So far it's pretty square, but I can only measure using a square. The machine itself will be out a bit here and there but I hope some stuff I can square up by loosening, adjusting, and retightening. Other area's may need shimming. Once it's built, I will use a dial indicator to get it as close as I can, and cut a couple squares and check that the right angles are right...
I am willing to accept it as good as it comes out. I mostly cut airplane parts, so 10 thousands here and there won't matter. Still, I hope to get it better than that. We will see.
I used 6061-T6 aluminum. I drew it up in 2D.
I wish it wouldn't crash.
