
    Activelow36=False
    Pin37=0
    Port37=0
    Buttoncode37=0
    Activelow37=False
    Pin38=0
    Port38=0
    Buttoncode38=0
    Activelow38=False
    Pin39=0
    Port39=0
    Buttoncode39=0
    Activelow39=False
    Pin40=0
    Port40=0
    Buttoncode40=0
    Activelow40=False
    Pin41=0
    Port41=0
    Buttoncode41=0
    Activelow41=False
    Pin42=0
    Port42=0
    Buttoncode42=0
    Activelow42=False
    Pin43=0
    Port43=0
    Buttoncode43=0
    Activelow43=False
    Pin44=0
    Port44=0
    Buttoncode44=0
    Activelow44=False
    Pin45=0
    Port45=0
    Buttoncode45=0
    Activelow45=False
    Pin46=0
    Port46=0
    Buttoncode46=0
    Activelow46=False
    Pin47=0
    Port47=0
    Buttoncode47=0
    Activelow47=False
    Pin48=0
    Port48=0
    Buttoncode48=0
    Activelow48=False
    Pin49=0
    Port49=0
    Buttoncode49=0
    Activelow49=False
    Pin50=0
    Port50=0
    Buttoncode50=0
    Activelow50=False
    Pin51=0
    Port51=0
    Buttoncode51=0
    Activelow51=False
    Pin52=0
    Port52=0
    Buttoncode52=0
    Activelow52=False
    Pin53=0
    Port53=0
    Buttoncode53=0
    Activelow53=False
    Pin54=0
    Port54=0
    Buttoncode54=0
    Activelow54=False
    Pin55=0
    Port55=0
    Buttoncode55=0
    Activelow55=False
    Pin56=0
    Port56=0
    Buttoncode56=0
    Activelow56=False
    Pin57=0
    Port57=0
    Buttoncode57=0
    Activelow57=False
    Pin58=0
    Port58=0
    Buttoncode58=0
    Activelow58=False
    Pin59=0
    Port59=0
    Buttoncode59=0
    Activelow59=False
    Pin60=0
    Port60=0
    Buttoncode60=0
    Activelow60=False
    Pin61=0
    Port61=0
    Buttoncode61=0
    Activelow61=False
    Pin62=0
    Port62=0
    Buttoncode62=0
    Activelow62=False
    Pin63=0
    Port63=0
    Buttoncode63=0
    Activelow63=False
    Pin64=0
    Port64=0
    Buttoncode64=0
    Activelow64=False
    Pin65=0
    Port65=0
    Buttoncode65=0
    Activelow65=False
    Pin66=0
    Port66=0
    Buttoncode66=0
    Activelow66=False
    Pin67=0
    Port67=0
    Buttoncode67=0
    Activelow67=False
    Pin68=0
    Port68=0
    Buttoncode68=0
    Activelow68=False
    Pin69=0
    Port69=0
    Buttoncode69=0
    Activelow69=False
    Pin70=0
    Port70=0
    Buttoncode70=0
    Activelow70=False
    Pin71=0
    Port71=0
    Buttoncode71=0
    Activelow71=False
    Pin72=0
    Port72=0
    Buttoncode72=0
    Activelow72=False
    Pin73=0
    Port73=0
    Buttoncode73=0
    Activelow73=False
    Pin74=0
    Port74=0
    Buttoncode74=0
    Activelow74=False
    Pin75=0
    Port75=0
    Buttoncode75=0
    Activelow75=False
    Pin76=0
    Port76=0
    Buttoncode76=0
    Activelow76=False
    Pin77=0
    Port77=0
    Buttoncode77=0
    Activelow77=False
    Pin78=0
    Port78=0
    Buttoncode78=0
    Activelow78=False
    Pin79=0
    Port79=0
    Buttoncode79=0
    Activelow79=False
    Pin80=0
    Port80=0
    Buttoncode80=0
    Activelow80=False
    Pin81=0
    Port81=0
    Buttoncode81=0
    Activelow81=False
    Pin82=0
    Port82=0
    Buttoncode82=0
    Activelow82=False
    Pin83=0
    Port83=0
    Buttoncode83=0
    Activelow83=False
    Pin84=0
    Port84=0
    Buttoncode84=0
    Activelow84=False
    Pin85=0
    Port85=0
    Buttoncode85=0
    Activelow85=False
    Pin86=0
    Port86=0
    Buttoncode86=0
    Activelow86=False
    Pin87=0
    Port87=0
    Buttoncode87=0
    Activelow87=False
    Pin88=0
    Port88=0
    Buttoncode88=0
    Activelow88=False
    Pin89=0
    Port89=0
    Buttoncode89=0
    Activelow89=False
    Pin90=0
    Port90=0
    Buttoncode90=0
    Activelow90=False
    Pin91=0
    Port91=0
    Buttoncode91=0
    Activelow91=False
    Pin92=0
    Port92=0
    Buttoncode92=0
    Activelow92=False
    Pin93=0
    Port93=0
    Buttoncode93=0
    Activelow93=False
    Pin94=0
    Port94=0
    Buttoncode94=0
    Activelow94=False
    Pin95=0
    Port95=0
    Buttoncode95=0
    Activelow95=False
    Pin96=0
    Port96=0
    Buttoncode96=0
    Activelow96=False
    [Outputtriggersettings]
    Pin1=0
    Port1=0
    LEDcode1=29
    Invert1=False
    Pin2=0
    Port2=0
    LEDcode2=30
    Invert2=False
    Pin3=0
    Port3=0
    LEDcode3=31
    Invert3=False
    Pin4=0
    Port4=0
    LEDcode4=0
    Invert4=False
    Pin5=0
    Port5=0
    LEDcode5=0
    Invert5=False
    Pin6=0
    Port6=0
    LEDcode6=0
    Invert6=False
    Pin7=0
    Port7=0
    LEDcode7=0
    Invert7=False
    Pin8=0
    Port8=0
    LEDcode8=0
    Invert8=False
    Pin9=0
    Port9=0
    LEDcode9=0
    Invert9=False
    Pin10=0
    Port10=0
    LEDcode10=0
    Invert10=False
    Pin11=0
    Port11=0
    LEDcode11=0
    Invert11=False
    Pin12=0
    Port12=0
    LEDcode12=0
    Invert12=False
    Pin13=0
    Port13=0
    LEDcode13=0
    Invert13=False
    Pin14=0
    Port14=0
    LEDcode14=0
    Invert14=False
    Pin15=0
    Port15=0
    LEDcode15=0
    Invert15=False
    Pin16=0
    Port16=0
    LEDcode16=0
    Invert16=False
    Pin17=0
    Port17=0
    LEDcode17=0
    Invert17=False
    Pin18=0
    Port18=0
    LEDcode18=0
    Invert18=False
    Pin19=0
    Port19=0
    LEDcode19=0
    Invert19=False
    Pin20=0
    Port20=0
    LEDcode20=0
    Invert20=False
    Pin21=0
    Port21=0
    LEDcode21=0
    Invert21=False
    Pin22=0
    Port22=0
    LEDcode22=0
    Invert22=False
    Pin23=0
    Port23=0
    LEDcode23=0
    Invert23=False
    Pin24=0
    Port24=0
    LEDcode24=0
    Invert24=False
    Pin25=0
    Port25=0
    LEDcode25=0
    Invert25=False
    Pin26=0
    Port26=0
    LEDcode26=0
    Invert26=False
    Pin27=0
    Port27=0
    LEDcode27=0
    Invert27=False
    Pin28=0
    Port28=0
    LEDcode28=0
    Invert28=False
    Pin29=0
    Port29=0
    LEDcode29=0
    Invert29=False
    Pin30=0
    Port30=0
    LEDcode30=0
    Invert30=False
    Pin31=0
    Port31=0
    LEDcode31=0
    Invert31=False
    Pin32=0
    Port32=0
    LEDcode32=0
    Invert32=False
    Pin33=0
    Port33=0
    LEDcode33=0
    Invert33=False
    Pin34=0
    Port34=0
    LEDcode34=0
    Invert34=False
    Pin35=0
    Port35=0
    LEDcode35=0
    Invert35=False
    Pin36=0
    Port36=0
    LEDcode36=0
    Invert36=False
    Pin37=0
    Port37=0
    LEDcode37=0
    Invert37=False
    Pin38=0
    Port38=0
    LEDcode38=0
    Invert38=False
    Pin39=0
    Port39=0
    LEDcode39=0
    Invert39=False
    Pin40=0
    Port40=0
    LEDcode40=0
    Invert40=False
    Pin41=0
    Port41=0
    LEDcode41=0
    Invert41=False
    Pin42=0
    Port42=0
    LEDcode42=0
    Invert42=False
    Pin43=0
    Port43=0
    LEDcode43=0
    Invert43=False
    Pin44=0
    Port44=0
    LEDcode44=0
    Invert44=False
    Pin45=0
    Port45=0
    LEDcode45=0
    Invert45=False
    Pin46=0
    Port46=0
    LEDcode46=0
    Invert46=False
    Pin47=0
    Port47=0
    LEDcode47=0
    Invert47=False
    Pin48=0
    Port48=0
    LEDcode48=0
    Invert48=False
    Pin49=0
    Port49=0
    LEDcode49=0
    Invert49=False
    Pin50=0
    Port50=0
    LEDcode50=0
    Invert50=False
    Pin51=0
    Port51=0
    LEDcode51=0
    Invert51=False
    Pin52=0
    Port52=0
    LEDcode52=0
    Invert52=False
    Pin53=0
    Port53=0
    LEDcode53=0
    Invert53=False
    Pin54=0
    Port54=0
    LEDcode54=0
    Invert54=False
    Pin55=0
    Port55=0
    LEDcode55=0
    Invert55=False
    Pin56=0
    Port56=0
    LEDcode56=0
    Invert56=False
    Pin57=0
    Port57=0
    LEDcode57=0
    Invert57=False
    Pin58=0
    Port58=0
    LEDcode58=0
    Invert58=False
    Pin59=0
    Port59=0
    LEDcode59=0
    Invert59=False
    Pin60=0
    Port60=0
    LEDcode60=0
    Invert60=False
    Pin61=0
    Port61=0
    LEDcode61=0
    Invert61=False
    Pin62=0
    Port62=0
    LEDcode62=0
    Invert62=False
    Pin63=0
    Port63=0
    LEDcode63=0
    Invert63=False
    Pin64=0
    Port64=0
    LEDcode64=0
    Invert64=False
    Pin65=0
    Port65=0
    LEDcode65=0
    Invert65=False
    Pin66=0
    Port66=0
    LEDcode66=0
    Invert66=False
    Pin67=0
    Port67=0
    LEDcode67=0
    Invert67=False
    Pin68=0
    Port68=0
    LEDcode68=0
    Invert68=False
    Pin69=0
    Port69=0
    LEDcode69=0
    Invert69=False
    Pin70=0
    Port70=0
    LEDcode70=0
    Invert70=False
    Pin71=0
    Port71=0
    LEDcode71=0
    Invert71=False
    Pin72=0
    Port72=0
    LEDcode72=0
    Invert72=False
    Pin73=0
    Port73=0
    LEDcode73=0
    Invert73=False
    Pin74=0
    Port74=0
    LEDcode74=0
    Invert74=False
    Pin75=0
    Port75=0
    LEDcode75=0
    Invert75=False
    Pin76=0
    Port76=0
    LEDcode76=0
    Invert76=False
    Pin77=0
    Port77=0
    LEDcode77=0
    Invert77=False
    Pin78=0
    Port78=0
    LEDcode78=0
    Invert78=False
    Pin79=0
    Port79=0
    LEDcode79=0
    Invert79=False
    Pin80=0
    Port80=0
    LEDcode80=0
    Invert80=False
    Pin81=0
    Port81=0
    LEDcode81=0
    Invert81=False
    Pin82=0
    Port82=0
    LEDcode82=0
    Invert82=False
    Pin83=0
    Port83=0
    LEDcode83=0
    Invert83=False
    Pin84=0
    Port84=0
    LEDcode84=0
    Invert84=False
    Pin85=0
    Port85=0
    LEDcode85=0
    Invert85=False
    Pin86=0
    Port86=0
    LEDcode86=0
    Invert86=False
    Pin87=0
    Port87=0
    LEDcode87=0
    Invert87=False
    Pin88=0
    Port88=0
    LEDcode88=0
    Invert88=False
    Pin89=0
    Port89=0
    LEDcode89=0
    Invert89=False
    Pin90=0
    Port90=0
    LEDcode90=0
    Invert90=False
    Pin91=0
    Port91=0
    LEDcode91=0
    Invert91=False
    Pin92=0
    Port92=0
    LEDcode92=0
    Invert92=False
    Pin93=0
    Port93=0
    LEDcode93=0
    Invert93=False
    Pin94=0
    Port94=0
    LEDcode94=0
    Invert94=False
    Pin95=0
    Port95=0
    LEDcode95=0
    Invert95=False
    Pin96=0
    Port96=0
    LEDcode96=0
    Invert96=False
    [CAMsettings]
    Tooldia=0
    Startdepth=0
    Cutdepth=0
    Cutperpass=0
    SafeZ=0
    Feedrate=0
    Tooloverlap=0
    Plungerate=0
    Spindlespeed=0
    Arctolerance=0.01
    [Laserengraveplugin]
    workpiecewidth=50
    workpieceheight=50
    keepaspectratio=True
    Yscandistance=0.2
    Feedrate=1000
    Originsetting=7
    [Plugins_enabled]
    Debugger.dll=False
    Diagnostics.dll=False
    Laserengrave.dll=False
    Plugintest.dll=False
    Webcamera.dll=False
    Printer3D.dll=False
    UCR200Plugin.dll=False
    Xbox360controller.dll=False
    Scope.dll=False
    AutoLevelerCA.dll=False
    Modbusmaster.dll=False
    UCCNC_OSK.dll=False
    UCR201Plugin.dll=False
    XHC-HB04_pendant.dll=False
    HYPLUGIN.dll=True
    [Plugins_callstartup]
    Debugger.dll=False
    Webcamera.dll=False
    Printer3D.dll=False
    Scope.dll=False
    UCCNC_OSK.dll=False
    HYPLUGIN.dll=True
    [Macroloops]
    Macroloopautorun0=False
    Macroloopnumber0=0
    Macroloopautorun1=False
    Macroloopnumber1=0
    Macroloopautorun2=False
    Macroloopnumber2=0
    Macroloopautorun3=False
    Macroloopnumber3=0
    Macroloopautorun4=False
    Macroloopnumber4=0
    Macroloopautorun5=False
    Macroloopnumber5=0
    Macroloopautorun6=False
    Macroloopnumber6=0
    Macroloopautorun7=False
    Macroloopnumber7=0
    Macroloopautorun8=False
    Macroloopnumber8=0
    Macroloopautorun9=False
    Macroloopnumber9=0
    Macroloopautorun10=False
    Macroloopnumber10=0
    Macroloopautorun11=False
    Macroloopnumber11=0
    Macroloopautorun12=False
    Macroloopnumber12=0
    Macroloopautorun13=False
    Macroloopnumber13=0
    Macroloopautorun14=False
    Macroloopnumber14=0
    Macroloopautorun15=False
    Macroloopnumber15=0
    Macroloopautorun16=False
    Macroloopnumber16=0
    Macroloopautorun17=False
    Macroloopnumber17=0
    Macroloopautorun18=False
    Macroloopnumber18=0
    Macroloopautorun19=False
    Macroloopnumber19=0
    Macroloopautorun20=False
    Macroloopnumber20=0
    Macroloopautorun21=False
    Macroloopnumber21=0
    Macroloopautorun22=False
    Macroloopnumber22=0
    Macroloopautorun23=False
    Macroloopnumber23=0
    Macroloopautorun24=False
    Macroloopnumber24=0
    Macroloopautorun25=False
    Macroloopnumber25=0
    Macroloopautorun26=False
    Macroloopnumber26=0
    Macroloopautorun27=False
    Macroloopnumber27=0
    Macroloopautorun28=False
    Macroloopnumber28=0
    Macroloopautorun29=False
    Macroloopnumber29=0
    Macroloopautorun30=False
    Macroloopnumber30=0
    Macroloopautorun31=False
    Macroloopnumber31=0
    Macroloopautorun32=False
    Macroloopnumber32=0
    Macroloopautorun33=False
    Macroloopnumber33=0
    Macroloopautorun34=False
    Macroloopnumber34=0
    Macroloopautorun35=False
    Macroloopnumber35=0
    Macroloopautorun36=False
    Macroloopnumber36=0
    Macroloopautorun37=False
    Macroloopnumber37=0
    Macroloopautorun38=False
    Macroloopnumber38=0
    Macroloopautorun39=False
    Macroloopnumber39=0
    Macroloopautorun40=False
    Macroloopnumber40=0
    Macroloopautorun41=False
    Macroloopnumber41=0
    Macroloopautorun42=False
    Macroloopnumber42=0
    Macroloopautorun43=False
    Macroloopnumber43=0
    Macroloopautorun44=False
    Macroloopnumber44=0
    Macroloopautorun45=False
    Macroloopnumber45=0
    Macroloopautorun46=False
    Macroloopnumber46=0
    Macroloopautorun47=False
    Macroloopnumber47=0
    [SpindlePIDsettings]
    PIDenable=False
    Kp=1
    Kd=0
    Ki=0.01
    Samplingtime=10
    [AUXencodersettings]
    AUXencoder1pinA=0
    AUXencoder1portA=0
    AUXencoder1pinB=0
    AUXencoder1portB=0
    AUXencoder2pinA=0
    AUXencoder2portA=0
    AUXencoder2pinB=0
    AUXencoder2portB=0
    AUXencoder3pinA=0
    AUXencoder3portA=0
    AUXencoder3pinB=0
    AUXencoder3portB=0
    AUXencoder4pinA=0
    AUXencoder4portA=0
    AUXencoder4pinB=0
    AUXencoder4portB=0
    AUXencoder5pinA=0
    AUXencoder5portA=0
    AUXencoder5pinB=0
    AUXencoder5portB=0
    Aux1Encodercountsper=0
    Aux2Encodercountsper=0
    Aux3Encodercountsper=0
    Aux4Encodercountsper=0
    Aux5Encodercountsper=0
    Aux6Encodercountsper=0
    [Digitizesettings]
    Addaxisnames=False
    Xinclude=True
    Yinclude=True
    Zinclude=True
    Ainclude=False
    Binclude=False
    Cinclude=False
    Commaseparation=False
    Filenametosave=C:\UCCNC\Example_codes\Digitize.txt
    Numberofdigits=4
    Probedia=0
    Clearfilenamewhenfinished=False
    [Statistics]
    TotalM3s=235
    TotalM4s=0
    TotalM7s=1
    TotalM8s=2
    Totaltimedays=0
    Totaltimehours=13
    Totaltimeminutes=57
    Totaltimeseconds=55
    M3timedays=0
    M3timehours=2
    M3timeminutes=2
    M3timeseconds=54
    M4timedays=0
    M4timehours=0
    M4timeminutes=0
    M4timeseconds=0
    Cyclestimedays=0
    Cyclestimehours=0
    Cyclestimeminutes=11
    Cyclestimeseconds=36
    TotaldistX=451
    TotalcutX=145
    TotaldistY=605
    TotalcutY=85
    TotaldistZ=135
    TotalcutZ=36
    TotaldistA=0
    TotalcutA=0
    TotaldistB=0
    TotalcutB=0
    TotaldistC=0
    TotalcutC=0
    UCdevicetype=UC100
    [UserCheckboxes]
    20301=False
    20302=False
    20303=False
    20304=False
    20305=False
    20306=False
    20307=False
    20308=False
    20312=False
    20309=False
    20310=False
    20311=False
    [UserTextfields]
    20333=0.1
    20334=0.0
    20335=0.01
    20336=0.01
    20337=0.01
    20338=0.01
    20339=0.0
    20340=0.01
    20341=0.0
    20342=0.01
    20343=0.0
    20344=0.0
    20345=0.0
    20346=0.0
    20347=0.0
    20348=0.0
    20349=0.0ø
    20350=0.0
    20304=0.0
    20300=0.0
    20301=0.0
    20302=0.0
    20303=0.0
    20305=0.0
    20306=0.0
    20307=0.0
    20308=0.0
    20309=1
    20310=5
    20311=10
    20312=25
    20313=50
    20314=100
    20315=0.001
    20316=0.01
    20317=0.1
    20318=0.25
    20319=0.5
    20320=1.0
    20321=0.0
    20322=0.0
    20323=0.0
    20324=0.0
    20325=0.0
    20326=0.0
    20327=0.0
    20328=0.0
    20329=0.0
    20330=0.0
    20331=0.0
    20332=0.0
    20351=0.0
    20352=0.0
    20353=0.0
    20354=0.0
    20355=0.0
    20356=0.0
    20357=0
    20358=0.0
    [2017JogSpeeds]
    913=5
    2027=0.01
    [Hyplugin]
    Selectedport=COM5
    Selectedbaud=9600
    SelectedFreq=400
    Selectedminrpm=6000
    Selectedmaxrpm=24000
    SactField=
    AmpFeild=
    OnOff=False
    AmpCB=False
  12. #532
    35494
    Did you set all the required parameters in the VFD?
    PD001
    PD002
    PD004
    PD163
    PD164
    PD165
  13. #533
    May 2018
    17
    pd001 is 2
    pd002 is 2
    pd004 is 400.0
    pd163 is 001
    pd164 is 1
    pd165 is 3
  14. #534
    35494
    Dan would no better, but it sounds like the RS-485 adapter is either not working, or not wired correctly.
    RS-485 adapter issues seem to be very common.
  15. #535
    May 2018
    17
    I've tried 2. from 2 different sellers. I guess I could try ordering more.
    I think I've tried about everything
  16. #536
    35494
    Dan might know better.
    Can you control the spindle with spindletalker?
  17. #537
    May 2018
    17
    no. It just continues to send commands, but nothing is received
  18. #538
    Mar 2010
    813
    Quote Originally Posted by healinhand View Post
    It may seem like it's communicating because written bytes are only showing what serial port is putting out, no test for rs485 and VFD. If no response than communication is your problem, even if a bad/incorrect byte array was sent the VFD will still reply.
    If your able to download a free Serial Monitor and post dump it will give a more definitive clue of what's happening.
    Dan
  19. #539
    May 2018
    17
    Do you have a preference and maybe a link?
  20. #540
    Mar 2010
    813
    This is the one I use, it gives a 14 day free trail period. Use dump view to post.
    https://www.eltima.com/products/serial-port-monitor/
  1. Accessing Macro Variable from another macro
    By ex-egll in forum Mach Wizards, Macros, & Addons
    Last Post: 02-01-2014, 06:52 AM
  2. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  3. Replies: 3
    Last Post: 02-13-2012, 07:20 PM
  4. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  5. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
