588,626 active members*
5,625 visitors online*
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    Dec 2010
    For some reason Kmotioncnc does not recognize this line of code: N14G70G91.1
    That line of code is in the original file and the warpdrive file.
    If I remove it I can run the simulation. When I view the warpdrive version the arcs are now straight lines between the two outer straight lines. Not sure what the cause of this is.
    Attached are all the files I tried and the originals.
    Attached Files Attached Files
  2. #42
    It probably doesn't like G91.1, which is incremental IJ mode in Mach3.
  3. #43
    Jan 2008
    853
    Yes, I mention that in the WarpDriver manual, I just comment it out in the source window before warping. By memory removing this line affects the mm/inch interpretations too, so make sure it is back in place for any files that you are sending to the machine and Mach3.
  4. #44
    Jan 2008
    853
    Looks good to me JayCop! Good luck with it.
    Cheers!
Page 3 of 3 123
  1. The Widgitmaster's Travelling CNC Medicine Show
    By BobWarfield in forum DIY CNC Router Table Machines
    Last Post: 04-22-2024, 10:11 AM
  2. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  3. Speed (RPM) and travelling speed.
    By einarkol in forum Material Machining Solutions
    Last Post: 12-27-2008, 07:04 PM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. travelling salesman
    By ghyman in forum Visual Basic
    Last Post: 10-27-2005, 11:16 AM
