603,855 active members*
3,914 visitors online*
Page 3 of 3 123
Results 41 to 49 of 49
  1. #41
    Aug 2008
    21
    Re: CR Electronic HD Plasma - Winplasma
    [QUOTE=NGZ;2165760]
    Quote Originally Posted by donaldooo View Post
    Hello Donny,
    I found your above message.
    I have the same problem with the same machine CR ELECTRONIC hd 3070. I need the phoenix software created by CR ELECTRONIC as a original one. I would like to reinstall it due to some problem with the existing one in the machine. Please can you tell me if you have this programm
    Thanks in advance
    Ngz
    Hello,
    I can fully support CR Electronic plasma/laser/ox machines.
    Able to provde Cam software winplasma / wincam or cnc software
    Feel free to contact to [email protected]
  2. #42
    Mar 2018
    4
    ¡¡¡NECESITO AYUDA !!!
    hola buenos días, tenía un motor Leadshine como el que aparece en la foto, el proveedor me dice que ya no es posible. compre un motor nuevo y la única diferencia en el cuadro rojo que se destaca. el motor no funciona para mí. Me dicen que es una herramienta eléctrica de los pinos en el cable del motor. ¿Alguien puede ayudarme?
  3. #43
    Nov 2019
    8
    Let me know if you need any parts or replacement machine
    https://supplychain.requis.com/procu..._records/68089
  4. #44
    Nov 2020
    4
    Hello, I have a cr electronic EU 3-15 machine from 2003, I need the operation manual, can you help me to get it?
    cn photo
    https://www.cnczone.com/forums/attac...1&d=1606554060
    thanks
  5. #45
    May 2021
    Hej Lars fandt du en løsning på dit problem ?
    Hilsen Klaus
  6. #46
    Apr 2022
    Hello,
    I'm down with a cr electronic plasma cutting table. The hard disk of the computer in the console is hs. I want to repair with a new hard drive under windows xp or install a new computer under windows 7. Does anyone have the software to do the nesting and order the table.
    Please I don't want to put my cutting table in the trash....
    Thanks in advance.
  7. #47
    Dec 2023
    Unhappy Re: CR Electronic HD Plasma - Winplasma
    Hello everyone.
    I'm new to this forum.
    I signed up for help solving a problem with an old CR Electronic plasma.
    The plasma is mechanically perfect but I have a lot of problems with the nesting software.
    It was sold to me with the Winplasma 5 software for windowsMe on a virtual machine with a dongle key, without an installation CD, which is why I have a lot of difficulty working in this way, when passing the cad files and pm1 files.
    Could any of you help me find a version of Winplasma that can be installed on WindowsXP, Windows7 or higher?
  8. #48
    Aug 2008
    21
    Hello mail to [email protected] for any support on cr electronic plasma machines and software wincam\winplasma
  9. #49
    Mar 2022
    Quote Originally Posted by cweimaraner View Post
    I have obtained a copy of the software, however it is protected by HASP/Dongle. So without the hardware Dongle, I'm SOL.
    I have ordered a PlazPac 3 ssytem from candcnc.com to retrofit the whole machine and run it with MACH3.
    Jim
    Hi Jim,
    I realise this is an extremely old post, but I'm hoping you can give me some info. I maintain and service an old CRE Plasma cutter for one of my clients, and am looking to retrofit something more modern to control it. I don't know what plasma head it actaully has on it, but I'm interested to know how the PlasPac went for retrofit of this machine. Did you replace the original 3Phase servos with steppers?
    What if anything did you have to do to the power control/saftey circuitry?
    Cheers,
    Garrick
Page 3 of 3 123
  1. CR Electronic
    By blahic11 in forum European Club House
    Last Post: 11-20-2011, 12:31 AM
  2. CR Electronic Plasma Cutting Machine
    By Joao_correia in forum Waterjet General Topics
    Last Post: 11-20-2011, 12:22 AM
  3. CR ELECTRONIC PLASMA MACHINE "software"
    By mcsales in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-08-2011, 08:11 PM
  4. CR Electronic HD Plasma - Winplasma converter
    By FabrizioIT in forum Waterjet General Topics
    Last Post: 01-27-2009, 09:56 AM
  5. '06 Electronic setup?
    By bkboggy in forum Joes CNC Model 2006
    Last Post: 01-26-2009, 06:04 PM
