587,638 active members*
4,434 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > HF 8x14 linear rail conversion....and maybe more...
Page 3 of 5 12345
Results 41 to 60 of 100
  1. #41
    Jan 2016
    120
    Re: HF 8x14 linear rail conversion....and maybe more...
    Off topic - what is your green lathe in the back? It looks like a SB 10 inch or something.
  2. #42
    Aug 2006
    673
    Quote Originally Posted by burbingus View Post
    that is a Rockwell 9"x 36. I have found VERY little information on it, but from what I can tell it's essentially Rockwell's version of a Logan 200. That said I love it. it's a tank for it's size and even has power feed on the cross slide. If it only had a gearbox it would be perfect....
  3. #43
    Jan 2016
    120
    Thanks for the info, it looks stout and in great shape. I'm enjoying this thread!
  4. #44
    Aug 2006
    673
    if you're super interested it's model number 74tlc-2130
    so tonight was full of disappointment...not only did i find out that my post needs lots of work still, but i found out that mach3 does not support having front and rear oriented tools at the same time. So there goes setting up gang tooling...all roads lead to a turret!
  5. #45
    Feb 2012
    26
    Or to Linuxcnc!
  6. #46
    Aug 2006
    673
    nah, if i switch controllers itll likely be kflop/dynamotion so i can actually use my encoders for position feedback.
  7. #47
    Jan 2008
    1543
    LinuxCNC works well with encoder input in many forms.
    Mach3 is hopeless for lathes.
  8. #48
    Aug 2006
    673
    Quote Originally Posted by pippin88 View Post
    are you using that function currently for a position feedback loop? I'm not against switching to linux, but if I do i'd like to set up a dedicated PC to run it which is my real hesitation.
  9. #49
    Feb 2012
    26
    I'm setting mine up with a spindle encoder (100PPR quadrature + index) and two MPG handwheel encoders, But I haven't got it running yet, still working on the cast iron. I'm also looking forward to pippin88's answer
    I followed your lead on this one, have the bed in my mill right now cutting a rail abutment and a few other features.
  10. #50
    Aug 2006
    673
    What's all this now...?
    Possibly the beginnings of a turret?
    and the ratchet mechanism?
    You guessed it!
  11. #51
    Jul 2018
    6489
    Hi CS900- about time you swapped out that belt?? Peter
  12. #52
    Aug 2006
    673
    Hahaha, yeah that belt has been like that for about 4 years. When it finally gives up I do have a spare ready to go, but it's a pita to replace, so for now I'm going to keep it.
  13. #53
    Aug 2006
    673
    Got the shaft done today. It never fails to be very gratifying to single point threads.
    There was about a .0015 interference between the shaft and the ratchet.
    A little heat and it fits right together.
    A little weld for good measure and it's finished.
  14. #54
    Feb 2012
    26
    Looking good! Are you planning to release the turret prints? I'd be willing to pay to avoid doing the design work....
  15. #55
    Aug 2006
    673
    Quote Originally Posted by jdrimm View Post
    i'd happily send you the CAD models free of charge.
  16. #56
    Feb 2012
    26
    Quote Originally Posted by CS900 View Post
    Thanks! I'll PM you my email as soon as I figure out how to pm on here!
  17. #57
    Apr 2014
    345
    I’m interested in the turret files too if you are will to share. Could you post them on the forum? If not I can just pm you my email.
  18. #58
    Feb 2012
    26
    I got the models, this is an impressive design. I'll look at it more closely tomorrow at work, but at least at first glance, I think it will be a perfect fit for my lathe!
  19. #59
    Aug 2006
    673
  20. #60
    Aug 2006
    673
    weekend update...got most of the components machined. still need to make the actual ratchet arms and the cam clamp that secure the tools but other than that it's all fabricated.
    Test fit and everything is looking good so far...
    Still waiting for the stepper motor to show up and i had to re-order the rear bearing. It's a taper bearing and the rollers don't rotate inside the cage. I've never seen a failure like that in a bearing before, i assume it's just defective.
Page 3 of 5 12345
  1. G0704 Linear Rail Conversion
    By BTP in forum Benchtop Machines
    Last Post: 07-14-2019, 01:59 AM
  2. 8x12/8x14 Lathe CNC Conversion
    By snowluck in forum Benchtop Machines
    Last Post: 12-23-2013, 05:00 PM
  3. RF45 z-axis linear rail conversion?
    By AndreasT in forum Benchtop Machines
    Last Post: 12-23-2012, 11:53 PM
  4. Sieg X3/SX3 Linear rail conversion
    By DvG4 in forum Benchtop Machines
    Last Post: 01-16-2011, 02:17 AM
  5. Replies: 1
    Last Post: 06-04-2009, 05:41 AM
