It's been a while since the last update, so here it goes. I have been testing all kinds of stuff to see what the machine (and myself) manage to make. My 'End Mills' from ebay for testing have been 4/6/8mm 2flute ones. And managed to burn the 6mm one 2 weeks ago. All end mills are HSS for price reasons, so I will need some good ones soon.
Now after my tests I discovered multiple problems and fixed most of them. I reinforced the Y-axis in multiple places and it seems to be better, but there is one thing I can't figure out at all. I don't even know where to looks, so I hope someone here has an idea
(I'm still a complete newbie, so it could be obvious to you guys).
The attached pictures show my last 'test' in black MDF. I did cut the same thing twice in one job, next to each other. Pic 3 shows the one that has been completed 'almost OK', pic 1 and 4 show the 'not OK version'. It looks like the first pass is completely off on both pieces and it gets restored from the second pass on. The strange thing is that I haven't seen this on other materials like in pic 2.
Is there someone here who has an idea where to start looking ? Gcode is made with vCarve and the controller is GRBL, I don't think that is a problem. I guess there still is some design/build error, but if I was missing steps I think the problem would get worse (which isn't the case at all) ?
Second guess was to much flew on the Y axis, but in pic 4, the 'bump in the long side' is away from where it should be, so that sound strange also.
I'm also sure my HSS bit at 12000rpm (Kress milling engine) isn't the correct one, but to produce things that look that bad :/ ?
Hope someone can point me in some direction ... I made multiple thing that look perfect, but with these big jobs (far away from the starting point) it going really wrong
