588,183 active members*
4,137 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Lessons in overkill! Welded steel, fixed gantry router
Page 3 of 3 123
Results 41 to 54 of 54
  1. #41
    Mar 2010
    621
    Re: Lessons in overkill! Welded steel, fixed gantry router
    Looks great... is the dust shoe public or private I'd love to get a copy of it. I'm looking to revamp my dust shoe and would love to take a look at it.
    Keep posting the update pics.
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
  2. #42
    Apr 2009
    290
    Quote Originally Posted by adam_m View Post
    I'll upload the parts to thingiverse today, and post the link here.
  3. #43
    Apr 2009
    290
    Took some time, but here are the files https://www.thingiverse.com/thing:3131943
    "Hey! It's that guy you are!" - Phillip J. Fry
  4. #44
    Mar 2010
    621
    Quote Originally Posted by mcentric View Post
    That's great thanks... any chance you'll be uploading a .step file also?
  5. #45
    Apr 2009
    290
    done
  6. #46
    Mar 2010
    621
    Much appreciated!
    Adam,
  7. #47
    Mar 2010
    621
    I'd been doing some work on a "Air ring" (not sure what to call it) for clearing debris when I cut aluminum and I'm going to try and incorporate it into your design, really love it... I'm still very new to Fusion 360 but liking the results.
    Adam,
  8. #48
    Apr 2009
    290
    Adam,
    Looking good! Let me know how it works out
  9. #49
    Apr 2009
    290
    Speaking of milling aluminum, here is a tiny test piece i did a couple months ago. This is a 1mm 2 flute ball end mill.
    I'm also just using compressed air to clear the chips
    https://youtu.be/98cDHl9Nqjc
  10. #50
    Apr 2009
    290
    Here are some more random clips from the router this last year
    https://youtu.be/U9Ul6rcFS0g
  11. #51
    Dec 2014
    640
    Very cool!
  12. #52
    Nov 2003
    452
    Hi can someone remind me when and why the tubing gets filled with sand? And is foam used sometimes?
  13. #53
    Mar 2014
    735
    I filled my base frame with sand to add mass and help with vibration dampening.
    I filled my gantry tube with 2 part foam trying to dampen resonance. Sand would have worked better but I didn't want the added mass on a moving part. I did some before and after tests and the foam had a positive affect. It also sealed the inside and prevents temperature changes from forming condensation and rusting out my gantry from the inside.
    There was a guy over on the UK forum I think, that built a router out of aluminum extrusions. He filled his extrusions with a silicone casting compound. That's probably a better solution than sand or polyurethane foam.
    Sent from my Pixel XL using Tapatalk
  14. #54
    Apr 2009
    290
    Quote Originally Posted by justCNCit View Post
Page 3 of 3 123
  1. steel/aluminium fixed gantry build
    By v2tiller in forum DIY CNC Router Table Machines
    Last Post: 06-16-2020, 09:42 AM
  2. Fixed Gantry Steel, wadeodesign
    By wado1971 in forum DIY CNC Router Table Machines
    Last Post: 01-06-2018, 02:12 PM
  3. My First All Welded Steel Router Design
    By widgitmaster in forum CNC Wood Router Project Log
    Last Post: 10-18-2008, 03:07 PM
