588,138 active members*
8,688 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CAD drawings of most popular V8 engine bellhousing patterns
Page 3 of 5 12345
Results 41 to 60 of 87
  1. #41
    Oct 2012
    Hi Guys
    Looking for a 383 Chrysler bolt pattern on bell housing? Cad if possible?
  2. #42
    Apr 2005
    460
    Cool 383 Bellhsn
    Look back a page 440 is the same as 383 and 426 hemi. 518 trans back half should be adapteble to a 727from a 440 Kevin
  3. #43
    Oct 2011
    I'm looking for the IHC V-8 bell-housing dimensions....
  4. #44
    Jun 2013
    Does anyone have the 392 Hemi bellhousing bolt pattern?
  5. #45
    Jan 2014
    For the record the Dodge 3.7,4.7,5.7 have the same block to trans bolt pattern as the LA engines with the exception of the top center hole missing on the newer engines. They also have a small sheet metal spacer inbetween the block and the trans that may need to be accounted for.
  6. #46
    Jan 2014
    Hi
    Does anyone have drawing of the Ford FE bolt pattern, .dwg .stp .pdf or just paper so I can sketch it up
    /Thanks
  7. #47
    Oct 2014
    Re: CAD drawings of most popular V8 engine bellhousing patterns
    Good day people,
    has anyone a bell housing bolt pattern diagram or drawing of the Volvo 4 cylinder Redblock engine and a drawing of the european Ford bell housing of the old V4 / V6 engine, I think it should be similar to the Explorer 4.0 litre engine?
    Thank you,
    Udo
  8. #48
    Jul 2010
    24
    Just to restate I have a collection of different engine drawings, and would like to add to it. So far I have a number of American domestic engines along with a few German designs.
  9. #49
    Oct 2014
    7
    Hi
    I have looked over this thread and do not see the bell housing ford used on there diesel engines. Would anyone have a dimensioned drawing of the early 6.9, 7.3 idi bell housing or the 7.3 powerstroke bell housing drawing. Model years can range from 1986 to 2003
  10. #50
    Oct 2014
    7
    Re: Yanmar L100 drawings
    I have looked through all the ford shop manuals I have and none of them have the bell housing blueprint I need. What type of manual contains the blueprints for the bell pattern?
    I plan to use a 6.9 for a saw mill. I have a pto unit and I hope to make an adapter to join the two.
    any help is much appreciated
  11. #51
    Oct 2014
    7
    bump
  12. #52
    Jul 2010
    24
    I'm looking for GM 2 stroke diesel drawings, any and all of them. mostly the 53 series.
  13. #53
    Apr 2005
    460
    freefuel DDA Bellhousing's are part of the engine IE They seal up the back of the crankcase the back or trans end is SAE 0-4 depending on size and aplacation you can search and find the specs for them Dyna490k IH Combines had a bellhousing with a output shaft you might be able to use I don't know if they ever used a gas MV 404 or 446 that have the same bellhousing as a 6.9/7.3 good luck Kevin
  14. #54
    Jul 2010
    24
    Kevin, what about the rest of the engine? short block and all internals.
  15. #55
    Apr 2005
    460
    I Think DDA two cycle stuff has been bought out by MTU I don't know if they would help on print's what dim. do you need ? I Could help on rod length , crank sizes Deck Hight Ect. Kevin
  16. #56
    Jul 2010
    24
    enough info to scratch machine parts...
  17. #57
    Jul 2010
    24
    where to find drawings of the BMW R series boxer motorcycle engine? I'm trying to avoid the typical "just go measure one" approach as I'm more interested in a rideable completed project and not a pile of useless junk.
    if need be where should this question be moved?
  18. #58
    Mar 2015
    Drawing of the ALH TDI bellhousing pattern, and mounting points and such.
  19. #59
    Jun 2015
    Hi
    Im looking for the bellhousing bolt pattern for the Chrysler 3.5 V6 used in the LHS, Concord or Intrepid around 2000. I actually need the 42LE trans bolt pattern but it should be a mirror image of the engine. If anyone has this info could you please post or email it to me or point me to where I could get the info, it would be greatly appreciated. I would like to make an adapter to a SBF and have the bolt pattern for the SBF.
    wm
  20. #60
    Jul 2010
    24
    Re: I have some Mopar drawings
    when contacting me please include your email address, that should help prevent delays as some of you had to wait till I logged back in to get a reply.
    Quote Originally Posted by freefuel View Post
    I have both the small and big block Chrysler bellhousing drawings, plus the slant 6.
    I also have a really fuzzy photo of an AMC V8 blueprint, but it is readable!
    I also have some nice drawings of 4 and 5 cylinder Volkswagen TDI Diesels.
    PM me your email address and I'll send them to anyone who wants them, I'm not interested it setting up a photo hosting account.
    Lastly I'm searching for a BOP Buick/Olds/Pontiac/Cadillac bellhousing bolt pattern drawing.
    P.S. I have a spread sheet listing a pattern for the Mercedes OM617 5 cylinder Diesel
Page 3 of 5 12345
  1. Popular presents.......
    By MarkusD in forum Portfolio Board
    Last Post: 02-13-2014, 01:29 PM
  2. What will I make Is the popular question...
    By milhead in forum CNC Wood Router Project Log
    Last Post: 02-08-2012, 12:40 AM
  3. Big Block Chev Bellhousing Dimensions
    By hellcycledoctor in forum Australia, New Zealand Club House
    Last Post: 03-30-2010, 11:27 PM
  4. drawing board drawings to cad drawings
    By mike hide in forum Uncategorised CAM Discussion
    Last Post: 03-23-2009, 10:35 AM
  5. single cylinder engine drawings?
    By savvypower in forum MetalWork Discussion
    Last Post: 02-01-2007, 12:44 PM
