Originally Posted by
martinw
Dear Steven,
Thanks again.
OK, so if we start exporting "stuff" from the Earth to a position outside the Solar system, what happens to the Earth's orbit round the Sun?
Best wishes,
Martin
It doesn't have to be outside the solar system. As long as it is from outside the earth. If we bump into a NEO (near Earth Object) like an asteroid then it would likely come from the asteroid belt between mars and jupiter. Possibly the remains of a planet there that took a bump from something really really big. If it is a comet then it likely would come from the Kuiper belt, a group of some 200 planetoids and comets of which pluto is a member. Both of which are part of the solar system. The term "outside of the system" is a thermodynamic term and doesn't always mean just what it sounds like it should.
Conservation of momentum says it the earth gets lighter then it has to move faster to keep the momentum the same. If the earth gets heavier then it moves slower. But since the mass of Earth = 5.9742 × 10^24 kilograms, your talking a lot of stuff to make even the smallest noticible change.
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
