Just look back a few posts and there it is. --- http://www.cnczone.com/forums/1025144-post7878.html
Larry
Larry
Hello! Does somebody have some 3D puzzles ( car, plane, horse...) dfx files?
Grettigns!
Check out this thread:
http://www.cnczone.com/forums/diy-cn...odels_dxf.html
There's lots of files and links in there, along with some amazing photos of peoples work to inspire you. :-)
Hello gentlemen,
I want to share with you a dxf image RoboCop.
If I like someone to help.
Yours
Tomino
For you Mopar lovers. Here is a Superbee logo I traced and cut on our Waterjet. Turned out pretty well.
Can anyone help convert this to a decent DXF? I have to cut it for a friend on our Waterjet. I have been trying to use Inkscape but my results so far have been dismal.
I know the size and rez is kinda low but its the best I have.
Hi DC-1,
Thanks for the Super Bee logo. I owned a 1969 Super Bee with a 383 4 speed. It would anything except a gas station. Ha Ha
John
2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
heres a dxf. and a svg. you will need to do more editing.
Excellent!!.....way better then my attempts. Thanks a lot!!
I spent almost all day messing around with Inkscape but I haven't been able to figure out how to get a resonable conversion from rastor to vector image. When I use the "trace bitmap"option the brightness cut off option doesn't do anything so I tried every other option.
Sorry to hijack this thread. I will have to post another file to make up for it : )
I take the image to photoshop first to clean it up, and then inkscape has an easier time tracing.
Bar Sign I did for a buddy
Can someone convert me this file to dxf?
Tanks in advance...
is this what you need?
how can we convert to jpg to dxf ?
Hello gentlemen,
I ask you to transfer the image to dxf format.
Thank you very for your help
Yours
Tomino
voila![]()
http://zeed-diyproject.blogspot.com/
Hello
i'll give you some instructions to be able to transfer a bmp image to vector image
1- convert the image to black&white
2- adjust the bright and contrast of the image to make parts of the image clear and sharp as you want it to be
3- use one of the soft wares available (coreldraw ,any like soft ware) to convert is by using trace bitmap function
and this is one site have some programs you can use
Photo to Cartoon
