588,484 active members*
5,175 visitors online*
Thread: Hoss's G0704
Page 327 of 344 227277317325326327328329337
Results 6,521 to 6,540 of 6871
  1. #6521
    Re: Hoss's G0704
    just put some tramming tools up.
    Garage Sale
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #6522
    Aug 2010
    630
    What are you using on your machine for power drawbar now?
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  3. #6523
    Re: Hoss's G0704
    The PDB3.
    Projects3
    Hoss
  4. #6524
    Re: Hoss's G0704
    Found my original G0704 control box if interested. It's the original before they ran into problems with them. Worked perfect for me.
    Garage Sale
    Hoss
  5. #6525
    Re: Hoss's G0704
    Found my old beltdrive pulleys to get rid of, both v-belt and 2 speed XL.
    Garage Sale
    Hoss
    update, timing pulleys are gone. both sets gone.
    Attached Thumbnails Attached Thumbnails 0723161543b_cropped_640x406.jpg   0723161544a_cropped_640x435.jpg
  6. #6526
    Re: Hoss's G0704
    Linear Rails or big treadmill motor anyone?
    NSK Japan SH200520AND1 Linear Rails 3 Pairs | eBay
    3 8 HP Treadmill Motor | eBay
    Hoss
    Attached Thumbnails Attached Thumbnails 0725161443a_cropped_640x218.jpg   0725161444_640x384.jpg   0725161445c_640x384.jpg   0725161433e_cropped_640x277.jpg
  7. #6527
    Re: Hoss's G0704
    Anyone looking to make a hydraulic power drawbar this would be the ticket, I never got to the project. Half the price of others.
    SAMSOMATIC TA6007.4X1 PNEUMATIC HYDRAULIC TRANSDUCER
    Hoss
  8. #6528
    Sep 2011
    84
    Re: Hoss's G0704
    Guys - How tight is everyone tightening the jam nuts? I have a problem with the Z axis where if i tighten the jam nuts too much, i get serious wobble (like .250) on the screw. Also on the instructions it shows hoss add AC, top endcap, .025 shim, AC, jam and another jam nut, but on the video it shows AC, .025 shim, endcap, .025 shim, a (washer?) and then two jam nuts. Which is correct?
    Making chips, day by day
  9. #6529
    Re: Hoss's G0704
    Use both shims.
    Hoss
  10. #6530
    Sep 2011
    84
    Re: Hoss's G0704
    Thanks hoss... Also, how tight should the jam nuts be? should the first one be very tight and the other finger tight or what?
  11. #6531
    Re: Hoss's G0704
    tighten the first so it spins freely with no slop and jam the second with the first careful not to overtighten the first, usually takes a few times to get it right.
    Hoss
  12. #6532
    Sep 2011
    84
    Re: Hoss's G0704
    Got it. Thanks again hoss!Should there be any side to side play from the endcap to the screw? I found that to eliminate that play, I had to tighten the jam nuts to a point that the ballscrew didn't want to move
    Sent from my Nexus 5 using Tapatalk
  13. #6533
    Re: Hoss's G0704
    likely from the ac bearing which is a tiny bit smaller in diameter than the pocket, a thin strip of shim around it will solve that.
    Hoss
  14. #6534
    Re: Hoss's G0704
    bgriggs your inbox is full.
    The air cylinder is 3.950 inches in diameter which would be the widest part so if you have 2 inches clearance from the center of the drawbar to the motor it should fit.
    Hoss
  15. #6535
    Aug 2003
    329
    Re: Hoss's G0704
    Sadly I only have about 1 1/2" clearance towards the column. The sides are clear but not the back.
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
  16. #6536
    Nov 2009
    4415
    Re: Hoss's G0704
    Quote Originally Posted by bgriggs View Post
    Time for a head spacer.
    A lazy man does it twice.
  17. #6537
    Sep 2011
    84
    Re: Hoss's G0704
    Has anybody come across an interesting pocket on their saddle? Is it a defect or intentional modification for the cnc conversion?
  18. #6538
    Aug 2003
    329
    Re: Hoss's G0704
    Attachment 329436
    Head spacers. Check.
    Bill
  19. #6539
    Aug 2003
    329
    Re: Hoss's G0704
    Hoss, can you give me a rough idea of the length and depth of your new chip tray. I am going to make one this weekend.
    Bill
  20. #6540
    Re: Hoss's G0704
    Bill
    Here you go.
    HossClick image for larger version.
Name:	mill enclosure chip pan.jpg
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
