Hey Marco
Gotta shout out to you man! Without your pics of your spindle work, I may not have figured out how to take mine out ;D
Your vids are so much nicer than mine
Im gonna get a new camera soon, instead of using my iphone HAha.
According to hardinge (multiple techs), they said if you are going to grind the bed, DO NOT GRIND THE SIDES. 99.9% of the wear is the top, so grinding the top and bottom are necessary for a rebuild. If you were to regrind the sides, you would be narrowing the bed, resulting inssues with tamming, and because your narrow the bed, the tapered gib may now be too small...you would then have to make a brand new gib, or add a shim behind it (Bad practice).
When I measured the sides of the bed, I could not detect any wear with my large micrometers that can be set at 0.0001" intervals. I measured this by taking a precision angle block on both sides and then take measurements along the axis.
Ill be cleaning the ballscrews up this weekend and I will have a tutorial on how to clean and remove the nut also. Wasn't hard, but some people are skiddish about taking them apart, hard part is putting them back together
Mike
