603,352 active members*
3,418 visitors online*
Page 3 of 6 12345
Results 41 to 60 of 113
  1. #41
    Jul 2009
    21
    still working
    Sorry for not giving any updates or anything for so long. I'm still working on this little by little. It's been hard to find time lately as I just bought a house and am trying to finish getting settled in. Hasn't left much time for fun stuff.
  2. #42
    Feb 2010
    18
    Hello Bill,
    What a great DRO project you have done.
    I think I want to give this a try. I found this thread after I have bought a 18F87J50 demo board, this PIC has USB capabilities. Boy does that add complexity!
    I only want a single DRO in my own VB program so I can just buy a $15 Serial to USB adapter and try your much simpler method.
    I just built a hex file from your code using MPLAB IDE v8.01 and I ended up with a byte for byte copy of your hex file, that was cool.
    I think I'll order some 12F675's tonight.
    Would you care to share some VB code that reads the serial port and puts the scales value in a text box?
    Dale
  3. #43
    Aug 2008
    573
    Hi Dale,
    My program is a torturous mess of VB5 object code, so you probably wouldn't want to copy it
    The PIC code responds to 2 byte commands with a VB friendly string (I think it is all documented in the source listings). The receiving app' has to asynchronously workout what it has received then act appropriately (sound hard than it is) . I'll dig out some code for you later.
    Bill
    Bill
  4. #44
    Aug 2008
    573
    Dale,
    This is how it's done in my application ATM (I'll try to simplify it later)
    Data received by the Comm control is passed to a Scale Control object in the form of a string.
    Code:
    Private Sub MSComm_OnComm()
    Dim s As String
    'Dim T As Single
        Select Case MSComm.CommEvent
            Case comEvReceive
                s = MSComm.Input
                SC.DataInput s 'pass data to scale control object
            Case Is = comEvCTS
                'CTS line change
                If MSComm.CTSHolding Then
                    SendIdentify
                Else
                    SC.RemoveAll 'lead unplugged
                End If
        End Select
    End Sub
    The Scale Control object splits up the string, works out what to do with the parts and passes that data onto the appropriate handler.
    Code:
    '* < DataInput Sub Header >
    '* Author.......: {UserName}
    '* Date.........: 03-Aug-2007 12:32
    '* Purpose......: Data from verniers
    '* Assumptions..:
    '* Effects......:
    '* Inputs.......: sting data from scales
    '* Returns......:
    Public Sub DataInput(vData As String)
        Dim strErrmsg  As String
    If Not IsInIDE() Then On Error GoTo DataInputError
    '------------------------------------------------------------------------ Main Code
    'update appropriate vernier class
    Dim VS As clsVernier 'Vernier scale object
    Static RXS As String
    Dim SCid As String
    Dim sData As String
    Dim vMode As Integer
    Dim vType As String
    Dim vUnit As String
        RXS = RXS & vData
        Do While InStr(RXS, ":") 'Len(RXS) >= 9
            sData = Sfmt.SplitAtDelim(RXS, ":")
            Select Case Left(sData, 1)
                Case Is = "C"
                    'connect e.g CX
                    SCid = Mid(sData, 2, 1)
                    'AddScale ScID
                    RaiseEvent ScaleComms("I0")
                Case Is = "D"
                    'disconnected e.g DX
                    RemoveScale SCid
                Case Is = "I"
                    'info string  ID,Mode,Type,Unit e.g. IX,0,Decimal,Inch:
                    SCid = Mid(Sfmt.SplitAtDelim(sData, ","), 2, 1)
                    vMode = Sfmt.SplitAtDelim(sData, ",")
                    vType = Sfmt.SplitAtDelim(sData, ",")
                    vUnit = sData
                    If Not Scales.Exists(SCid) Then AddScale SCid
                    For Each VS In Scales ' find the correct Vernier Scale object
                        If VS.Key = SCid Then
                            VS.Mode = vMode
                            VS.ScaleType = vType
                            VS.Unit = vUnit
                        End If
                    Next
                Case Is = "R"
                    'scale has been zeRoed (can't use Z)
                           VS.ResetAbsolute
                        End If
                    Next
                Case Else
                    'data e.g. X+00.0000
                    SCid = Left(sData, 1) 'uses the the identifier e.g. W, X,Y or Z to choose the scale ID
                    If Scales.Exists(SCid) Then 'check if scale ID is in scales collection
                        Set VS = Scales.Item(SCid)  ' set current vernier scale object
                        VS.Setdata Right(sData, Len(sData) - 1) ' pass data
                    End If
            End Select
        Loop
    '------------------------------------------------------------------------ End of Main Code
    The Vernier Scale object has to work out the data type convert it and save it in a standard form (e.g. inches)
    The PIC can output three type depending the make of digital vernier used:
    1)A 6 digit Hex number where 20480(d) units = one inch
    2)A signed two significant digit + four decimal place string in Inches
    3) A signed three significant digit + two dp string in millimetres.
    Code:
    Public Sub Setdata(sData As String)
        'takes sData string e.g. H000000 (hex 1/20480"), +00.0000 (inches) or -000.00 (mm)
        'and converts it to ABS value
        Dim pos As Long
        Dim NV As Single
        Select Case True
            Case Mid(sData, 5, 1) = "."
                'decimal vernier in metric mode
                NV = Val(Right(sData, 7)) / 25.4
            Case Mid(sData, 4, 1) = "."
                'decimal vernier in inch mode
                NV = Val(Right(sData, 8))  ' convert decimal string
            Case Left$(sData, 1) = "H"
                ' convert hex string
                    pos = 1 - Val("&" & sData & "00") 'shift 24bit to 32bit and invert
                NV = pos / 5242880 '20480* 256
        End Select
      'add to glitch filter
        If mRev Then
            AddToFilter NV * -1
        Else
            AddToFilter NV
        End If
        mController.Refresh Me  'update the controller
    End Sub
    In order to improve the display stability and remove jitter and glitches I added a simple filter to the output.
    Code:
    Private Sub AddToFilter(NV As Single)
        'filter new value add to abs value
        Static FI As Integer 'filter index
        Dim n As Integer
        Dim FT As Integer
        FT = UBound(Filter())
        Dim Tot As Single
        'glitch filter
        'average last few readings
        Filter(FI) = NV
        FI = FI + 1
        If FI >= FT Then FI = 0
        For n = 0 To FT - 1
            Tot = Tot + Filter(n)
        Next
        mvarAbsValueInch = Tot / FT
    End Sub
    The display routine reads the Scale object's AbsValueInch or AbsValueMM (the scale object does the conversion to a single precision variable).
    Bill
  5. #45
    Feb 2010
    18
    Bill
    Thanks, thats great, I'm sure I can make use if this.
    I'm still considering using an 18F13K50 20 pin USB PIC but I did order the 12F675's.
    I'm wading thru the Microchip USB dll, mpusbapi.dll. It might be not too bad and I can still adapt your VB code somewhat to do it.
    I'm thinking of making a round PCB the size of a 2032 battery that is used in my calipers. One SOIP 18F13K50 and very few external components. It will have a vertical mini-USB connector that comes thru a hole in the battery lid. I can sneak the 2 signal wires inside the case to their pcb pads and solder them on thru the existing connector hole. Should be pretty neat, especially if I can use the USB PIC.
    24 inch calipers for $80 and DRO to a PC, very appealing.
    Dale
  6. #46
    Aug 2008
    573
    Be aware that the callipers have the battery +ve grounded (i.e. they sort of run a negative rail).
    I was considering making an opto-isolated version to avoid the problem in future.
    Bill
  7. #47
    Feb 2010
    18
    I don't think mine has a +ve Gnd.
    When I check for continuity, with the battery out, between both battery contact points on the pcb and the metal of the caliper, they are both open.
  8. #48
    Aug 2008
    573
    That sounds like a very different (and better) type of calliper. The 2032 battery is a great improvement. What type of calliper is it? Are you sure that it outputs the same code as the cheaper Chinese ones?
    Bill
  9. #49
    Feb 2010
    18
    Yes they are Chinese output, confirmed with my 100mhz digital USB storage scope, although I have yet to translate the data stream.
    I have both an 18 inch and a 24 inch and I got them on Ebay recently from seller 800watt.
    These are big an heavy calipers, well worth the money, even though they are inexpensive.
    By the way I checked my cheap Habor Freight 4 and 6 inch calipers and they are +ve gnd.
  10. #50
    Aug 2008
    573
    Great. Keep us informed on your progress and let me know if I can help with modifying the PIC code.
    ...from seller 800watt.
    He's got some nice bits there. (It's a pity it's so expensive to ship heavy goods over to the UK)
    Bill
  11. #51
    Feb 2010
    18
    Bill,
    I am stuck because I can't access the dll from vb6, I know that the answer is simple:
    Here is the VB6 code I am testing:
    PHP Code:
    Public Declare Function MPUSBGetDeviceCount Lib "mpusbapi.dll" Alias "_MPUSBGetDeviceCount" (ByVal pVID_PID As String) As Long
    Global count As Long
    Sub OpenMPUSBDevice
    count MPUSBGetDeviceCount("vid_04d8&pid_003f" Null)  ''ERROR here with Error 49 Bad DLL calling convention
    End Sub
    Here is what I believe is the C code from the source files for mpusbapi.dll:
    PHP Code:
    DWORD MPUSBGetDeviceCount(PCHAR pVID_PID)
    DWORD count;        // Number of USB device with matching VID & PID
    count 0;          // Initialization
    for(int i 0MAX_NUM_MPUSB_DEVi++)
            if(
    MPUSBGetDeviceLink(i,pVID_PID,NULL,NULL,NULL) == MPUSB_SUCCESS)
    count++;
    //end for
    return count;
    //end MPUSBGetDeviceCount
    The DLL routine returns a DWORD which I think is VB6 Long and the argument is PCHAR which I think is a Null terminated string so I added the Null in calling it.
    I've tried it many different ways with no luck-- always ' Error 49 Bad DLL calling convention'.
    Have you got any thoughts on this?
    I have attached the Dll if you want to quickly try this.
    Dale
    Attached Files Attached Files
  12. #52
    Jun 2008
    128
    Do a google code search for mpusbapi lang:basic and you will find an example of basic program using this function
    page link it gives is no longer valid but all the code is there.
    http://google.com/codesearch?q=mpusb...%3Abasic&hl=en
    George
  13. #53
    Feb 2010
    18
    Thanks George, never seen that code search before, very useful.
    I have already seen that code, it is coded for VB.net (or whatever Microsoft named VB6 successor). Not compatible with VB6, they shouldn't even have had the right to call it VB in my opinion, code is not very convertible.
    I copied the code it used to declare and call MPUSBGetDeviceCount and it got the same error, I went digging and found the C code in the dll and tried to fix the problem with the Null and Long.
    Dale
  14. #54
    Aug 2008
    573
    If memory serves, the ByVal statement should pass a null terminated string to the dll so you shouldn't need to add the termination.
    A quick google threw up others having the same problem with the microchip dll (suggesting that it doesn't use standard calling conventions - i.e. not VB compatible)
    Might be worth chasing Microchip ???
    Bill
  15. #55
    Feb 2010
    18
    Bill,
    Didn't work without Null either, good to know Byval sends it.
    I already have a Microchip ticket open on this but haven't had a response yet.
    I hope I can use VB6. I never went to VB.net, it was just too different and a money grab. Someday I'll just learn C.
    Dale
  16. #56
    Aug 2008
    573
    Snap !
    I tried VB.net as a beta - it was like starting all over again, NOTHING worked !
    A friend suggest C# but ... I think my programming days are over (or at least the days of learning a new language are) , I don't get anything out of it any more
    Bill
  17. #57
    Feb 2010
    18
    Smile
    Bill,
    Well that was interesting, I can now send and receive data to the 18F87J50 demo board with a simple VB6 program.
    The template like code was generated by EasyHID and it uses mcHID.dll.
    I just set the VendorID, ProductID, BufferInSize, BufferOutSize.
    Then I wrote a little code to toggle the LEDs (on the pic board) every time there is a state change of a switch on the pic board. Read and write accomplished.
    Attached is the VB6 project and the dll if anyone wants to 'look' at it.
    To run it you need PIC18F87J50 FS USB PIM demo board with 'USB Device - HID - Simple Custom Demo - C18 - PIC18F87J50 PIM.hex' loaded
    Now I just have to mesh your 12F675 asm code into the C++ workspace that Microchip uses for the USB pic's. I hope that is not too hard.
    :cheers:
    Cheers
    Dale
  18. #58
    Feb 2010
    18
    Bill,
    Well I now am able to modify the C code, build, load and run a hex file. I spent a lot of time trying to consolidate all the necessary .c and .h files into the project directory but eventually gave up. In all there are about 16 files loaded or included, wow.
    Anyway, I can very easily call an asm function from C or insert asm code inline in C (with a little syntax changing). So I am ready to dive in.
    First, I am not sure how not having a +ve gnd on the caliper changes the input signal components. I don't think it does. Would I just use the LED/3.3k components you used?
    In your code below it says you are setting the reference voltage to 0.75v but I can't figure out how that is. The B'10100011' sets VRR to low range and VR3:VR0 to 0011 or decimal 3. Doesn't that make the ref voltage = (3/24)*5 = 0.625? I'm not tying to be picky, I just want to be sure that I understand assembly/binary/.... because I am so rusty at it.
    Anyway, wish me luck!!
    Dale
    Code:
    ;initialise comparator etc
    VInit	BSF	status,RP0	;select bank 1
    	movlw	B'10100011' 	;set Vref ~ 0.75v, Vdd = 5v;(24/5)* 0.75
    	movwf	VRCON
  19. #59
    Aug 2008
    573
    Hi Dale, your progress is impressive
    I'll check the ref value code tomorrow. However, your scale works at 3v from the 2032 cell, so you'll want to set the comparetor threshold higher any way. Similarly, you may need to use 3v zeners (or perhaps green leds) to limit the voltage out of the pic (if the pic runs at 3v, not 5v, you could dispence with the doiodes altogether)
    Bill
  20. #60
    Feb 2010
    18
    Yep, I wish I had a 3V signal level, then I would just have TTL input levels and use digital I/O ports on the Pic.
    Not to be, even though the battery is 3v, the output signal is only 1.5v.
    One of the main things I need to do is get rid of the battery and get the 10 microamps I need to power the caliper form the USB. I was just going to use a 3V zener to power it with a 100 uF cap on it.
    I will run the Pic on 5v from the USB.
    Now this is a stupid question, why can't I just put the data lines to the comparator thru 10k resistors and forget the diodes?
    Dale
    P.S. I spoke too soon on how easy it was to add asm to C18. When I actually try it I get syntax error at _asm. Supposedly you just put ams between _asm and _endasm, oh well, more grief (3 hours so far on this one). The more I look at the C code the more I might try just doing it.
Page 3 of 6 12345
  1. Is water based
    By cncadmin in forum Safety Zone
    Last Post: 10-19-2022, 05:10 PM
  2. Need help with CNC UK based
    By ciscoe in forum European Club House
    Last Post: 07-21-2008, 12:03 PM
  3. Pic based Oscilloscope
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:48 PM
  4. PC Based Controls
    By zimbricd in forum News Announcements
    Last Post: 12-12-2007, 09:38 PM
  5. dos based cnc software
    By flyingmike in forum Computers / Desktops / Networking
    Last Post: 11-25-2005, 08:29 PM
