For that size machine NEMA 23 motors of 380 oz and 495 oz will be plenty of power if you use a Gecko drive and the proper PSU voltage. I'm using four G203V drivers, four 495 oz motors, C11G breakout board, and 72vdc PSU on my 60 inch wide by 12 foot long DIY machine. It easily jogs at 1,400 ipm with CNCRP R&P installed.
The G540, 381 oz motors and 48v PSU is a lot lower cost and will outperform many other driver system kits. The resonance reduction feature alone is reason enough to buy Gecko stepper drives.
You won't regret going with R&P for most things. You may have some issues with engraving small text in metal name plates if the tension is not correctly set on the R&P drive assemblies.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
