587,770 active members*
3,092 visitors online*
Page 3 of 3 123
Results 41 to 43 of 43
  1. #41
    Sep 2006
    6463
    Yes, that's probably true....the build has just been completed and the specs are being drafted ready for the product release....go to the build thread and get into the picture.....there are a number of options being considered.
    The two example I posted were of two different mills that I personally think are the ideal design.....we all differ in our likes.
    The Toolcraft model is very interesting, made in India, and has very good potential.....approx $6,000 if I recall correctly.
    Ian.
  2. #42
    Mar 2012
    19
    Having just read this thread, I would like to add something. There were several comments about using a weight to offset the weight of the milling head on the z axis. While this is fine for offsetting the weight, it doubles the mass that you are required to move and also increases friction. All this will mean larger motors needed to attain the same accelerations. On older machine tools that use counterweights (Horizontal Boring Mills, Slotters) the weight usually offset something that either wouldn't be moved during the machining process or would move very slowly.
  3. #43
    Sep 2006
    6463
    Hi, the weight solution has been used for compensation, but unless you are accelerating and decelerating at very high speed it probably won't be a problem.......gas struts seem to be the favourite, whether successful or not I don't know.
    I think if the Z stepper can handle the load on the uplift without missing a beat or overheating, then you have no problem.
    Inertia loads are a problem that counterweights will only increase.
    Ian.
Page 3 of 3 123
  1. New CNC machine build (big pics)
    By ckm in forum Vertical Mill, Lathe Project Log
    Last Post: 04-30-2012, 11:49 PM
  2. My first build log of my belt drive DIY CNC Machine - PICs
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 03-23-2012, 05:10 PM
  3. Pics of my new CNC machine
    By monte55 in forum DIY CNC Router Table Machines
    Last Post: 11-26-2007, 05:21 PM
  4. Bridgeport series 1 MDI machine pics and questions
    By boringmill in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2006, 11:30 AM
  5. Machine building update pics
    By CRFultz in forum DIY CNC Router Table Machines
    Last Post: 10-23-2004, 10:42 PM
