588,685 active members*
5,927 visitors online*
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    Nov 2009
    84
    Re: Fixed Gantry Steel, wadeodesign
    Soooooooo whatever happened with some of the issues with this machine?????
    Did you figure them out ? And if you were to build another one would you do it this way?????
    Did you ever change the steppers to ClearPath servos????
    If so, what were the results??????
  2. #42
    Sep 2014
    32
    Quote Originally Posted by hacker7 View Post
    Sorry for the late reply hacker7 - I simply missed the email notification I had a new post. Anyhow.... the router has been running great - It's changed personality from a project to a useful tool. The last thing I did was to replace the steppers with the Clearpath servos which gave me crazy improved performance on the x / y axis - servos are king! I'm set at 250 IPM rapids and have cut up to 180 IPM (HSM) without seeing any issues. I finally solved my intermittent electrical issues by simply ripping out the limit switches (poor mans solution) - I'll have to rewire the entire thing at some point but it's low priority for me as it runs fine with soft limits in mach. Heres a link to the Clearpaths in action https://youtu.be/vloGMD8okDg
    If I was to build another one.... would be very similar. Can't beat the steel construction. I do have a list of potential upgrades in the back of my mind but I have a feeling I won't get to them until I start having problems of some sort (tool changer, upgrade z-axis stepper to servo, add auto zero routine). At the moment I'm actually finishing up a CNC Lathe conversion of my Grizzly G0602 -> http://www.cnczone.com/forums/bencht...6-cnc-cad.html .
    Cheers
    Wadeo
Page 3 of 3 123
  1. Fixed gantry vs moving gantry
    By scott0999 in forum DIY CNC Router Table Machines
    Last Post: 01-31-2014, 06:14 AM
  2. Fixed Gantry - Trying again
    By harryn in forum CNC Wood Router Project Log
    Last Post: 04-08-2013, 02:51 AM
  3. Shonky's lasercut steel fixed gantry routerish milly type CNC thing.
    By Shonky in forum CNC Wood Router Project Log
    Last Post: 03-18-2013, 12:47 AM
  4. fixed gantry
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-29-2009, 11:20 PM
  5. Fixed Gantry
    By Auzze in forum DIY CNC Router Table Machines
    Last Post: 07-25-2004, 08:34 AM
