588,613 active members*
6,870 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > ATC. Automatic Tool Changer issue. Leadwell Mill, MCV-OP Fanuc OM controller
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    Mar 2011
    230
    Re: ATC. Automatic Tool Changer issue. Leadwell Mill, MCV-OP Fanuc OM controller
    Quote Originally Posted by machinehop5 View Post
    ...looking at lobboo's Ladder pdf file, I see M21-M26 codes should Step control your TC manually..try all of them to see if, they are working
    M26 - Tool unclamp
    M25 - Tool clamp
    M24 - Magazine Down
    M23 - Mag UP
    M22 - Mag Left
    M21 - Mag Right
    Hi machinehop5
    I'm back to this issue again which I never resolved, ATC. I've got other parts of the machine working and actually made a part, I'm using this as a single tool at the moment.
    Ill try these M codes you posted, i guess it can be done in MDI? I've basically done other repairs around the machine, there were quite a few things that needed to be done and now back to the ATC.
    Ill see how I go.
  2. #42
    Mar 2011
    230
    So whats happened so far.
    M26 tool unclamp OK
    M25 tool clamp OK
    M24 Mag down OK
    M23 Mag up OK
    M21 Mag right Error 1036 T number unmatched and 1042 SPDL Unorient
    M22 Mag left didn't work as the ATC is in the left position.
    I guess if i can find what the code number for spindle orientation is, I'm not sure if its in my book. Tool number unmatch has got me beat.
  3. #43
    Mar 2011
    230
    Just found this, ill try it in a moment.
    M19 spindle orientation.,
    https://www.helmancnc.com/fanuc-m-code-list/
  4. #44
    Mar 2011
    230
    Just tried M19 and spindle is not turning/orientating but I can hear the relays switching. I remember when I had a technician looking at this he did mention this issue.
    Also the technician made some changes in the ladder regarding the ATC and since then the code M6 T# doesn't rotate the ATC. Rotation of the ATC was the only part that worked when punching in this code before the ladder change.
    I have some ladder diagrams another guy kindly posted on this forum.
Page 3 of 3 123
  1. Tool changer problem Leadwell MCV-760 CR
    By Nilsson.ganda in forum Fanuc
    Last Post: 02-11-2015, 06:11 PM
  2. LeadWell MCV-760 FANUC 0-MF ATC macro
    By cnc35 in forum Fanuc
    Last Post: 08-05-2013, 08:44 PM
  3. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  4. ATC automatic tool changer
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 06-29-2010, 08:01 AM
