Hey Japroach, Have you figured out how to control the spindle using the analog 0-10 Volts or the PWM settings?
I bought the 2200 watt set from Jon at Keling and the motor and the controller works very well in manual mode. Maybe a bit slow to get up to speed, but I can live with that as long as the Dwell times are consistant.
I am working on my Mach 3 setup now and have the analog connected, and I am putting out the 0-10 volts on that input, and I have also added the secondary 5V power and ground to the small board on the CN15 plug. But alas, I cannot get the motor to turn on. I am sure I am missing something though.
Overall, I think this is an excellent product and a much needed replacement for the ailing Grizly motor controls on the SX3 model. Other than the connections, the only other issue I have is the speed.
It starts out correctly at the 400rpm speed, but will not get beyond 4424 rpm, even with the rpm set to 6k. But... It is repeatable and it could be because I am on a 60 cycle power grid rather than 50. When I turn the speed down to 4420, the spindle measures 4375 so I am at my top end at that point.I don't get much more out of the other 1500 rpm of button pushing.
I also noticed that this motor has a pretty warm spindle after a little use. That could be a controller issue though.
Again, I think this is a good product and seems well built. I want to purchase the 1100 watt version since the 2200 watt is way too big for the SX3. The 2200 watt I bought is about to run a lathe. I will get the 1100 for my SX3 when Keling can get more.
Kung Fu Panda - I am looking forward to more of your products.
![Smile](images/smilies/smile.png)
