Originally Posted by
handlewanker
LOL....thanks John.....my first learing curve would be to decide when to switch the machine on and what will happens when it fires up.
At the moment I'm in the waiting lane waiting for a mill sourced from China.....long story, but in the meantime I'm starting to chafe at the bit and have taken the plunge to design a 3025 CNC moving table router initially to get into the CNC race, but mainly to get acquainted with the mysterious world of computer generated movements as opposed to inserting all the axes movements manually.
It's going to be a long haul building from scratch, but that's how I want to do it.
I see you mention 2D......I would think that as soon as you start drilling operations and cutting to depths etc, then 3 D will need to be addressed as the next step.
BTW, it has been mentioned that the SBR linear rails are not all that good for CNC purposes, cheap yes, but not when compared to HIWIN types.
As I will be tossing up to decide whether or not to use HIWIN 15mm slides or 12mm SBR round rail types under the table, it would be interesting once the "shine" has gone off your 6040 to see how the SBR slides (you have) handle wear, and if they exhibit any deterioration due to the balls in the bearing block bearing directly with point contact onto the round rail surface.
At the same time, have you detected any backlash in the single ball nuts, as this is a worry I want to eliminate from the outset, not later
I've designed an infinitely adjustable double ball nut using two single ball nuts, but in a different configuration to a dedicated double ball nut as sold for the purpose purely for backlash elimination.
Ian.
