588,169 active members*
4,887 visitors online*
Page 3 of 5 12345
Results 41 to 60 of 100
  1. #41
    Oct 2005
    1145
    Re: UCCNC ETH-400
    Teh UC400eth has 2 standard LPT type1 port configuration. 12 outputs and 5 inputs each.
    Any bidirectional breakout board will work with it as well as the type 1 only lpt BOBs.
    IF you want a single board then most boards for a Smoothstepper will work fine
    Just a thought, (;-)TP
  2. #42
    Jun 2017
    5
    Re: UCCNC ETH-400
    Quote Originally Posted by SCzEngrgGroup View Post
    Why on earth do you think you need a single board that plugs directly into both ports?
    Because I'm tight on space and that would be the most elegant solution. Guess it's not absolutely necessary.
  3. #43
    Jun 2017
    5
    Re: UCCNC ETH-400
    Quote Originally Posted by vmax549 View Post
    As I mentioned, the C25 does *not* work as it appears the 2 LPT ports are hardwired--one is UC400ETH compatible, one not. But yes, I'll check for boards that are bi-directional.
  4. #44
    Apr 2013
    1899
    Re: UCCNC ETH-400
    Quote Originally Posted by TripWire View Post
    Thanks for the quick reply/info!
    But that's kind of crazy, right? What use is the UC400ETH if there are no breakout boards for it? Is it a brand new product or something? Yes, I can cobble together a couple of single parallel port solutions but that's a kludge. I thought the smooth stepper C25 would be the perfect solution but discovered that the 2nd parallel port is not "standard".
    Aren't you making a hen out of a feather? I mean, why is it such a huge problem if you need to use two bobs?
  5. #45
    Re: UCCNC ETH-400
    Actually, the "bi-directional" features of a bi-directional board are what won't work with a UC400ETH.
    Most 2 port boards have the second port as the bi-directional type, to get more inputs.
  6. #46
    Oct 2005
    1145
    Re: UCCNC ETH-400
    MY understanding of Bi Directional is that the signal can pass thru in both directions. As an input or as an output. So it did not matter if you use it on a type 1 or 2 lpt port.
    (;-) TP
  7. #47
    Re: UCCNC ETH-400
    Yes, but the UC400ETH ports are one directional. So a bi directional board on a UC400ETH can only be used as a "standard" breakout board, with pins 2-9 as outputs only.
  8. #48
    Oct 2005
    1145
    Re: UCCNC ETH-400
    OK what does that have to do with the BOB (;-) If it is bidirectional then you set teh 2nd port on teh bob as a type1 and there you have it. You would have a BOB that is setup for 2 type1 ports.
    But not all 2 port BOBs are bidirectional.
    (;-) TP
  9. #49
    Apr 2003
    540
    Re: UCCNC ETH-400
    I have a UC400 and 2 breakout boards..one is pretty standard (C11GS) for driving the motors and charge pump, on board relays etc and another attached to port 2 that's a 12/24v open collector breakout board for proximity sensors, probe etc. Not a thing wrong with using 2 boards. The ability to select 2 different breakout boards is not only usually a little cheaper it allows you to mix and match BoB's to meed your specific hardware requirements. I consider it a positive not a negative.
  10. #50
    Jun 2015
    943
    Re: UCCNC ETH-400
    I agree. Standard printer port pinout which the UC400ETH has is the best solution. I can use 1 or 2 breakout boards. Most bobs come with standard printer port pinout. No need to buy expensive dual port ones or to find one with bidirectional pinout. And I can use 2 different bobs in case I need different functionalities.
  11. #51
    May 2009
    327
    Re: UCCNC ETH-400
    Ray something that mach is driving me nuts with is their Run From Here never seems to work right. I had a problem this weekend where I paused the cut and it cut a straight line though my part when I started it again (it was an arc and it just connected the start and end points). How is this with those things do you know?
    I also have an issue where I can't probe twice without reloading mach or it will probe -x and then just rapid -x after that.
    I hate replacing things that are working but if these problems are fixed I would probably take a shot..
    -Keith
  12. #52
    Re: UCCNC ETH-400
    Well, it sounds like it's obviously not working....
    All these issues in Mach3 are bugs.
    If you find a bug in UCCNC, and can reproduce it, it's generally fixed in a few days.
  13. #53
    May 2009
    327
    Re: UCCNC ETH-400
    There are ways around both issues but it does suck.
  14. #54
    Feb 2006
    7063
    Re: UCCNC ETH-400
    You all should be happy to hear Novakon will be using the UC300ETH-5LPT, with a largely passive custom BOB mounted to it, so it will simply plug into any Novakon machine with no cabling changes. A few added features, like peck tapping on the Pulsar, will require a small amount of additional cabling. Additional uncommitted I/Os will be provided for easy user expansion, and at least 2 of the 5 ports will be completely unused, and available to the user through their connectors on the 5LPT board.
    Regards,
    Ray L.
  15. #55
    Jun 2015
    943
    Re: UCCNC ETH-400
    Regards,
    Ray L.
    Ray, what made you guys to decide to use the UC300ETH-5LPT instead of the UC400ETH?
    The much more I/Os or the analog I/Os or both or something else?
    I'm just curious.
  16. #56
    Feb 2006
    7063
    Re: UCCNC ETH-400
    Quote Originally Posted by OlfCNC View Post
    I'm just curious.
    Biggest factor was probably the analog I/O, since that allows the exact same hardware to be used on all Novakon machines, and the BOB can be little more than a board full of connectors, since the 5LPT is fully buffered. This setup will provide much more I/O, and some additional functions, and eliminate the current Novakon BOB, which more than makes up for the slightly higher cost.
    Regards,
    Ray L.
  17. #57
    Aug 2007
    359
    Re: UCCNC ETH-400
    I'm looking forward to hearing what the price for a retrofit kit comes in at. With all the Fusion 360 users, are there any plans for a post processor or is there already one available?
    Don't have to be too bright to be me
  18. #58
    Jun 2015
    943
    Re: UCCNC ETH-400
    Thank you for the information Ray.
    There is a UCCNC post processor for Fusion 360 : Autodesk CAM | Post Library
    Type in UCCNC and you can download it.
  19. #59
    Aug 2007
    359
    Re: UCCNC ETH-400
    Excellent! Thank you!!
  20. #60
    Oct 2009
    483
    Re: UCCNC ETH-400
    This is great news that Novokon has settled on a new motion controller upgrade package. What kind of pricing are we looking at?
    Perhaps most important is when will the new upgrade package be available? Are we talking 1 week, 1 month, 3 months? Or should I be expecting something under the Christmas tree in December?
    Also, why did you guys go with a custom BOB instead of the UB1?
Page 3 of 5 12345
  1. UCcnc CAM
    By vmax549 in forum UCCNC Control Software
    Last Post: 09-16-2016, 04:19 PM
  2. Uccnc - g20/g21 or g70/71
    By robertspark in forum UCCNC Control Software
    Last Post: 06-19-2016, 01:26 PM
  3. UCCNC Help
    By extsuba in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:51 AM
  4. FED UP with UCCNC
    By jcarpenter2 in forum UCCNC Control Software
    Last Post: 03-10-2016, 11:24 PM
  5. Has anyone really used UCCNC?
    By greggv in forum UCCNC Control Software
    Last Post: 08-16-2015, 10:45 AM
