588,224 active members*
4,692 visitors online*
Thread: Artcam 2008
Page 3 of 5 12345
Results 41 to 60 of 87
  1. #41
    Dec 2008
    445
    Hello.
    Does someone know how i fix the problem at the post #38?
    Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
  2. #42
    Dec 2004
    1137
    Quote Originally Posted by Vegabond View Post
    If you see on the picture below, you see trough the material where the tool has milled. On my artcam it doesn`t show the white color there the tool milled, but the same color as the material.. Why?, i have same, or more cut depth than the tickness of the material...
    Robert.
    Most likely because your material is thicker than the total depth of cut. Check your Material setup and the total depth on your profile toolpath.
  3. #43
    Apr 2006
    3498
    The best way is to deal with the Artcam reseller in your locality.. Also watch the Videos and post the same in artcam forum..I hope you will get speed up your learning curve..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  4. #44
    Dec 2008
    445
    Quote Originally Posted by Jay C View Post
    No, i have tryed that. To cut deeper than the material thikness.
    Robert.
  5. #45
    Dec 2008
    445
    Quote Originally Posted by Khalid View Post
    Hello, i see the videos, and learn things to!
    Robert.
  6. #46
    Dec 2004
    1137
    Ok, what version is your ArtCAM, maybe they are showing a newer version in the videos. I use what I see in the videos to do somethings in Cut2D.
  7. #47
    Dec 2008
    445
    I use Artcam 2008
    Robert.
  8. #48
    Dec 2008
    445
    Can i see how much time i have to run the g-code?
    Robert.
  9. #49
    Feb 2006
    18
    Once you have created your toolpaths, click: Toolpath Operations > Toolpath Summary. It will show the estimated time needed to finish the toolpaths. Hope this helps.
  10. #50
    Dec 2008
    445
    Yeah it helps! Thank you.
    Robert.
  11. #51
    Dec 2004
    1137
    Found more videos: here
  12. #52
    Dec 2008
    445
    Hello, can i program a A-axis in artcam?
    Robert.
  13. #53
    Aug 2009
    136
    does so out there have artcam that can anwser a question for me. i downloaded a file STL from cnc4free when i open it in artcam i can't do nothing with it like move it and i can't see it as a vector to move it. can some one help he please
  14. #54
    Jan 2006
    2985
    Quote Originally Posted by electric2u View Post
    First, correct sentence formation will help others understand what you are asking:
    Does someone out there....
    On to your question, an STL file is NOT a vector, so you will not see it as one, you will not see it in the 2D view at all. You will see it in the 3D view however. When you import the STL, you can rotate it and translate it wherever you want, then when you click "paste" (I think thats what its called) it will actually paste the model into your workspace. Then you can only machine it using 3D toolpaths (machine relief, etc.) I have found artcam to be somewhat limited in its ability to work with 3D models, depending on what you are trying to do, it may or may not be adequate.
    Good Luck
    Matt
  15. #55
    Dec 2008
    445
    Hello, can i set a colour on the "milled" area?
    Also, i see i can do many changes on my material, (wood, brushed silver.....) But can i set a black color, there i have milled vit a v-bit for example? so i get the text more out
    Hope you understand..
    Robert.
  16. #56
    Mar 2009
    90
    Robert.
    Let me see if i understend...hmmmm....you cand use the "colour shade"... i will explain how it's work. you need to put colour in 2d mod on vector's you want and and in 3d mod activate the "colour shade". i'm attaching a photo the button in the read circle
  17. #57
    Dec 2008
    445
    Hello, thanx for answer.
    I mean that i get it dark "shadowed" or painted like the example under.
    Robert.
  18. #58
    Oct 2009
    21
    Hi. I am fairly new to artcam 2008 and i have a recessed feature problem.
    I followed the steps in the tutorial but i am having a hard time in the recessed feature tutorial b/c i can't find the 'Create' button w/c should be nearby.
    Hoping for your kind consideration in detailing my mistake/s.
    Thank You.
  19. #59
    Dec 2004
    1137
    What does w/c mean?
  20. #60
    Oct 2009
    21
    What does w/c mean?
    w/c is short for which sir. and b/c is short for because.
    Might you know where i made a mistake?
    Btw, i'm using artcam 2008.
Page 3 of 5 12345
  1. CncBrain SDK - VB.NET 2008
    By Switcher in forum CNC Machine Related Electronics
    Last Post: 12-11-2011, 06:20 AM
  2. Artcam 2008 -Noen som bruker det?
    By Vegabond in forum Norwegian
    Last Post: 04-01-2010, 07:09 PM
  3. CWX SP2.1 for 2008
    By pixburghenat in forum CamWorks
    Last Post: 05-16-2008, 09:39 PM
  4. ArtCAM Insignia 2008 now available
    By Beckyf in forum News Announcements
    Last Post: 04-02-2008, 03:12 PM
  5. Learning SW 2008
    By SPEEDRE in forum Solidworks
    Last Post: 01-29-2008, 07:30 PM
