587,833 active members*
3,180 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > New to the Okuma lathe with a U10l control
Page 3 of 3 123
Results 41 to 43 of 43
  1. #41
    Re: New to the Okuma lathe with a U10l control
    Quote Originally Posted by newton11n View Post
    Hey Everyone I'm in need of desperate help here. I'm very new to CNC lathes I have ran mills my whole career. We recently have purchased a used Okuma Crown with the U10L control I have been able to navigate around the machine relatively easy but when it comes to putting in the program i have had a bit of trouble. I used Fusion 360 to make a simple turn two diameters to get used to the machine I used the Okuma Lathe post and it generated the program after getting the program into the actual machine I have had errors most which have been an easy fix but i have one line that keeps sending an alarm.The alarm is( Alarm 2366 Tool Radius Comp. No spec) the code line that this happens on reads (G90 G18 G3 x2.4992 z-1.5264 k-0.0312).Can anyone help me with this also if anyone has a sample program that they would share with me that runs on the U10L control so I can compare it to what I have to see where I am off. Like I said i am very new to the CNC lathe so any help with this is appreciated .
    What did you adjust on that line of code in the end?
    Im having the same issue here!
  2. #42
    Quote Originally Posted by skywalker4 View Post
    N13 T020202
    N14 M8
    N15 G94
    N16 G97 S500 M3 M41
    N17 G0 X2.8 Z0.1969
    N18 G0 Z0.3181
    N19 G1 X1.9496 F39.3701
    N20 G32 X1.9496 Z-1.2431 F0.0787
    N21 X2.065 Z-1.3009 F0.0787
    N22 G0 X2.8
    N23 Z0.3181
    N24 G1 X1.9311 F39.3701
    N25 G32 X1.9311 Z-1.2339 F0.0787
    N26 X2.065 Z-1.3009 F0.0787
    N27 G0 X2.8
    N28 Z0.3181
    N29 G1 X1.9168 F39.3701
    N30 G32 X1.9168 Z-1.2268 F0.0787
    N31 X2.065 Z-1.3009 F0.0787
    N32 G0 X2.8
    N33 Z0.3181
    N34 G1 X1.9049 F39.3701
    N35 G32 X1.9049 Z-1.2208 F0.0787
    N36 X2.065 Z-1.3009 F0.0787
    N37 G0 X2.8
    I have never seen a threading program
    that long. canned cycles are not normally that
    long. I am not sure what that is??
    Appears to be threading multiple sections of a shaft, with gaps between them
  3. #43
    Sep 2010
    1230
    Quote Originally Posted by JoeTall69 View Post
    Hello Joe,
    The code shown is just four threading passes on the one Thread; no multiple thread with gaps between.
    Regards,
    Bill
Page 3 of 3 123
  1. okuma osp u10l
    By TOMO1 in forum Post Processor Files
    Last Post: 08-03-2017, 01:44 PM
  2. okuma OSP-U10L
    By clayd-cnc in forum Okuma
    Last Post: 09-20-2016, 10:51 AM
  3. Post for Okuma Osp-U10L
    By Pupc in forum Post Processors for MC
    Last Post: 04-01-2016, 02:56 PM
  4. Okuma-U10L DNC
    By hense in forum Okuma
    Last Post: 04-25-2009, 07:23 PM
  5. OKUMA OSP-U10L RS232
    By edmondyjh in forum Okuma
    Last Post: 01-28-2009, 08:27 PM
