Check out SignTorch, he has a bunch of them on his disk!
Metal Art Gallery - SignTorch.com
Larry :cheers::cheers:
i'm in the middle of making a small table for outside. I have got the table cut already cut but i can't seem to come up with any good legs for it... Does anyone have any ideas ? I'm using a laser to cut the parts so it has to be 2d. small bending is not a problem either...
madness,
Would these work for you? They are from a table the company I work for used to make. (modified to remove the decorative features that make it "ours") As you can see, the two pieces slide together in the middle slots. It makes it pretty sturdy. A quick weld bead along the joint makes it even sturdier.
As they are now, they are for an 18" high table with an approx 20" diameter top.
A tip: Cut some decorative shapes about 2-3" in diameter and weld them on to the bottom of the legs as feet. Makes it even sturdier. Butterfly shapped feet look pretty cool. Depending on the "look" you're going for, of course! If it's for your "man-cave", butterflys may not be appropriate! :nono:
I guess you could just stretch the end of the legs a couple inches and then bend them to 90 deg to make feet, as well.
I hope this will work for you. Or, at least give you a starting point! If you use the idea, I would appreciate to see the finished project!![]()
- Schmidty
thanks for helping... although i must of forgot to add that it's a square table and not round.. !!!
They should work regardless of the shape of the top...? Just modify the tops of the legs so that they fit corner-to-corner. I don't know if I exlpained that very clearly! Do you get what I'm trying to say? haha
- Schmidty
I'm building a rectangluar table.. it's 17"x36.5 " & i want it to be 36" tall.. i have taken the .dxf that was posted on here and altared it for what i need, however it throws the whole project out.. i want legs on each side of the table... maybe I'm over thinking this..... Attached is the drawing of the table top
I see what you are saying. You would have to do a lot of stretching and modifying to make my first legs work.
OK...two more ideas. :idea:
1. Use two of the "A" legs I attached before. Weld one on either end of the table (you'd still need to stretch them to get your 36" height. And probably "beef" them up a little, too.) Then cut a support brace with slots on either end to tie the two ends together. Know what I mean?
2. I attached a drawing of some corner legs. (They are super-simple, so you'd probably want to dress them up a little.) Bend them to 90deg down the middle and weld one under each corner.
Would either of these work, or are you still thinking of something a little different?
- Schmidty
From the page CNC Lurker links to:
DeskEngrave is a basic True Type Font to Vector Converter that allows saving of G-Code or DXF files. It will convert a single line of text into the required toolpaths for engraving. It can create toolpaths aligned along an arc or straight line. It includes a TTF 'Stick Style' font - Stick40. It is being released to the CNC community free of charge. We hope you enjoy using DeskEngrave.
I missed Lurker's post the first time, but thanks for posting this program! It will come in VERY handy for me!
- Schmidty
If anybody's into airspace models, here are a couple of free models to cut from 2mm foam. These are SVG and G-Code files.
Electronics Blog: CNC Files
I actually have more, will post other ones as time allows.
Cheers!
rocket dxf:
http://zeed-diyproject.blogspot.com/
I am looking for a 3d model of an open book,anybody?
Hello everybody,
I have seen a picture of a children rocking chair with a teddy bear-styled back rest in the www. Does anybody know where this design/ file is available from? Would be glad about any help!!
Thanks in advance,
Rainer
Hi Rainer,
Here's a child size puzzle rocker but it has rabbits. You could always substitute the rabbits for teddy bears I would think. Here's the link.
Skip
For some reason the DXF conversion of my rocket SVG files that zeed posted did not render well in QCAD, so I'm attaching the DXF files I used for G-Code conversion. Please note that I designed it in Inkscape and the DXF files were converted to AutoCAD 12 DXF by Inkscape, so I never actually touched the DXFs except for conversion to G-Code. Still, when I loaded the DXFs into QCAD (don't have AutoCAD to check there), they looked fine.
Also note that if you're blowing it up, you're probably going to have to rework slots for joining parts together. like I said before, this was a laser cut project for 2mm craft foam and so the slots are approx 1.45-1.55mm to compress the foam just enough to make it hold the parts together. There is no glue used, just tight fitting of parts together. Depending on your material, the fit may have to be different. Also, the model only comes together because of foam's flexibility. If you cut the parts from rigid material, you'll have to find well-located spots to break parts apart.
Good luck with your project, I'd be delighted it you post or email me a picture of what came out.
Cheers!
Hi Skip,
thanks a lot for this beautiful chair. Not exactly what I was looking for but also a great file. Wanted to make some of this teddy bear rockers for my nieces and nephews. But this rabbit rocker is very cool, too
Nevertheless, would be fantastic if anybody could help me with the teddy bear rocker!!
Rainer
