Hi all.....it's getting very exciting now.....for all those asking the whats and whys etc......if you'd ordered a machine a month go it would almost be on the water by now.....LOL.
Sky is right, the shipping cost is according to the package, but it's at the other end you have to allow for mostly, that is the Customs Brokerage fees to get it to your destination.
It does pay dividends to work out the package, as in the options and any peripherals you'll need, well before hand and try to include them in the one buy package to be included with the order to cut down on individual shipping costs.
If Sky has any contacts in the Customs Brokerage area in OZ that would be handy if a good deal could be made.
BTW, one question I wanted to ask, regarding the need for a Z axis zero device, or that little round box thingy that lights up when you touch the tool end on it to get your zero height.
Does this mean you need to zero all your cutters tools for their Z height etc to the zero device and store the info in the Mach3 file database somewhere?
What if the tools are all mounted in their own tool holders and placed in a holder on a steel table and each one individually zeroed to a fixed height with a dial indicator and a reference point?
I've seen this done many years ago before my CNC interest time and wondered why it was needed.
Is this the old way to do it or just another way?
I think it would be simple to make a block of steel with a taper to match your tool shank mounted on a steel plate and have a gauge block to set all your tools to the same height with a dial indicator.
Why or when would you need the touch and see the light block costing around $300?
I have designed a setting block with a plunger to activate a dial indicator that would set the tool to zero while in the spindle, but now don't think I would need it.
Surely if the tool was preset to zero off the mill there would be no need to jog the Z axis to get the tool point to touch the zero device?
I can imagine that with the SVM-0 with the basic spindle having an ER32 chuck on the end, the need to touch and get zero from a setting block would be necessary as you cannot have preset tooling in that set-up, but with removable tool holders this is not the case.....each one goes back in the same position.
If my reasoning is correct I need to make an ISO20 tool shank holder on a steel base with an indicator and gauge block etc.....this is much simpler than a zero setting block device.
On the other hand, would this zero setting block device only be necessary for when you have a high speed spindle with engraving cutters that are held in the ER 16 spindle and have to be zero set in situ?
I think I can see a need for both devices now.
Ian.
