The 1911A grips look easy enough, but they got complicated fast when I started on my own effort. I have the right side grip files working well, but haven't worked on the left side lately to finish it. It probably won't take long once I can get back to it. Critical thinking about fixturing and front to back alignment makes my mind hurt too much. ![Smile](images/smilies/smile.png)
They look pretty in red oak. I bandsawed 3/4" board to ~3/8" halves, zero the Z axis on the table top. Place the smooth side of the wood against the table top, and there is no need to surface plane the rough side of the board. The grips end up all being the same thickness.
I'm using a 1/8" straight flute Bosch router bit to do the flat side pockets and holes. The holes go down into the fixture board. I insert wood pegs into the screw holes, flip it over on the pegs, then mill the rounded side with a 1/8" tapered ball nose bit. Last operation does the screw head pockets and the profile cut. The little notch in the bottom corner of each side is for a pin that goes through the frame. Putting a dimple at that location would let the grip cover the pin if a notch is not desired. Some of the pins are not flush with the frame.
The left side grip has an angled round notch that covers a round thumb safety operating rod. That angle is fairly critical. I do it with the 1/8" tapered ball nose bit while cutting the flat side of the grip. The final profile finishes out the top end shape.
In my steel channel build log are some photos I posted back in October or November. To be continued when I get interested in it again.
CarveOne
http://www.carveonecncwoodcraft.com
