587,997 active members*
1,792 visitors online*
Thread: Hoss's G0704
Page 319 of 344 219269309317318319320321329
Results 6,361 to 6,380 of 6871
  1. #6361
    Re: Hoss's G0704
    Quote Originally Posted by jbar View Post
    Am surprised you need a double female parallel cable to connect computer to breakout board. Those are a little difficult to find these days.
    The necessary cables needed are available at places we buy our mill electronics like Cnc4pc.com or Automation Tech.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #6362
    Re: Hoss's G0704
    Quote Originally Posted by Balazar View Post
    Hoss, what is your opinion of using limit switches for homing? I'm defiantly going to install some for use as limit switches. I was looking at these and these on fleabay.
    Those appear decent quality, hard to tell how large they would be to mount on the 0704.
    I use one switch per axis to act as home and limit.
    Projects
    Hoss
  3. #6363
    1943
    Re: Hoss's G0704
    If using a C10 breakout board then you need a male to male parallel cable.
  4. #6364
    Dec 2007
    2134
    Re: Hoss's G0704
    I have a number of those same switches, and they are really good quality I've found. Much better than the cheaper Chinese copy ones. They are quite bulky though.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  5. #6365
    Jun 2013
    19
    Re: Hoss's G0704
    I've got a question for those who have done the CNC conversion. I bought Hoss's plans last week and have fabricated the standoffs and the motor mounting plates. For the Y axis spacer block, I don't have a boring head, but noticed that the tolerances for mounting the bearings is very tight. Do I have to have a boring head to do this? My funds are just about exhausted and I have everything else I need to get my X and Y axes CNC'd, so I would like to find an alternative that uses what I have. Unfortunately, I don't have a 4 jaw chuck for my lathe, just the 3 jaw. Any thoughts from the more experienced folk? Thanks!
  6. #6366
    Re: Hoss's G0704
    Quote Originally Posted by Ripthorn View Post
    Do you have a piece of round stock that you could bore out on the lathe with your 3-jaw then machine the flat sides on the mill?
    Hoss
  7. #6367
    Aug 2008
    1186
    Re: Hoss's G0704
    You could make a boring head relatively easy, do you have a boring bar for your Lathe? You could also chuck up a piece of aluminum and face it down in the Lathe and fasten the piece to the aluminum after finding the drill hole center. Just don't try turning it super high RPM.. Lol. Might be a problem. The other thing you could do is bore the hole in a piece of round stock and then machine the part out of the round stock with the hole already bored in it. Lots of creative ways to do it especially if you have a Lathe, just need to have the determination to make it happen.. I always say it is pretty amazing what can be accomplished with a mill and a Lathe even if they are only manually operated.
    Sent from my XT1080 using Tapatalk
  8. #6368
    Jun 2013
    19
    Re: Hoss's G0704
    I don't have a piece of round stock that has that large of a diameter. By my rough calculations, that would need to be about 3" diameter, would it not? However, I did realize that I have a very small Sherline rotary table. I might be able to zero that up, mount the piece in it, and mill with an end mill. I don't know if the rotary table is big enough, however. I suppose I could make a crude boring head just for this one job (after it's CNC'd, i can just do canned cycles). I'm thinking a drill rod shaft with a shoulder turned on it. The cross member would mount via a screw. The cross member would have a hold drilled with a set screw for holding the boring bar, and a slot where it connects to the shaft with a fine pitch screw for fine adjustment of hole size. I'll have to test it in some scrap to see if it would work.
    I guess I really just need to play around a little bit...We'll see what I can do.
  9. #6369
    Re: Hoss's G0704
    As long as you can hold down in 2 places a rotary table would work too.
    Could always make a larger tooling plate to mount on your rotary to support larger pieces.
    Hoss
  10. #6370
    Jun 2013
    19
    Re: Hoss's G0704
    Just as an update in case anyone cares. I was able to get the spacer machined using my tiny rotary table. Everything just fit. The first side I miscalculated and got it a couple though larger than tolerance. The second side was bang on.
  11. #6371
    Aug 2008
    1186
    Re: Hoss's G0704
    Nice!! Way to be creative and get the job done!!! Looks like it will work well for you.. !!
  12. #6372
    Re: Hoss's G0704
    Nice work, figured the rotary would do the trick.
    Hoss
  13. #6373
    Nov 2015
    24
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    Turn switch 4 to off, it sets it to half current mode when the motor is idle, it won't get as hot.
    Hoss
    Can you guys share where you have all the dip switches set?
    Also what output voltage from the power supply?
    Also, I'm copying a post that says there are two methods to hookup the C10 breakout board to the KL-5056d drivers. Which are you using?
    OK.... I found this wiring diagram on CNC4PC's site which is completely different then what i posted above from Keling's site... which is right and which should i be using? extremely confused now.....
    http://cnc4pc.com/Tech_Docs/1_C10R10.PDF
    it appears that on CNC4PC's diagram, they have the following listed for their wiring:
    from 5056 driver:
    DIR- to external 5v power Supply GRD
    DIR+ to C10 Board Pin 3
    PUL- to external 5v power Supply GRD
    PUL+ to C10 Board Pin 2
    Keling's diagram states:
    from 5056D driver:
    DIR- to C10 Board Pin 3
    DIR+ to comm between pin 2 and 3 on C10 board
    PUL- to C10 Board Pin 2
    PUL+ to comm between pin 2 and 3 on C10 board
  14. #6374
    Re: Hoss's G0704
    Read #6 here it will help a bit.
    FAQs
    Hoss
  15. #6375
    Nov 2015
    24
    Re: Hoss's G0704
    [QUOTE=hoss2006;1817122]Read #6 here it will help a bit.
    FAQs
    Hoss[/QUOT
    Do you have your power supply voltage cranked down below 48v or are you running 48v?
    Are your pins 2 & 3 connected to the dir - and pul - or the dir + and pul + ?? I'm guessing negative since you have the COM set to 5V...?
  16. #6376
    Re: Hoss's G0704
    For the digital driver I had it turned down to 45V.
    Either way will work depending on what you set the COM to
    COM = 5v, Dir & Pul -
    COM = GND, Dir & Pul +.
    Kelings pdf uses a 5v COM.
    http://www.kelinginc.net/KL-5056WithC10.pdf
    Hoss
  17. #6377
    Nov 2015
    24
    Re: Hoss's G0704
    Hoss
    I used the Keiling method of hooking up to the Dir - and Pul - and setting the 5volt/ground switch on my C10 board to 5 volts. Works. Still need to set individual motor speed in the Mach 3 software - any tips on that would be appreciated. Next Im going to work on the motor mounts per your plans. Thanks for the help.
  18. #6378
    Re: Hoss's G0704
    keling has a pdf on that too.
    http://www.kelinginc.net/Mach3setup.pdf
    you'll use 8128 in motor tuning though since these are metric ballscrews with a pitch of 5.08.
    Hoss
  19. #6379
    Nov 2015
    24
    Re: Hoss's G0704
    Hoss
    Reference the pdf above, Engine Configuration Ports & Pins table: Question, what are column 4 (Dir Low Active) and column 5 (Step Low active) for? I see they are checked with green checks.
    I see you reference 'ballscrews with a picth of 5.08' That must be withPhase 2 or Phase 3. I was going to start with Phase 1 and then use the CNC's mill to make parts for Phase 3. But, if I don't mind spending the extry money now, ......should I consider jumping straight to Phase 3 and skipping phase 1 & phase 2 ??? I read your webpage - G0704 DVDROM and it seems like it might be possible. Couldn't I mill my Phase 3 parts before I take the mill apart?
  20. #6380
    Re: Hoss's G0704
    You might want to spend some time and read thru the manual, it will explain everything you might have questions about.
    Product Manuals - Newfangled Solutions
    The video tutorials are also a great help.
    ArtSoft USA - Video Tutorials
    If you plan to go to ballscrews eventually and have the money now it makes sense to go ahead in that direction.
    Making the phase 3 parts are easier as with most parts if it's already cnced but they can be made manually.
    You can email me if you need more detailed info. [email protected]
    Hoss
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
