![Quote](images/misc/quote_icon.png)
Originally Posted by
HimyKabibble
"Yes , 2000 steps/turn and 5Tpi gives 10,000 steps/inch. So you should easily get a solid repeatable resolution of 0.001" (on the screw anyway, not counting linear backlash or friction)" - "easily"??
If you build a machine with rolled ballscrews with a maximum lead error of AT LEAST +/-0.003" per foot, how do you "easily get a solid repeatable resolution of 0.001"? This means, essentially, that the screw position can be off by +0.003" at one position, and off by -0.003" at another position an inch away from that first position. And ground screws are out of the question, as one of them would cost more than the whole machine. And without double ballnuts (which are hard to fit into an X2), or true zero backlash nuts and screws ($$$), the screw WILL have measurable backlash.
If you get an X2 where the X and Y ways in the saddle have been machined 0.005" out of square (which is not at all unusual) what are you going to do?
If you get a saddle, table, column or head where the ways are not milled parallel, or even straight, (both of which are VERY common on X2s) what are you going to do?
If you get a spindle with 0.0005" runout (which near the BEST you could hope for) what are you going to do?
A 10 degree change in the temperature of the machine will change the length of the table, the column and the screws by almost 0.001"! What are you going to do about that?
Even after it's been "shimmed and tuned to death", these problems WILL still exist.
Getting TRUE 0.001" accuracy AND repeatability (and one without the other is kinda useless...), over more than a very short distance, is NOT easy, and NOT cheap. Geometry errors in the basic mill components (which is almost ALWAYS present in these machines) cannot reasonably be corrected for. Lead error in the screws (which is ALWAYS present, even in the $$$ ones) , cannot reasonably be corrected for. Spindle runout cannot reasonably be corrected for. Getting these factors, and the many other important ones, individually down to the 0.001" range is difficult. Getting the TRUE overall system performance into that range is VERY difficult. On an X2, it's probably near impossible.
You need to set realistic expectations. If you REALLY need that kind of accuracy, then the X2 is not the place to start. OTOH, I'd bet you don't REALLY need that kind of accuracy, other than perhaps for a few specific operations, like boring bearing pockets.
Adding up all the theoretical capabilities of the machine based on individual component specs will give you numbers that are wildly optimistic compared to the machines actual, real-world capabilities. Commercial machines get their specs under 0.001" by using FAR more expensive components (a single VMC ballscrew can cost thousands of $), screw mapping, closed loop positioning, temperature controlled environments, and many other "tricks".
Regards,
Ray L.
