603,308 active members*
3,052 visitors online*
Page 3 of 8 12345
Results 41 to 60 of 160
  1. #41
    Dec 2020
    168
    Re: Working On A New "Timber Frame" Design and Build.
    I completed the epoxy pour yesterday evening. It looks good this morning with no leaks past the dams. Now just waiting for it to continue curing before pulling the dams off maybe tonight or tomorrow..
  2. #42
    Dec 2020
    168
    The Dams have been pulled. I'm real happy with how it turned out. Now just more waiting as it continues to cure.
  3. #43
    Jul 2018
    6823
    Hi Loren - well done. Now you can top the bench and pour the pool table Peter
  4. #44
    Dec 2020
    168
    Pete, thanks! Next is doing the work on the table components while waiting for the epoxy to cure more.
  5. #45
    Dec 2020
    168
    The start of the table torsion box.
  6. #46
    Jan 2008
    1556
    Wait plenty of time before putting pressure on the epoxy
  7. #47
    Dec 2020
    168
    Quote Originally Posted by pippin88 View Post
    Yes it is still very green.
  8. #48
    Dec 2020
    168
    I have been working on getting the table torsion box framing cut and dry fitted.
  9. #49
    Jul 2018
    6823
    Hi Loren - That's a serious torsion box! Don't leave the screw boxes in they will rattle. peter
  10. #50
    Dec 2020
    168
    My frame straightness gage. 2lb fishing line and 5 blocks cut from the same short piece of plywood. Right now both sides have just a bit of inward bow, which I think I can adjust with shimming on the internal blocking. My corner widths are right on the same measuring with my Starrett 16' tape.
  11. #51
    Dec 2020
    168
    All the joist and blocking are installed in the table. Started installing the base to table connection bolts.
  12. #52
    Jul 2018
    6823
    Hi Loren - Like those big washers what are they from? Peter
  13. #53
    Dec 2020
    168
    Hi Pete,
    Here is a link to the washers. I like them because not only are they big in diameter, but also thick. Helps spread the load out on the wood.
    https://www.mcmaster.com/91117A229/
  14. #54
    Dec 2020
    168
    Putting blocking inside the table frame work for lifting eyes, so if and when the machine needs to be moved the table can be hoisted off the base if needed.
  15. #55
    Dec 2020
    168
    Starting work on the aluminum base plates for mounting the linear rails. The aluminum plate will be bolted to the side of the table and then the rails mounted to the aluminum plate. It will give me more surface area for the load going into the rails beyond the rail foot print on the timber frame.
  16. #56
    Dec 2020
    168
    I had been waiting on some large syringes to arrive to do some epoxy shimming of the aluminum side plates. They arrived yesterday late and I was ready and did the first epoxy pour to create a “shim” between the frame and aluminum plate. The frame had just a bit of inward bow on this side. This worked out great filling the tapered gap.
  17. #57
    Dec 2020
    168
    Here is the "epoxy shim on the other side.
  18. #58
    Dec 2020
    168
    First linear rail and rack gear installed. :-)
  19. #59
    Dec 2020
    168
    Finished the table frame with installing the right side linear rail and rack. Then installed the top sheets for the main table and lower rotary table.
  20. #60
    Dec 2020
    168
    I have the material for the gantry pretty well all cut and started laying out the gantry column assemblies. .
Page 3 of 8 12345
  1. Profile Rail Wood Frame Router, 25" x 37" x 6" working area
    By jpvonoy in forum CNC Wood Router Project Log
    Last Post: 03-01-2019, 03:47 AM
  2. First Build-Steel Frame-Cutting Area 2'3"x2'3"
    By Rock380Star in forum CNC Wood Router Project Log
    Last Post: 04-15-2018, 08:10 AM
  3. Replies: 3
    Last Post: 01-21-2017, 11:01 PM
  4. First Router Build, Is The Frame "Beefy Enough"
    By jimbooboo in forum DIY CNC Router Table Machines
    Last Post: 04-06-2008, 06:49 PM
