587,133 active members*
3,074 visitors online*
IndustryArena Forum > Other Machines > PCB milling > CNC 3020T-DJ Spindle Control, JP-382A JP-1482
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    Aug 2017
    Re: CNC 3020T-DJ Spindle Control, JP-382A JP-1482
    Hey kb0nly,
    I don't know if you're still on here, but I had questions about the PWM-OUT port. Are you suggesting that the pins are as follows?
    1 - PWM Output -> connected to the collector of ENO optocoupler. Anode pin for this optocoupler is cut on some boards (not mine). Connected to the A-axis.
    2 - External voltage -> emitter for DDO?
    3 - GND -> collector for DDO?
    4 - Spindle ON/OFF output -> Q for DDO?
    It seems like with the mod, both the physical switch and the software switch must be on at the same time right? Also, it seems like PWM Output could not be enabled without interfering with the A-axis. In this case, would it be possible to output a PWM signal on pins 2-3 instead? That way, the spindle would have to be turned on using the physical button, but then the speed could be controlled by software and *effectively* turn off by decreasing the speed to 0.
    Thanks!
  2. #42
    Aug 2017
    I found that you can actually use the pin 4 for speed control as well. But the problem is that for speed control, the duty cycle is kept at 50% and the frequency is varied; at the maximum speed, the frequency is 1.475kHz and the speed is proportional to the frequency, but the problem is that with 0rpm, the frequency goes to 1.475kHz again. Other than never using the maximum speed, how could you overcome this? Is there something I'm missing?
  3. #43
    Feb 2018
    8
    Hello
    @ kb0nly
    Excuse me would you be able to have both schemes in larger 1024x960?
    top small to read the diagrams.
    cordially
  4. #44
    Jul 2014
    15
    Quote Originally Posted by kb0nly View Post
    Ok, i got tired of having to flip the Spindle switch all the time and decided it was time to get Mach3 doing its job!
    I have a newer version of the Chinese CNC 3020T-DJ with a black controller box and the controller board is model JP-382A and the spindle board is JP-1482.
    The controller has a PWM output and the spindle board has a PWM input but they are not connected. Here is some pictures i included on another post..
    Attachment 250510 Attachment 250512
    After i got done adding home switches to the controller i also started to trace out the boards to figure out the Spindle control.
    You need two JST-XH connectors to make the interconnect cable, also if you want to add limit/home switches its the same 4 pin JST-XH connector, look on eBay for LiPo balancing cables and connectors as they are used in the LiPo battery packs.
    Note... I don't yet have the PWM speed control working, still finishing up how to set that up, but i DO have Spindle On/Off control now from Mach3! The PWM control just wasn't as big of a concern for me as i generally run it full speed all the time for PCB milling.
    Ok, on the controller board the jack marked PWM i numbered them from the back panel forward, pins 1-4.
    1. LPT Port Pin #17 to Spindle Controller PWM Input
    2. +5v from Spindle Controller to the EL817 labeled DDO, This is Spindle On/Off
    3. Ground from Spindle Controller
    4. Spindle On/Off
    On the Spindle Controller board i labeled the pin numbers Left to Right looking at it from the front panel, pins 1-4.
    1. PWM
    2. +5v
    3. Ground
    4. Spindle On/Off
    The front panel Spindle switch only switches a ground on the Spindle Controller and its in parallel with an Optocoupler, part number EL817, on the Spindle Controller board. So you can leave the front panel switch for manual control and leave it in the OFF position to allow Mach3 to turn it on and off.
    You need to make a cable so that its matching 1-1, 2-2, 3-3, 4-4, using the pinouts as i described them. The plug orientation is flipped, so pin 1 on plug on one end of the cable would be the opposite side of the plug on the other end. You will understand what i mean when you look at the jacks, the controller board has its jack going front to back with the keyway to the left and pin 1 towards the back, but the spindle board has its jack going left to right and keyway to the back and pin one on the left. So the cable is a flipped crossover config.
    Set Mach3 for Active Low on Pin #1 to turn the Spindle On/Off.
    Set Mach3 to control the Spindle PWM using pin #17
    Now, as i said i haven't hooked up and configured the PWM control to pin 17 yet, so all i wired up was three pins between the boards, i didn't install the wire from pin #1 on the controller to pin #1 on the spindle controller, thats the PWM control. You need pins 2-4 for On/Off control as the Spindle controller board feeds +5v back to the controller board via pin #2 to run the Optocoupler labeled DDO, the output of which toggles another EL817 optocoupler on the Spindle board that then enables the spindle motor, the front panel switch is wired in parallel across the Optocoupler on the Spindle controller board which gives manual control and can be left in place.
    Here is some schematics i drew up quickly... Notice that pins i didn't continue to trace out for PWM on the Spindle board or the ENO Opto on the Controller board are marked unknown. Also in the case of the EL817 marked ENO on the Controller board note that Pin 1 of the component was clipped and bent back at the factory, ENO looks to have something to do with the A-Axis as its connected to one of the pins of the four pin header marked A-Axis, i didn't continue tracing that out as it wasn't necessary. Also pin 2 of ENO dead ends at a set of open pads on the back side of the board, i would guess there should be a 330 Ohm resistor there as they kept the same basic design across the boards, using a 4.7k pullup resistor to 5v on pin 1 and a 330 ohm resistor on pin 2 on the others for what i would assume is current limiting through the optocoupler.
    Attachment 250418 Attachment 250420
    Anyway, with a three pin jumper you can make the Spindle On/Off control work with Mach3, or whatever software you use, but i haven't got the PWM config working just yet. I would assume it requires removing the front panel trimpot from the circuit, either just unplugging it or installing a jumper as in the other versions of these boards but i don't have that info yet.
    do you have a photo with the cable in place between the two boards
  5. #45
    May 2019
    4
    Thank you for finding the spindle control.
  6. #46
    Feb 2017
    5
    This is an old thread, but I hope this will be helpful.
    The controller supports a display and switches to change mode. This Hackaday post shows how to connect display and change controller modes.
    I have used this successfully and modified the display board to use it's buttons to change modes.
    After changing mode to PWM the 4 pin connector works for on/off/pwm
    https://hackaday.io/project/6776-304...g-machine-mods
  7. #47
    Oct 2016
    12
    Quote Originally Posted by pache11 View Post
    I was messing with things this weekend and managed to use that post (and a couple others) to successfully get spindle on/off working via software and get my estop so it actually functions on my Chinese 3040 CNC. Good to see you've got PWM working. That hackaday posts mentioned one of the issues is he can't get 100% spindle speed in PWM mode. Instead he achieved only about 63% of full speed. Have you noticed this? I currently use Mach 3 and was wondering if I'll encounter this issue. I'm happy with at least finally having basic on/off spindle control via Mach 3, but PWM speed control would be nice too!
Page 3 of 3 123
  1. Need help with eBay 3020T-DJ
    By morbidmind6 in forum Chinese Machines
    Last Post: 06-20-2016, 05:15 AM
  2. It's Alive! 3020T-DJ
    By kb0nly in forum PCB milling
    Last Post: 09-21-2014, 06:46 AM
  3. 3020t Size and specs
    By tracyaf_2 in forum Chinese Machines
    Last Post: 09-07-2014, 05:33 AM
  4. No Movement Cnc 3020t-dj
    By seriousman in forum Chinese Machines
    Last Post: 09-03-2013, 02:35 PM
