588,270 active members*
11,071 visitors online*
Thread: Hoss's G0704
Page 320 of 344 220270310318319320321322330
Results 6,381 to 6,400 of 6871
  1. #6381
    Jan 2011
    91
    Re: Hoss's G0704
    Hoss do you offer the conversion kit in .stl format? I seen a guy on ebay selling the .stl files for the mounts and thought since I have a 3D printer I could print them out and use the printed ones to make aluminium ones.
  2. #6382
    Re: Hoss's G0704
    Yes I included stl's to make 3D printed stepper mounts.
    Hoss
    https://www.youtube.com/watch?v=bj0CQ2qJgyY
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  3. #6383
    Jan 2011
    91
    I looked in the zip files and didn't see them?
  4. #6384
    Re: Hoss's G0704
    Quote Originally Posted by modelaratrod View Post
    email me at [email protected], we'll get you fixed up.
    Hoss
  5. #6385
    Apr 2005
    1268
    Re: Hoss's G0704
    Hoss;
    Do you have a decent scale model of the torus pro. I know you printed a bunch of mills earlier in this thread but I'm getting old and don't have the time to search this most humble thread of yours. Six thousand entries may take awhile so I thought I'd go to the horses mouth!
    Thanks and glad to see everything is still ticking along.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  6. #6386
    Re: Hoss's G0704
    Quote Originally Posted by bill south View Post
    Hoss;
    Bill
    I did the torus pro scale model.
    https://www.youtube.com/watch?v=SZ0WU5R982Q
    I got the model from Hirudins thread in the novakon forum.
    Don't know if he still has it available.
    Hoss
  7. #6387
    Aug 2008
    1186
    Re: Hoss's G0704
    I love that video... Great compare and contrast between all of the machines!! What size is your printer. It looks like it can handle some pretty big print jobs!
    Sent from my XT1080 using Tapatalk
  8. #6388
    Re: Hoss's G0704
    Quote Originally Posted by lcvette View Post
    Yes I made a custom modified 14x14x14 printer that I made all the 1/4 scale models with.
    Hossmachine OB14 3D Printer by Hossmachine - Thingiverse
    Hoss
  9. #6389
    Aug 2008
    1186
    Re: Hoss's G0704
    Quick question for you while I am waiting for my thingiverse registration email.. What is the limiting factor in work cube size on a 3D printer build? Is it just frame build size or is there something else that becomes a constraint. All pretty new to me but have wants to build one of these for a while now for prototyping before machining.
  10. #6390
    Re: Hoss's G0704
    You can go bigger by butting multiple heatbeds together, I'm using a single 12x12 covered with a 14x14 pane of glass.
    I've seen some monster printers out there, mostly commercial ones but the problems with going bigger are warping of the part if it's too long, it can lift off the plate at the ends where it's cooler than the center.
    Another reason to keep it reasonably sized is the time it takes to make the part.
    Programs can easily run into hundreds of thousands of lines of code and take many hours to print.
    Once you work out all the kinks, and there will be a learning curve, you can leave it go by itself but it's still a good idea to check in on it.
    I have a remote cam I can watch it with because glitches will still happen, clogged nozzle, program error, part lifts off the table (especially ABS), a small electrical fire (once) and so on.
    What you end up with is a ruined part and have to start over again.
    Really sucks to have that after 10 hours of printing.
    I keep parts smaller if I can, slicing a part in half with software (Netfabb) or designing them that way and gluing them together later, Weldon 16 is great stuff for PLA and ABS.
    Hoss
  11. #6391
    Aug 2008
    1186
    Re: Hoss's G0704
    Very cool.. Glad I asked, its great to hear the potential pitfalls of larger parts. Length is definitely what I was after.. I guess going taller isn't necessarily a better option instead of long flat ways. I imagine that would keep the heat generated in a smaller X and Y area to avoid warping and part lift, but maybe add a slew of new issues from balancing a tall skinny part.. Clearly I have Iots to learn about this subject.
    Gluing sounds like it may be the smart move.
  12. #6392
    Jun 2013
    19
    Re: Hoss's G0704
    Quick question regarding the shaft couplings. I broke the acetal disc in my X axis coupler because the threaded portion unthreaded from lead screw. I tightened the set screws as best I could, but it still worked loose. Do I need to file a flat on the lead screw threaded end, use loctite, or both? I just ordered more discs, but now I can't use my machine until I get them. Kinds of a let down since I felt so good about getting it up and going last night. This was the first part, and broke about 25 minutes in (pretty basic part, just a pocket and outer profile). I was about 3 minutes from being done, but the backlash kept getting worse and worse, which I didn't chalk up to the coupler coming loose until I heard the "pop". I hit that e-stop real quick!
  13. #6393
    Re: Hoss's G0704
    Quote Originally Posted by Ripthorn View Post
    Yes I've always recommended both flats and loctite threadlocker.
    Hoss
  14. #6394
    Aug 2008
    1186
    Re: Hoss's G0704
    Are you referring to the jamb nuts on the screw or the set screws in the Oldham coupler?
  15. #6395
    Jun 2013
    19
    Re: Hoss's G0704
    Awesome, I must have just missed the info. Before the new discs get here, I will put some flats on. I have both blue and red loctite, which would be best for the oldham set screws?
  16. #6396
    Re: Hoss's G0704
    Blue works fine but I also keep purple for really small screws.
    Hoss
    Attached Thumbnails Attached Thumbnails 100_1678 06loctite x axis ballnut mount160.JPG
  17. #6397
    Jun 2013
    19
    Re: Hoss's G0704
    Beautiful, thanks so much!
  18. #6398
    Feb 2010
    114
    Re: Hoss's G0704
    Hey Hoss,
    Do you recall home many quarts of Blue Water Mega Gloss paint you used on your chip tray/enclosure?
  19. #6399
    Re: Hoss's G0704
    1 quart is enough for 3 coats, that's all I used.
    Hoss
  20. #6400
    Jan 2016
    6
    Re: Hoss's G0704
    Hoss,
    Im about to make a ballnut removal tool , after searching this thread i cant find exactly what material i'm supposed to use or a good supplier to purchase it . I'm getting close to putting this 704 into action with some double ball nuts and I don't want to screw things up at this stage of the game . Your plans were spot on , thank you for your work in creating them . I would have looked like three monkeys %^&*(#ing a football without them.
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
