588,398 active members*
4,507 visitors online*
Page 3 of 4 1234
Results 41 to 60 of 61
  1. #41
    Mar 2009
    1114
    No no don't get it wrong. I have used the smooth stepper before and it works great, I'm just saying the backlash comp plugin has some kinks. The smooth stepper its self is awesome, I would recommend it to anyone. The best part is the USB interface.
  2. #42
    Oct 2010
    266
    Quote Originally Posted by Starleper1 View Post
    thats awesome they are working on backlash comp for it. that is the single thing that kept me from buying it for my lathe or mill
  3. #43
    Mar 2009
    1114
    I know me too. It blows away the parallel port on performance, but if you didn't have a means of zero backlash i.e. double ball nut. It's wasn't a viable solution. Now that it has backlash support I think you will see it more.
  4. #44
    Jun 2005
    53
    Got the x and y up and running. It's only at 66% of max speed due to the parallel port, but still way faster then I need. Here is a little video. Hope to have the z up and running next weekend.
    bccde710.mp4 video by sdubfid - Photobucket
  5. #45
    Feb 2010
    3447
    One of your axis sounds pretty loud/ different from the others?
    REALLY fast though!!
    Quote Originally Posted by sdubfid View Post
  6. #46
    Jun 2005
    53
    Quote Originally Posted by diyengineer View Post
    Yah I noticed that too. It's my x-axis that is louder. I was just happy to have it working. But I also remember not lubing the x like the y so I'm going to try that next weekend, hopefully thats all it is.
    Is it safe to use grease on the ballscrews? When I took the ballnuts apart they had grease from the factory. I was even considering greasing the ways instead of using oil. Any issues with this?
  7. #47
    Mar 2009
    1114
    You can use grease, but keep in mind, grease is tacky and it will collect chips a lot more then using oil.
  8. #48
    Looking great, gee, from your PM I thought maybe you were going with the front mounted Y.
    I'm real happy with the rear mounted Y but it still needs a motor cover.
    Best of luck, Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  9. #49
    Jun 2005
    53
    sweet finally got to cut some aluminum with it
    I cut a 2' diameter circle in a 3/8" plate.
    it came out within .0015" and there were no marks or divots where the axes reverse rotation. Pretty darn good for the first part.
    Won't be able to update for a month as I'm starting a new job and moving.
    Hopefully Hoss will have some new plans out by then that I can buy.
  10. #50
    Jun 2005
    53
    Been a long time since any updates. I got the machine working and have engraved a few things and done some random stuff. Still have a bunch of work and tidying up to do.
    I picked up a dmm 750w servo today to use as my spindle motor. My stock motor is an early grizzly 750w motor.
    I will be doing belt drive too. Max rpm will be 6000rpm. DIYENGINEER has already upgraded my spindle bearings. Servo motor max rpm is 1000rpm with their old servo drives. With the new servo drive it will do ~3000rpm 110v and ~5000rpm 220v. I will be running 110v and 1:2 ratio probably with a gt2 belt. Should be a good combo for tapping.
  11. #51
    May 2005
    3920
    Nice pics.
    Believe me I understand the issues with finding time to pursue such things while working. It is not easy at all!
    Did you ever get rid of the MTW mill? I see it is still have it listed.
    it is looking good though!
    Why stick with the same power range? This mill is really nice and should handle a larger motor well, especially if you gear it up for higher speeds.
    I'd go for 220v myself.
  12. #52
    Feb 2006
    7063
    High RPM is only useful for small cutters, which require very little power. High power is need only for large tools taking aggressive cuts, and the G0704 is really not rigid enough to handle more than about 1HP, probably less.
    Regards,
    Ray L.
  13. #53
    Feb 2010
    3447
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    If you watch The videos on HOSS's youtube page, he takes some insane cuts with the stock motor. 750watts is a pretty good chunk of power! Looking good keep up the great work.
  14. #54
    Feb 2010
    3447
    Dang! that is really good on search a large circle and first time operation! congrats!!!
  15. #55
    Jun 2005
    53
    haha should be 2" not 2'. Machine worked awesome interpolating some 3" holes in 6061. Now I will get to weld the machined parts when I'm back from europe in July.
  16. #56
    Feb 2010
    3447
    Well even for 2" that is great! haha I'm sure you will get it all dialed in. Have fun in Europe!
  17. #57
    Feb 2010
    3447
    Any updates?
  18. #58
    Jun 2005
    53
    Any updates?
    I have moved to fort mcmurray alberta. Will be parting the machine out in July when I am on vacation in BC if anyone is interested in the dmm kit or ballscrew kit or complete machine.
  19. #59
    Mar 2010
    115
    Sorry to hear about the move. Nobody deserves to live in the Mac.
    I'm sure you got killer pay work up there though. I was this ~> <~ close to going there myself,but the position fell through.
    Email me a list of what you've got,and what you want for it. I'm in North Delta (15 minutes from Vancouver).
  20. #60
    Feb 2010
    3447
    Ahh that sucks!
Page 3 of 4 1234
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. No Joy with my New G0704
    By DogWood in forum Benchtop Machines
    Last Post: 07-05-2016, 05:49 PM
  3. Different G0704 motors?
    By jeremy0203 in forum Benchtop Machines
    Last Post: 08-05-2011, 06:09 AM
  4. G0704 or a X-3
    By USN in forum Benchtop Machines
    Last Post: 05-30-2011, 08:24 AM
  5. Yet another G0704 purchase.
    By Wmacky1 in forum Benchtop Machines
    Last Post: 09-20-2010, 05:58 AM
