588,698 active members*
6,420 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Where can I buy Nichrome wire from?
Page 3 of 3 123
Results 41 to 51 of 51
  1. #41
    Sep 2006
    18
    Nickel Wire
    Nichrome wire at http://mscdirect.com all sizes and kinds and 1/3 the proce of other distributors
  2. #42
    Dec 2004
    48
    Hey Gil
    That power supply is the one I use. You know it works well with the inconel.
    I think I got my wire from aerowright.com
    Later Bruce
    www.wtxrcdog.com
    http://wtxrcdog.blogspot.com/
  3. #43
    Sep 2006
    37
    You can buy Chrome Nickel fishing leader wire at Walmart. It's 69# test and 0.018 inch. It comes in a 25 foot length for less than $2. Works like a champ.
    This is the stuff at Walmart.
    http://www.thornebros.com/muskie/ter.../lc_mason.html
  4. #44
    Nov 2004
    321
    I find several types od Nichrome wire.
    Nickel-Chrom - copper coated
    Nickel-Chrom - shining
    Ni 80 - shining
    Nickel-Chrom-Titan
    diameter
    0,2mm resistance on 1 meter 16,8
    0,3mm resistance on 1 meter 10,1
    0,35mm resistance on 1 meter 7,5
    0,4mm resistance on 1 meter 4,6
    0,5mm resistance on 1 meter 3,4
    0,6mm resistance on 1 meter 2,3
    or 0.008 0.012 0.014 0.016 0.020 0.024 inch
    My question is: wich wire to use for foam cutting and what kaind wire diameter to use. Whati is difference between this wires.
  5. #45
    Sep 2006
    37
    I am using .018 inch, but I see a lot people using between .016 and .020 inch. I have a 115V to 25.2V, 2 Amp step down transformer. My AC voltage going into my transformer measures 124.9 and I'm seeing a little over 28 volts at my cutting wire. My power supply uses a 1 Amp fuse and so far it hasn't blown using .018 inch wire.
  6. #46
    Feb 2005
    13
    Quote Originally Posted by 43220 View Post
    My problem is wire I have on hand now breaks too frequently. Anybody recommend something that holds up well without breaking? Reason it breaks is I cut foam manually using guides the wire makes contact with and moves along during the cutting.
    Do you cut using wood templates or similate?? I used to cut wings for Rc planes using wood templates, and the wire used to break due to friction. Then I learned a simple trick: you shoul cover the edge of the template with adhesive aluminium tape, wich is used for isolating air conditing installations. Then the wire will run smoothly
    Regards from Spain
  7. #47
    Mar 2011
    buy directly from Manufacturer in China, minimum order quantity is one spool.
    Here: Http://niwire.com
  8. #48
    Jun 2010
    why not just buy rene 41 wire from skyking? cost is about 60c per foot but you get a much better cut and last longer than s/s or nicrome wire.
    you can buy 50feet for $30 and its only $6 shipping to usa
    sky king rene 41 wire
  9. #49
    Oct 2011
    Nichrome resistance wire
    Quote Originally Posted by ihkim View Post
    I am looking for Nichrome 6 ohm/foot wire.
    I tried find it from HobbyLobby, Home depot, etc..
    Ebay doesn't have 6 ohm/foot.
    Anyone can help me?
    I think this site can help you to find what you are looking for:
    wires.co.uk : Bare Nickel Chrome / Nichrome Section
    they have almost all the kinds of wires, and many more helpful items.
  10. #50
    May 2008
    For anyone that needs "small" quantities, one strand of bicycle brake cable works perfectly for me.
    It measures +/- 20 ohm/meter. The twist does go away after the first use.
  11. #51
    Oct 2012
    Small orders
    Pelican Wire | Custom manufacturer of appliance, bare resistance, floor heating, insulated and thermocouple wire.
    they have 50 foot and 100 ft spools listed on their website. If you need larger quantities then you should call them for a quote 239-597-8555
    They have competitive pricing and their customer service is outstanding
Page 3 of 3 123
