588,033 active members*
5,431 visitors online*
Thread: Hoss's G0704
Page 293 of 344 193243283291292293294295303343
Results 5,841 to 5,860 of 6871
  1. #5841
    Re: Hoss's G0704
    Thanks fellas!
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #5842
    Re: Hoss's G0704
    I'll have the plans done by the morning, just have to go take a few close up pics and edit them then put it all in a zip.
    Hoss
  3. #5843
    Re: Hoss's G0704
    The free plans for this power drawbar can be had by private messaging me here on cnczone or emailing me at [email protected] for the link and password, Hoss
  4. #5844
    Jan 2008
    1543
    Re: Hoss's G0704
    Hoss, I presume the plans are free for people who have already bought the DVD? Or for everyone?
    Great work on the drawbar.
    I'm still looking at making a manual version of this with a long lever.
  5. #5845
    Re: Hoss's G0704
    Quote Originally Posted by pippin88 View Post
    Free to anyone that asks.
    Hoss
  6. #5846
    Feb 2014
    103
    Re: Hoss's G0704
    Acquiring funds for stage 1 conversion.
    There is no reason I couldn't easily upgrade from Phase 1 to Phase 3 conversion?
    I plan on getting good electronics and steppers. I guess the only thing I would need to upgrade would be the C7 ballscrews?
  7. #5847
    Re: Hoss's G0704
    That's the case often, build phase 1 then use the cnced mill to help build phase 2 or especially 3 when the funds are there for ballscrews.
    Hoss
  8. #5848
    Jan 2008
    1543
    Re: Hoss's G0704
    Thanks for the plans Hoss, you are a champion.
    I contacted chai about double nuts - I bought my screws a little before you posted about them - and he said I can retrofit them, so I've got some coming. I'll update on the backlash when they come, as it might help others who didn't get them at time of ordering screws.
  9. #5849
    Re: Hoss's G0704
    That's cool to hear he'll sell the double nuts separately now, will be a good option for many.
    Hoss
  10. #5850
    Re: Hoss's G0704
    A note on the PDB 3, I can't locate my treadmill motor at the moment to check but there is a possibility that the height of the motor could interfere with the tilting air cylinder.
    I'll hunt it to make sure but using the cam lever with the slot that I made first should fix it and let the pivot for the cylinder be tightened in place, with a bolt and different bushing, so it stays put.
    I'll verify soon I hope.
    Hoss
  11. #5851
    Jun 2013
    1041
    Re: Hoss's G0704
    I like the drawbar design. If you're worried about it interfering with the drive motor could you just remove the yellow part from the pictures and turn it 180deg?
    Ben
  12. #5852
    Re: Hoss's G0704
    I would imagine the cylinder rod/cam lever could hit the motor turned 180 but it's possible.
    The motor and mounting holes could just me moved farther back with a longer belt too.
    Hoss
  13. #5853
    Re: Hoss's G0704
    If anyone is looking to buy something from grizzly by sept 30th, just got an email with a coupon code for 10% off the entire order, 14FC047085840.
    Hoss
  14. #5854
    Sep 2011
    281
    Re: Hoss's G0704
    is there any reason to not use helical coupler's when connecting up your stepper's to the ballscrew's?
    Colten Edwards http://www.cncsigns.ca
  15. #5855
    Re: Hoss's G0704
    Quote Originally Posted by cd_edwards View Post
    Yeah, they suck.
    Unless you use stainless steel helicals, aluminum ones are too springy and prone to breaking at the force the 570 steppers can put on them at the speeds possible.
    You can run what you like but they'd never go on my mill.
    Hoss
  16. #5856
    Jul 2010
    60
    Re: Hoss's G0704
    I tried the helical Aluminum ones at first, went thru about 5 broken ones before I swore never to use them again.
  17. #5857
    Mar 2006
    19
    Re: Hoss's G0704
    Hoss, thanks for the PDB3 plans.
    One thing I can't seem to find information on, and I assume this is because it is in the belt drive kit, is the height of the base mount (rails) that screw directly to the head of the mill. The part the base legs attach to. They look to be 0.5 inches wide by 1 inches tall. Is that correct? I don't really need much past the height. I want to make sure the spacing from top to bottom is as accurate as possible
  18. #5858
    Re: Hoss's G0704
    The beltdrive mount it sits on is .5 wide x .75 tall in that section, that's about the same height as the stock motor plate too.
    Hoss
  19. #5859
    Aug 2010
    630
    Re: Hoss's G0704
    I've looked through all my folders and such for videos / pictures for the C7 LMB2008 Z axis being installed.. I can't find anything. Which way does the nut go? Ballnut flange toward the turned end or away?
    Thanks, Connor
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  20. #5860
    Re: Hoss's G0704
    Quote Originally Posted by Connor View Post
    Thanks, Billy
    That's because I never installed one in mine but I would have the ballnut flange on top so the screws go in from the top.
    Hoss
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
