587,999 active members*
1,610 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach 1100 VS Haas OM1 OM2 OM2a CM1 or other???
Page 3 of 4 1234
Results 41 to 60 of 67
  1. #41
    Mar 2009
    1863
    Quote Originally Posted by CadRhino View Post
    Congratulations on being able to take it easy.
    So, is that a yes or no on your tormach being capable of doing what your haas/fadal did but just at a slower speed?
    That's a definite yes. I can do anything on my Tormach you can do on a FADAL, Haas or any of those high dollar machines, it's just going to take a little longer.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
  2. #42
    Aug 2013
    980
    Aaahh, I love hearing you say that Steve
    Quote Originally Posted by Steve Seebold View Post
  3. #43
    Dec 2007
    379
    Re: Tormach 1100 VS Haas OM1 OM2 OM2a CM1 or other???
    Wow, thank you for your insight.
    Regarding your tormach, would you say it can pretty much do what the haas can (tolerances/repeatability) but at a much slower rate?
    Glad to hear you are still using your tormach and congratulations on moving up to a 'real' vmc
    I bet you are stoked
    I generally find it easier to make more accurate parts the first time around on my Haas over my Tormach especially with being able to measure tool diameter easily. However, the Tormach is plenty accurate and is repeatable and once parts are dialed in you can make great parts. There are so many variables that can throw off the accuracy such as warping from work holding and parts warping after machining and the most accurate machine is not going to fix that.
  4. #44
    Aug 2013
    980
    Thanks for the comparison and insights. I plan on keeping my tormach but want a has like you have but with a 4th axis and phase converter. It sounds like I need to come up with $100k.
    Quote Originally Posted by LazyMan View Post
  5. #45
    Mar 2011
    480
    I think you can do a lot better than a HAAS for 100k. I would look at the Brother speedio series or Even a robodrill. Chip to chip tool changes time In one second. Lighting rapid speeds etc.
  6. #46
    Mar 2009
    1863
    If you buy a Haas tool room mill or a Mini, they will both run on single phase power. The only thing I didn't like about my TM1 was its 4000 RPM spindle. I had a service guy tell me when I get it paid for he would come out and change some codes to make the spindle 6000 RPM.
  7. #47
    Feb 2006
    7063
    I would bet any of the Haas machines would be a good deal more accurate than any machine in the Tormach class, by virtue of better, closed-loop servo drive systems. For sure the bigger/more expensive machines use dual-loop servo drives, which provide precise position and velocity control, and thermal compensation, compared to the open loop position-only control on virtually all hobby level machines. I don't know if that extends down to the Mini-Mill and other smaller/cheaper machines, but I would not be surprised if it did. They do, at a minimum, provide closed-loop position control. This kind of drive provides not only much higher performance (600-1000 IPM rapids), but will also create parts with far less dimensional variation from part-to-part as ambient temperature varies throughout the year.
    Regards,
    Ray L.
  8. #48
    Aug 2013
    980
    Thanks for your insight, Ray.
    You hav a Novakon, right? Is it the model with servoes?
    Do you consider it a hobby level machine? You use it to make your products right?
    QUOTE=SCzEngrgGroup;2065172]I would bet any of the Haas machines would be a good deal more accurate than any machine in the Tormach class, by virtue of better, closed-loop servo drive systems. For sure the bigger/more expensive machines use dual-loop servo drives, which provide precise position and velocity control, and thermal compensation, compared to the open loop position-only control on virtually all hobby level machines. I don't know if that extends down to the Mini-Mill and other smaller/cheaper machines, but I would not be surprised if it did. They do, at a minimum, provide closed-loop position control. This kind of drive provides not only much higher performance (600-1000 IPM rapids), but will also create parts with far less dimensional variation from part-to-part as ambient temperature varies throughout the year.
    Regards,
    Ray L.[/QUOTE]
  9. #49
    Feb 2006
    7063
    Yes, both of my Novakons have AC servos (though the Torus Pro was a stepper machine when I first bought it), and yes, I consider them "hobby" mavhines, albeit at the high end of "hobby", like the Tormach. But, still, I wouldn't put either up against a commercial VMC, like a Haas. I make ALL of my products on the Novakons, mostly the Torus Pro, due to its huge work envelope (X25" x Y15" x Z16"), but I don't expect to get better than +/-0.001" accuracy across a production run, and design accordingly. With a Haas, you can easily work all day to a few tenths. This is an inherent characteristic of the basic machines - the Haas is MUCH stiffer, has more accurate balls screws, I would assume linear ways on ALL axes, not just Z, and dual-loop servos with glass scales, rather than the single-loop servos and rotary motor encoders on the Novakon. Each one of those contributes significantly to both accuracy and repeatability. And, of course, with higher spindle speed, and more powerful spindles, most of the Haas machines will run circles around our machines in terms of production time with both larger and smaller tools.
    Regards,
    Ray L.
  10. #50
    Aug 2013
    980
    That makes sense.
    thanks for the insight!
    QUOTE=SCzEngrgGroup;2065340]Yes, both of my Novakons have AC servos (though the Torus Pro was a stepper machine when I first bought it), and yes, I consider them "hobby" mavhines, albeit at the high end of "hobby", like the Tormach. But, still, I wouldn't put either up against a commercial VMC, like a Haas. I make ALL of my products on the Novakons, mostly the Torus Pro, due to its huge work envelope (X25" x Y15" x Z16"), but I don't expect to get better than +/-0.001" accuracy across a production run, and design accordingly. With a Haas, you can easily work all day to a few tenths. This is an inherent characteristic of the basic machines - the Haas is MUCH stiffer, has more accurate balls screws, I would assume linear ways on ALL axes, not just Z, and dual-loop servos with glass scales, rather than the single-loop servos and rotary motor encoders on the Novakon. Each one of those contributes significantly to both accuracy and repeatability. And, of course, with higher spindle speed, and more powerful spindles, most of the Haas machines will run circles around our machines in terms of production time with both larger and smaller tools.
    Regards,
    Ray L.[/QUOTE]
  11. #51
    Aug 2013
    980
    Thanks for the recommendation. I am not familiar with those brands. Hass' are so ubiquitous that I just assumed they would be easier to get servicing and parts for. I am open to a different machine if it is easy to find a tech and service.
    Actually, my (future) budget is currently between 60-80k for a NEW machine WITH a 4th axis.
    Any recommendations?
    Quote Originally Posted by AUSTINMACHINING View Post
  12. #52
    Nov 2007
    2151
    I have a question for all the pros in this business that make big piles of shiny accurate parts.
    What do you do for stock prep? No matter what I make it seams like i spend more overall time on my tormach prepping stock for the part or parts to be machined. From my experience, any material size that does not fit into a 5c collet requires some prep and that prep is not easy and or fast from my experience. Fast accurate vmc is fun, slow stock prep takes all that fun back.
    Those Ninja fast z moves are scary to watch on youtube. Looks like the machine would need to be bolted to floor
  13. #53
    Jun 2012
    311
    Speaking of Brother CNC take a look at the M140X1.
    https://www.youtube.com/watch?v=ndVS22ZbqmE
    It's out of your price range(~$150K) but does 5axis indexing and turning at insane speeds.(nuts)
  14. #54
    Aug 2013
    980
    I prep my round stock on a lathe and rectangle stock on cold saws.
    Quote Originally Posted by mountaindew View Post
  15. #55
    Aug 2013
    980
    Wow, that is faster than my Tormach lol
    Quote Originally Posted by IMT View Post
  16. #56
    Jun 2004
    6618
    I've got things that will make holes faster, but they are gunpowder driven.
    Lee
  17. #57
    Aug 2013
    980
    Faster maybe but are you repeatable and within .0001 😱🤓
    Quote Originally Posted by LeeWay View Post
  18. #58
    Jun 2004
    6618
    Probably not, but I don't always require tolerances that tight.
    Lee
  19. #59
    Jun 2012
    311
    Lol! I make holes that way too. Hard to control depth though and position tolerance is +\-1" at best. 😀
  20. #60
    Nov 2007
    2151
    If your having any tolerance problem then this would be the first place to check. I have found NO way to clamp rough stock in any fixture or vise other then 5c stock material and get it square to the mill xyz axis! If the stock is not square in the vise jaws your going miss any thru drilled holes by a mile in anything other then material less then 1/2" thick! Also you get misaligned mill operations from on each side when you flip parts for operations.
    I mentioned this in another thread when a user was not getting the accuracy he expected, then I giggled because 3 post above someone had said the exact same thing almost word for word
Page 3 of 4 1234
  1. Tormach 1100 vs. Haas VF3
    By Steelmesh in forum Tormach Personal CNC Mill
    Last Post: 05-10-2018, 02:50 PM
  2. New Tormach 1100 or aged Haas TM?
    By cloudgeneral in forum Haas Mills
    Last Post: 08-29-2016, 02:45 AM
  3. HAAS OM2A toolchanger Rotation Fault
    By Tungsten808 in forum Haas Mills
    Last Post: 04-26-2016, 11:10 PM
  4. Tormach 1100 S3 using Tormach 1.5" face mill....
    By dneisler in forum Tormach Personal CNC Mill
    Last Post: 05-06-2015, 04:50 AM
  5. Out with Tormach 1100, in with a new Haas VF-2?
    By velocitycnc in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2014, 07:52 PM
