588,411 active members*
5,383 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 cnc finished for now maybe
Page 38 of 53 28363738394048
Results 741 to 760 of 1045
  1. #741
    Mar 2009
    1114
    Where did you learn to write VB code? I'm going to be needing it soon and I have no clue where to start.
  2. #742
    Feb 2007
    4553
    Hoss,
    Thank you for the codes and screens, very good work!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #743
    Didn't have any clue how to write VB code, Greolt and Erniebro did that,
    I just did some editing, added some lines, combined some codes, inserted some math, added some inputs and outputs to make it do what I wanted.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  4. #744
    Mar 2009
    1114
    who are these people you speak of? Members?
  5. #745
    Yep, greolt made an auto z toolsetter and erniebro expanded on it.
    Then I expanded a bit more to get to this point.
    Hoss
  6. #746
    Sep 2006
    1738
    Very nice table!
    -Jason
  7. #747
    I added all the new codes for probing with tool diameters to my Probing Screenset.
    You can download the zip below or the self extracting exe from here.
    This video gives the installation instructions.
    Hoss
    [ame="http://www.youtube.com/watch?v=N4bFeF1ij94"]YouTube - Hoss Probing Tool Diameter Screenset Installation[/ame]
    Attached Files Attached Files
  8. #748
    Did manage to get to do something tonight, added a home switch to the trunnion table.
    Consistently homes to within .001 each time.
    Have a week off from work coming up in a couple weeks so I hope to get using it for something then.
    Have fun, Hoss
    [ame="http://www.youtube.com/watch?v=uCsh-sJzxu8"]YouTube - Trunnion Table Homing[/ame]
  9. #749
    I had a request on my forum for a metric version of the latest probe codes
    so I thought I'd share them here as well.
    The screenset will come soon.
    thanks, Hoss
  10. #750
    Here's the Metric Screenset with all the codes installed.
    Hoss
    Attached Thumbnails Attached Thumbnails auto tool probing metric_1000x718.jpg
  11. #751
    Jul 2003
    281
    Hey Guys, Here's a Free DXF Viewer.
    http://www.cad2gcode.com/freeprogram
  12. #752
    Gotta love freebies, thanks.
    Hoss
  13. #753
    Made a little flood coolant update.
    21 months since I started running flood and it couldn't be better.
    Still have 3/4 gal left of Syn-Kool, I've had to add water a few times due to evaporation.
    You can get it at Enco and MscDirect.
    Good stuff, it prevents rust and has NO odor even from the tank that hadn't been opened since the beginning.
    Whisper quiet, the chips collect in the pan for vacuuming later and all I'm left with is a wet part.
    Hoss
    [ame="http://www.youtube.com/watch?v=TpFEmvz0oEw"]YouTube - Flood Coolant Update 21 Months Later[/ame]
  14. #754
    Jan 2007
    525
    Hoss - do you do a wipe down of your mill every night?
    Tormach PCNC 1100, SprutCAM, Alibre CAD
  15. #755
    No need, the coolant is rust preventative and doesn't leave behind
    any sticky residue to speak of.
    I run a very thin mixture, up to 30 parts water.
    Hoss
  16. #756
    oops
  17. #757
    After making some notes for the R8 ATC and tapping with ATC, I had a little time to play around tonight
    so I started setting up the tools for the trunnion table.
    I'm using work offsets for the different sides, makes it real simple.
    I set the origin on the face with G54 then rotated the table for the left side
    and set the origin using G55.
    I'll carry on for the right using G56.
    Here's a little teaser video I shot making sure it was working right.
    No 4th axis CAM, just DeskCNC for hole locations and editing in notepad.
    Hoss
    [ame="http://www.youtube.com/watch?v=1y5ysyOfzWM"]YouTube - Trunnion Table Tease with Work Offsets[/ame]
  18. #758
    Mar 2009
    1114
    Very nice. I'd love to build a trunion but I doubt I'd ever use it.
  19. #759
    Using it this way as basically a part flipper is pretty simple to program
    getting into 3D and such is going to require some good CAM help.
    MeshCAM looks promising but I don't know that I need it yet.
    I'll probably put that stuff off till after I take care of a couple other projects.
    Hoss
  20. #760
    I was working on setting up the trunnion on the back side and realized I couldn't see behind the table to set a tool AND reach the jog keys.
    It's time to make a pendant!
    Gathered parts I had laying about over the weekend to build a little something,
    the only thing I had to order was a little $11 enclosure from Pac Tec.
    Even got a free sample case from them.
    Made a couple Brains for Mach 3 to work with it, along with keygrabber.
    Not going crazy, just need some basic functions but it'll be expandable.
    Seems like there's never an end to the things that I just HAVE to have.
    Later, Hoss
  1. Almost finished
    By steeltoes in forum T-Slot CNC building
    Last Post: 03-10-2014, 03:11 PM
  2. It's finished
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 01-14-2012, 02:09 PM
  3. Almost Finished
    By Kencor1 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 05:41 AM
  4. Finished at last (well almost!)
    By Ali Kat in forum DIY CNC Router Table Machines
    Last Post: 05-27-2009, 06:19 PM
  5. X2 cnc finished for now
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-12-2007, 11:55 PM
