![Quote](images/misc/quote_icon.png)
Originally Posted by
Mariss Freimanis
To add to what Marcus wrote:
1) The G250/G251 now also includes Automatic Standby Current. The phase current folds back to 70% of set value one second after the last step pulse. This cuts motor resistive heating and drive heating 50%.
2) The Current Set resistor is now a linear function of current; 1K equals 1A. You want 3.3A, you use a 3.3K resistor, you want 1.2A, you use a 1.2K resistor, etc.
3) The final board dimensions are 1.325" by 1.675" and are the same for both the G250 and the G251.
4) The G250/G251 had bloated $1.50 over it's budget. We had to get very clever with the circuit to preserve and even add features (1, 2) while putting the design on a strict diet. That involved a major redesign and I'm happy to say it has been successful.
We have been running the test production drives with no heatsinking whatsoever at 3.5A and 50VDC; the power MOSFETs get warm but not hot. To summarize:
CPLD based 10-microstep drive.
15VDC to 50VDC supply voltage.
0 to 3.5A motor phase current.
Mid-band resonance compensation.
Microstep to Full-step morphing at higher speeds.
Automatic Stanby Current.
Silent synchronous clocked design; no hissing, squealing, grunting or whistling. Ever.
Trimpot Adjust for low-speed smoothness.
Premium 4-layer printed circuit board.
NEMA-23 motor speeds tested to 10,000 RPM.
Very small size: 1/3 the size of a credit card.
Very efficient, very low drive heating.
Survives motor disconnect while powered.
All surface mount component (0603) design.
$29 for the G250 in large quantities, a little more for the G251.
Mariss
