588,227 active members*
4,327 visitors online*
Thread: Hoss's G0704
Page 341 of 344 241291331339340341342343
Results 6,801 to 6,820 of 6871
  1. #6801
    Re: Hoss's G0704
    Most likely, mine came out pretty easily but have seen where others have had to press them out, particularly the upper bearing.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #6802
    Dec 2009
    1416
    Re: Hoss's G0704
    Quote Originally Posted by Stigoe View Post
    Anyone had trouble getting the spindle bearings off? I have a Weiss WMD25LV and no matter what I try, I can't manage to separate the spindle from the spindle carrier. I've put the retainer cap back on and even if I hit it with a sledgehammer, it won't budge. It's limited how much force I'm able to hit it with since I'm also protecting it with a piece of wood and I'm holding the wood at the same time as I try to hit it... In addition, my spindle and bearing carrier has a hole, like for a wedge, so is there any chance that the spindle could be two parts screwed together?
    Attachment 363052
    I had a PM25 and yes, that bottom bearing set was a bear to remove for me. I damaged the bearing getting it out and had to replace it with new. Worked out well though as my spindle ran cooler with the new bearing. Had to do the whole freeze the shaft/heat the bearing to get it back on too. Mucho fun-o. I stuck with tapered rollers on the lower spindle and they have been great.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  3. #6803
    Dec 2012
    390
    Re: Hoss's G0704
    I put the spindle back together with the old bearings and I'll just have to see how they behave with higher speeds. If they overheat, I'll just have to see if I can find a workshop with a press.
    I couldn't find any speed rating on my bearings. They're LYC 32005.
  4. #6804
    Dec 2009
    1416
    Re: Hoss's G0704
    Yeah do that. I think if I had just eased the pre-load a bit and just run good grease, I could have run the stock bearings for a LONG time. I took some care when setting up the new bearings to keep the pre-load as light as possible while still being solid and I had no heating issues after break in. Even running 5300 RPM for hours will not result in much more than a slightly warm head. Before 3000RPM would make it sizzle and the spindle was too hot to hold onto for very long.
  5. #6805
    Feb 2010
    114
    Re: Hoss's G0704
    A couple hundred message in, I know Hoss show's how to change the ball nut using cardboard tube.
    Here's another option if you have a 3D Printer.
    https://youtu.be/e8wQgoEML68
  6. #6806
    Mar 2013
    42
    Re: Hoss's G0704
    Can someone point me toward how to speed up the Z axis? I finally got back around to rewiring it to bipolar parallel and adjusted the top motor mount so it doesn't stick during movement. It is a bit slow for my tastes though and certain the one in the videos goes faster.
    It is the nema 34 906oz with the appropriate driver.
  7. #6807
    Nov 2009
    4415
    Re: Hoss's G0704
    Quote Originally Posted by atalon View Post
    Are you using Mach3? If so look under motor tuning.
    A lazy man does it twice.
  8. #6808
    Mar 2013
    42
    Re: Hoss's G0704
    Quote Originally Posted by Fastest1 View Post
    Ah thanks, I must have turned it down while having trouble with it. Been a year or more since I messed with it last. Then I just need need to setup the backlash compensation and I should have a good start.
  9. #6809
    Mar 2013
    42
    Re: Hoss's G0704
    still getting stopping and buzzing when going up on the Z axis even at 40 ipm. What are you guys using for steps, ipm, and accel?
    Well I should say I am still in phase 1 with the stock screws.
    Also I just remembered I should be able to run the "set steps per unit" a few times to get that set better.
  10. #6810
    Nov 2009
    4415
    Re: Hoss's G0704
    Turn your accel down by half and work your way up.
  11. #6811
    Re: Hoss's G0704
    With stock screws you aren't going to get very fast rapids 50ipm was all I got with a 2:1 belt drive. Gotta love those low friction ballscrews. ;-)
    Set accel quite low to give it more ramp up time to speed, make sure you're giving the dovetails plenty of oil.
    Hoss
  12. #6812
    Mar 2013
    42
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    Hoss
    AH, thanks for the reply. I just need to get it running good enough to get the Z axis screw upgraded then. Already have the ball screws and bearings.
  13. #6813
    Re: Hoss's G0704
    Getting some use out of the old g0704 motor, using it to make a small wind turbine to charge a 12v battery when I move out to the Alaskan bush lol. Blades are cut from a 4" pvc pipe.
    Hoss
  14. #6814
    Jul 2012
    159
    Re: Hoss's G0704
    I am converting my Z axis to linear guide rails. I am leaving the X and Y axis as dovetail.
    However my question is about the stepper motor and driver.
    From the begining I have been using a KL23H2100-50-4B and I was using the KL 6050 driver with a 57vdc power supply I made.
    My best rapids before the Y extension and treadmill motor upgrage was 200 IPM
    When I did the Y extension, and the ATC/Powerdraw bar it went down to 100 IPM
    Since I was doing the linear rail upgrade for the Z axis I also upgraded the driver to the 8060D, and a 80vdc switching powersupply I purchased.
    Yet I am still only getting 120 IPM rapid for the Z axis.
    Why so slow? you were getting 260 to 290 with the 48vdc power supply and the 6050 driver.
    Any ideas?
  15. #6815
    Re: Hoss's G0704
    Could be your pc, I tried upgrading mine once and the rapids went to crap, put the old pc back on and the rapids went back to fast. You might think about using a smoothstepper if you aren't now.
    Hoss
  16. #6816
    Jul 2012
    159
    Re: Hoss's G0704
    My pc is an older one, I am running Vista. If I lay the Z axis flat, I can rapid about 200 IPM, but standing up I am at 120 IPM. Any faster than 150 IPM I have hardly any torque, when raising the head I can reach out and put my hand on top of the head and stop it with light to moderate force. At 120 IPM even with heavy force I can not stop the head from raising. I was thinking of using some balance weights to offset the head weight, but then I loose that weight for cutting into material.
    I was hoping with the increase in volts and current I would get better performance in Z but none is noticeable. I was thinking about getting a NEMA 34 970 oz stepper but with bigger shafts I will have to remake not only the mount but new couplings and bearings.
    David
  17. #6817
    Jul 2012
    8
    Re: Hoss's G0704
    Hoss, I am using your "heavy duty digital package" so for the z axis I am using the KL-8070D Digital Stepper Driver and the KL34H295-43-8A NEMA 34 STEPPER MOTOR 906 oz-in. In the KL-8070D manual there is a discussion of 8 wire motors (i.e. the KL34H295-43-8A) having the option of hooking the motor up on either series or parallel configuration. It states that the series connection would be used in applications where a higher torque at lower speeds is needed and the parallel configuration n would offer a higher torque at higher speeds. I am thinking that I really want higher torque at lower speeds.
    I also seem to remember that you tested a configuration using one og the nema34 motors in one of your videos but now I can’t find the video.
    Which hookup would you recommend?
  18. #6818
    Jun 2011
    692
    Re: Hoss's G0704
    What voltage power supply do you have?
    The biggest reason for wiring an 8-wire motor in series is if your driver doesn't have the current to drive it in parallel. That driver can run up to 7A, and the motor only needs 6.1A in parallel, so sticking with parallel is probably your best bet. Also the torque charts on the automationtechnologies website show the motor being stronger across the range in parallel when run from 48v.
  19. #6819
    Jul 2012
    8
    Re: Hoss's G0704
    Quote Originally Posted by skrubol View Post
    I am going to run this machine with the KL-600-48 48V/12.5A Power Supply running at 48v. I did not look at the torque curves. I agree they make it fairly obvious that parallel is the way to go. Thanks for your suggestion skrubol.
    steve
  20. #6820
    Jul 2012
    159
    Re: Hoss's G0704
    Has anyone had problems with corrosion in the limit switch wires? I have tried several different coolants but after a few months of running I start getting false triggers from the limit switches. The switches themselves are sealed units, but when I check the wire connection at the switches there is corrosion, and cut the wire back and find one to two inches of corrosion inside the shielding and the wires are crap. I tried different automotive sealers and marine sealants also different coolants. Cool Mist seems to take the longest to cause enough corrosion to be a problem.
    What is everyone else using to seal your soldered wires at the limit switches?
    David M.
    San Jose CA
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
