588,211 active members*
4,095 visitors online*
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    Apr 2018
    88
    Re: Optimum MH25V
    Had some trouble with the Z axis screw. The bearing block was not aligned with the Z nut. It was 3mm off and was binding at the top. I elongated a few mm the bearing block screw holes and now the Z can be adjusted easily.
    Otherwise the mill is coming along just fine. Tomorrow I will reattach the electrical cabinet and finish installing the oil lines and then cut the first chips.
    First project will be making a mounting block for an Ikea Jansjo LED lamp.
    Sent from my SM-A520F using Tapatalk
  2. #42
    Apr 2018
    88
    Re: Optimum MH25V
    Some weeks have passed since I started using the machine. In the mean time first parts have been produced and I would like to give some conclusions to this review.
    I made a nice pair of vise clamps out of hot rolled steel. After machining the clamps were sandblasted and cold blued.
    Machining in steel was easy enough. The mill seems to be solid and can easily mill steel. Tried different endmill combinations: 6mm, 8mm, 10mm and 12mm with good results.
    I also tried to mill a piece of aluminum also with good results.
    The central oiling system works like a charm. I still need to install the one way valves on all the circuits. While it works without the valves, the pump must be active longer so oil can reach the Z axis and while doing this is squirts too much oil in the X and Y (messy).
    Conclusion:
    PROS: Solid machine for it's size. Very nice features (belt drive, BT30 spindle with tool quick change, 1.5 kW AC induction motor with VFD, counterweight for the head). No quill, therefore easier to CNC. Holds good tolerances.
    CONS: Some design and execution mishaps which require a bit of TLC. But we are talking china, therefore not totaly unexpected. Here I refer to the oiling concept and the gibs. No quill. Milling and drilling with the head can be done but it is not pleasant. Also the paint is chemically compatible with...almost nothing. benzene softens it instantly, methilated spirits instantly makes it bouble and peel off. Some epoxy or polyurethane paint is due in the future. Benefit of the crappy paint is that it can be stripped off with no effort.
    So, for me I consider it a good buy and I recommend it to anybody who wants to CNC it.
    If one wants to use it as a manual mill, then please get one with a quill.
    Also, for CNC conversion stay away of the more expensive version with power feeds. You will throw the cheap and weak steppers and drivers to the bin. For the price difference one can buy really nice hybrid steppers and drivers.
    A.
Page 3 of 3 123
  1. Optimill MH25V CNC conversion
    By K_Jensen in forum RF-45 Clone Mill
    Last Post: 01-27-2019, 05:18 PM
  2. Any Optimum MH-28 conversions?
    By bmanners in forum Benchtop Machines
    Last Post: 06-29-2016, 02:56 AM
  3. Optimum BF 46
    By Kiwi 007 in forum Benchtop Machines
    Last Post: 09-03-2014, 10:03 AM
  4. OPTIMUM F45
    By MARTY FX in forum Benchtop Machines
    Last Post: 04-24-2012, 12:27 AM
