That is funny Scott, that is the same the new Z axis plates are being done now ,
XZero cnc
also the adaptor plate for Teknomotor and the Colombo spindles to mount to Z axis plate
XZero cnc
They are almost the same as Scott put them
XZero cnc
XZero cnc
Great minds think alike
Scott...
RMGreen Videos - Instructional Videos for Woodworking, CNC, Guitar Building
It never fails, you never get as much done as you want to. After I got the z axis plate sized and drilled, I was putting my flycutter on my mill to face the plate before I recessed the holes for the bolts, and stripped the drawbar out on my mill. So, now I have to make a new drawbar before I can get any farther. Oh well, I have been meaning to make a new drawbar anyway so I can put an airpowered drawbar tool on top of the mill.
Hope to have the mill's drawbar finished up this week, and back to finishing the plate this weekend.
What do I have left to do before I can cut something?
1) Spindle Plate.
2) Wire and test spindle.
3) Install Igus chain.
4) Figure out a way to mount a spoilboard.
Other stuff to do:
1) Check and adjust (if possible) squareness of machine.
2) Install new Mach3 2010 screensets I purchased.
3) Figure out a realistic speed to run this thing at.
4) Build Indexer.
5) Test some aluminum cuts.
6) Install Inductive Prox sensors.
Stay Tuned,
Scott
http://www.rmgvideos.com/
Other stuff to do:
GOOD LUCK with this one!!!
I just had to machine my gantry sides to allow me to adjust the squareness of the machine. The squareness error bolted together right out of the box was .06" over 20". After I machined the side rail pockets to allow some adjustment I was able to adjust to .01" over 20". I couldnt adjust better than this because it was actually bowing in the middle probably because of the way I adjusted it. The error is acceptable to me at this level.
I have some videos showing the parallelism adjustment of the Z rails before an after tweeking.
[nomedia="http://www.youtube.com/watch?v=SOl15Z08scM"]YouTube - XZero CNC 8" Z AXIS Hiwin Rails[/nomedia]
And also some interesting resolution tests on the Z axis.
[nomedia="http://www.youtube.com/watch?v=FVNPAVfAhoc"]YouTube - Xzero Hiwin Z axis motion resolution[/nomedia]
Ok, made some great progress tonight. Got my drawbar finished on the mill, the spindle plate faced, countersunk and finished and the spindle mounted to the machine. I'm pretty happy with where I am tonight, and can get a bunch of stuff done tomorrow that I didnt think I would get to.
Scott...
Installed tray for Igus cable carrier...
Scott
Wow, very nice! One would expect that you would receive it that way given that it was cut on a CNC mill!
Scott...
X Axis Igus cable carrier installed...
Scott...
As I expected I now have a problem with the X axis motor coupler. I ran the machine up against the stop, and now the coupler is spinning on the ballscrew shaft. This design is terrible. I now have to take the machine off of the stand, take entire endplate off of the machine, and hope that I can replace the bolt that I ground off to get the coupler to fit in the endplate hole. Again, this is a terrible design! If I can not get the coupler off of the shaft, I am going to have to wait weeks before George gets me another coupler where I once again have to grind the head off of the bolt.
Scott...
Ok, WAY WORSE THAN I THOUGHT...
I took the endplate off of the machine, and the pin that george installed in the end of the ballscrew fell out! I was told that this pin was oversided, and put in with liquid nitrogen... No idea how this will get fixed...
Scott
Scott,I just don't get it.The motor side or end of a ballscrew usually looks a bit different than yours.Is there a set of A/C bearings?Perhaps I am confused.Yes.What does the opposite end of the ballscrew look like?I have never seen a setup like this before.
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
sagreen
I have not seen such primitive work/design like this in a long time, George you are no machinist, or have a clue about designing, Nobody builds machines to sell with work like this
Thanks for showing this Scott, & I hope other people see this, to know what they are getting into when buying these machines
Mactec54
Ok, I spoke with george, and he's going to take care of the problem. In the mean time I am going to turn a new pin in my lathe (temporary solution) and get back moving...
lgalla,
The pictures are on the ballscrew side of the motor. George drilled the inside of the ballscrew and inserted a dowel pin for the motor shaft. Way easier than milling down the ballscrew. The ballscrew is 25mm in diameter. Apparently the pin was undersided and didnt hold. Make sense?
Scott...
lgalla
He has press/shrink fitted a dowel pin in the end of the ballscrew,which is the drive for the ballscrew, the pin has the drive coupling & bearing on it
This should never be done like this, This is what you would call a temporary fix, for something that has broken down, & you are waiting for new parts to be made
Mactec54
i had got this design off of machines that sell for half a million dollars, i asked them why ,and the reason was when you machine a ballcrew down ,you are machining the hardness away , so once all the hardness is gone the centre of the ballscrew is soft,which will cause vibration and bounce on heavy ballscrews,
with centre bore you still have all the harness and the dowel pins are precision ground and hardened,which would make the ballscrew a lot stronger on the ends, funny there is lots of Japan made machines do the same thing ,as where they got the idea from and has worked for years with no problem for them and 20 feet long and 3000ipm speed
mactec54 i see you try jumping on everything to put my stuff down , just the last post you made about profiles ,say if they know how to take care of there stuff lol meantime the company sales are over 50 million a year around the world
XZero cnc
