Trying to stay on topic, I have my 770 in my basement right at the foot of the stairs. I use flood and have never noticed any machine shop smells even when running all day. My girlfriend is not a big fan of my 770, so I'm sure if she had a chance to get a dig in on it she would, be she's never said a thing about the smell.
Noise on the other hand is something she does let me know about, so I usually can only machine when she is gone for the day or before she gets home from work.
The actual meaning of building code floor loading specifications is being seriously mis-interpreted in this thread. The spec is called "uniform floor load". The name includes the word "uniform" because it is defined such that it would be perfectly permissable to put a "uniform" 40 PSF load over the ENTIRE area of the floor (think a room-sized water bed), and the structure would still be structurally sound. Similarly, it is entirely acceptable, actually expected, that there will be frequent situations where the load far exceeds 40 PSF over a smaller area - for example, pianos, large aquariums, and other such loads can be handled with equal safety. This may cause some minor localized deformation of the subfloor itself if nothing is used to distribute the load, but it would present no risk whatsoever of structural failure. So, even putting a 1000 pound milling machine on a residential floor would NOT present any problem whatsoever.
Regards,
Ray L.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
awful lot of non tormach owners butting in with their 2 cents aren't there. cats vs dogs, gimme a break boys.
Makes one wonder that some who continually blog on this forum actually do make any real parts on their Tormach.
Don
My original point was simply that you are putting a heavy vibrating moving machine on a residential floor and that I would reinforce the floor by putting support underneath. It is not a shelf of non-moving books, a dresser, or a piano.
My second point was that putting a machine in a building it would be prudent to have that building up to specs for a light industrial floor rating since that is essentially what you will be subjecting the floor to. The comparison of floor loads was to show that light industrial specs are more than double that of residential. The waterbed argument was brought up by someone else and my calculation was to show that even the localized load of a waterbed is not significant when compared to the localized loading of even a relatively small machine like the Tormach..
The final calculation I did in response to your post was to poke fun at your argument.
The bottom line in my opinion is that if you are planning to put a tormach size machine into a bedroom, it would be prudent to reinforce the floor framing beneath the machine. That is still my opinion.
I don't know about your waterbed, but mine on the second floor gets plenty of vibration on a regular basis, especially back in 1992 during the twin quakes (Landers mag 7.3 and Big Bear mag 6.5) with epicenters less than 20 miles away. No reinforcement was ever needed. That said I do have my Tormach 1100 mounted on a concrete slab on the ground floor since a dogleg of the San Andreas fault is about five miles from here at the bottom of the hill. Unlike my narrow footprint lathe that is leashed with wire cable in case of earthquake, the Tormach has a wide footprint and needs no such leash. BTW I increased the lateral stability of my lathe by adding outriggers. Each of the two outriggers sit on two spherically jointed feet that also makes it easier to remove the twist from the lathe bed. I can see where spherically jointed feet might benefit my Tormach also. See photos below.
Don
What coolant are you using?
Never really thought about the noise. That could be a deal breaker, TV is on the adjoining bedroom wall.
Bedroom floor is concrete, single story, slab on grade. One of the piers is under the corner I'm thinking of for the mill. Zero need to worry about floor joists. Bet that somewhere, someone renting a second floor apartment, hauled a mill up to their place.
The floor situation you have is perfect for the mill, but the noise would be the deal breaker in my house. I mentioned my fathers shop when I was growing up. It was at one end of the basement and was totally insulated. When he was working down there you could still hear the muffled sounds coming from the workshop and that was in the family room at the other end of the house. It wasn't loud or annoying at all at that distance and with the shop walls insulated, but at a closer distance it may be a big problem. Good luck.
If it's a concrete floor (and walls) and you are worried about smells you need to waterproof the concrete. If oil and coolant soak into the concrete it will smell forever. If everything is waterproof then how much it smells will depend on how clean you keep the machine and area around it.
Phil
