603,308 active members*
3,087 visitors online*
Page 29 of 29 19272829
Results 561 to 563 of 563
  1. #561
    Sep 2016
    9
    Re: Another Aussie Auto Tool Zero Setter
    I built a new cnc machine and I have a problem in zeroing so i will try again now
    Sent from my SM-J700H using Tapatalk
  2. #562
    Sep 2016
    9
  3. #563
    Aug 2008
    4
    Another Aussie Tool setter not working with SmoothStepper
    hi Guys
    have run my machine with Greolt's Aussie tool Setter for a number of years and everything worked well.
    had to change computers recently and now running Windows 10 with ESS SmoothStepper. All if fine apart from the Tool Setter now not working.
    I have tried using Greolt's 'Modified 1024 screenset and the probe/Touch plate registers on the LEd and in the Diagnostics page. I have set the thickness of the touch plate, however, it always seems to hang at the "G4 P3" - "G90 G31Z-4. F4" section.
    Any ideas - it is driving me nuts.
    Using CNC4PC C10 Bob's - work well - and the inputs set to 'Pull High' and the Pins sets to 'Active Low'. The input pins are at 4.98v.
    Any and all suggestions greatly appreciated.
    Cheers
    Noel :cheers:
  1. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  2. Auto tool setter / touch plate ?
    By chrisnis in forum Machines running Mach Software
    Last Post: 04-06-2013, 12:24 AM
  3. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  4. Auto Tool Setter Button IH taylored !
    By Cruiser in forum Charter Oak Automation Support Forum
    Last Post: 08-06-2009, 03:25 PM
  5. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
