588,648 active members*
6,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > DIY mill from commercial castings?
Page 3 of 3 123
Results 41 to 57 of 57
  1. #41
    Dec 2005
    436
    Re: DIY mill from commercial castings?
    When I pay attention to the sound when cutting I can't help but think it is the machine frame vibrating and resonating.
  2. #42
    Dec 2016
    134
    Yeah that's probably correct.
    It is at it's limits with the 20mm end mill, but I think the finish is ok?
    This was of course a very light cut for the end mill, I won't be close to pushing it with this one.
  3. #43
    Dec 2005
    436
    Finish: I am a relativist on this issue. If it suits your purpose then the finish is OK.
  4. #44
    Dec 2016
    134
    Made these today. Two identical blocks.
    A 4,5mm x 9,5mm pocket 24mm deep. Machined with a 4mm end mill just ramping down. Flood cooling is great
    Did the chamfer with a ball end mill.
  5. #45
    Feb 2004
    33
    Very nice work on the mill!
  6. #46
    Dec 2016
    134
    Thank you
  7. #47
    Dec 2016
    134
    The mill runs fine.
    I have made a 5 axis attachement to run some light housing parts.
    A-axis is belt driven mini lathe headstock
    C-axis is a belt driven harmonic drive gearbox.
    Made a youtube video on machining a test part:
    https://www.youtube.com/watch?v=Wc_CNS88txw
    It is quite long, but have listed the different operations.
    Something is not perfectly straight though as seen on the pictures (when facing off the thin sides). It left a bump at two of the corners.
    Don't really know is if it is out of alignment or if the cut was too heavy for the c axis to stay in place.
    Future work: run the wires through the A-axis axle and make a cover for the C-axis belt drive.
    Also what is the positive direction on A and C? Started to wonder if I have them both going the wrong way both in my post processor and on the machine, is that even possible?
    Attached Thumbnails Attached Thumbnails 20220123_150844.jpg   20220110_231240.jpg   20220111_183639.jpg
  8. #48
    That A and C axis are freaking off the charts cool. What items did you use to make that? I spent a lot of time making a trunnion table for my G0704 and ultimately realize the work area just got too small on my machine. There were some other issues, but it looks like you got closer than I did.
  9. #49
    Dec 2016
    134
    This is made for very small parts. Basically max ~80mm cube.
    The A is this headstock https://www.amadeal.co.uk/acatalog/H...18_013CRB.html
    With a 100mm plate. Would probably be better off with a harmonic drive here as well, but bought it originally for a 4th axis/turn attachment on my router. Didn't get used much. A big belt pulley on the back of it gives about 1:8 reduction.
    The C is a 74mm harmonic drive with 1:50 (I think it was). Used from one of the large asian resellers on ebay. They made a mistake in the listing on the model number and it is smaller than I would like, but decided to use it anyway. The aluminium angle is a part from an electric rail that was thrown out from a transformer station... Quite soft and not easy to machine. The stepper mount is made from a much harder alloy and is better.
  10. #50
    I bought a used 1:80 harmonic drive on eBay for my A axis and used a 1:60 belt drive for C. The issues I ran into were seemingly just cumulative errors that started from the G0704 not being great and my machining not really being optimal. I ended up using most of the stock from the trunnion for projects later, so I don't have much of it left. Ultimately I gave up on the project, because frankly, I wasn't up to the task. I do dream of giving it a second try. My machining abilities have grown a lot since then, and the design wasn't as bad as I thought it was.
    You have gotten closer than I did, with some more work you will get there! That aluminum angle is rather sweet! I like what appears to be your 3d printed covers too!
  11. #51
    Dec 2016
    134
    There are some cumulative errors here as well. So if I want to get it perfect I have to start over with a new machine.
    But this has been great learning and it is good to have a small weak machine to crash in the beginning
    And for the light housing the critical features (placement of LED and optics) are machined at a fixed A-C position with just the XY moving at different Z for the two faces. 5 axis toolpath will be on the outside.
    Yes, 3D printed covers
  12. #52
    Dec 2016
    134
    Finished the first light housing. I conclude the 5 axis is working as hoped.
    No simultaneous 5 axis on this for now because Autodesk desided to restrain those tool paths to the machining extension right before I was going to do this and I don't pay for that (yet).
    I screwed up the cam a couple of places and the machines was out of reference in one operation. So this piece is not nearly perfect. But I hope I will get there in a few tries.
    The reference was a problem because I've done this over a few weeks and I turn the machine off every time I've jused it. So just homed it once and startet milling, but my homing switches is not good enough for this so need to reset zero every time..
    But even with position only 5 axis is great to watch when the tool paths are working. But a lot of checking and thinkering the first time...
  13. #53
    Dec 2016
    134
    It's alive
    Added videos on youtube as well. They are long, tried to add something from each operation. And in the free video editor I'm using I cant fast forward either.
    https://www.youtube.com/watch?v=y1bOJkNSeX8
    https://www.youtube.com/watch?v=dlgdbOoqPJw
    https://www.youtube.com/shorts/G5bF4ftSu-Y
  14. #54
    15362
    Quote Originally Posted by Buoyen View Post
    The mill runs fine.
    Works well
    What Cam software are you using ??
    Mactec54
  15. #55
    Dec 2016
    134
    Thank you, Mactec!
    It is Fusion 360. Choice of tool paths are probably not always the best. But it works. I am paying for the hobby version. 5 axis Flow and swarf was an option here before, but was removed before I managed to program this light housing.
    A true 5 axis move could be better on the cooling fins and around the mounting tabs.
  16. #56
    Oct 2013
    543
    You are a very talented person and your inventiveness is superb...great work.
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  17. #57
    Dec 2016
    134
    Wow, thank you, Stuart!
Page 3 of 3 123
  1. Replies: 299
    Last Post: 10-16-2022, 01:54 PM
  2. Fullmida Automation Mill Castings Experience
    By fritts in forum Benchtop Machines
    Last Post: 11-28-2018, 06:52 PM
  3. Commercial CNC mill - BZT and Heigh Z
    By Kent_Norway in forum Commercial CNC Wood Routers
    Last Post: 10-01-2007, 02:50 PM
  4. CNC Mill and CNC Lathe offered. Aluminum and Gray Iron Castings
    By maquiza in forum Employment Opportunity
    Last Post: 12-31-2005, 05:37 PM
  5. Anyone mill templates for castings?
    By studysession in forum Jewelry Design Software
    Last Post: 12-05-2005, 10:08 PM
