588,232 active members*
4,344 visitors online*
Page 4 of 8 23456
Results 61 to 80 of 142
  1. #61
    Oct 2009
    867
    Re: A Desktop CNC by David A
    Best to tram the machine now before all support equipment is installed.
    Due to spindle weight upfront, carriage will want to lean forward.
    Use the tram tool to pull back and adjust fore and aft.
    Use the large cross brace to adjust left to right.
    Needed just very minute adjustments.
    Attachment 505710
    Attachment 505712
  2. #62
    Oct 2009
    867
    Install rear bracket on the carriage for the drag chain.
  3. #63
    Oct 2009
    867
    Drag chain installed.
  4. #64
    Oct 2009
    867
    Install ball screw support onto gantry beam.
    Attachment 505788
  5. #65
    Oct 2009
    867
    Place rotating ball nut set onto X carriage.
    Attachment 505830
  6. #66
    Oct 2009
    867
    Set installed.
  7. #67
    Oct 2009
    867
    Install front brace.
  8. #68
    Oct 2009
    867
    And the back brace.
  9. #69
    Oct 2009
    867
    Right side bracket and ball screw clamp.
  10. #70
    Oct 2009
    867
    And the left side ball screw support.
  11. #71
    Jun 2022
    60
    Heck of a job...And your game plan with the drawings are second to none...paul
  12. #72
    Oct 2009
    867
    Thanks Paul, I really appreciate your support.
    The design with rotating ball nut drives has evolved over 5 years with several prototypes.
    Stay tuned, a lot more to come......
  13. #73
    Oct 2009
    867
    With all carriages and rotating ball nut drives installed, the mechanical portion of the machine is finished.
    Finishing up a few remaining details.
  14. #74
    Oct 2009
    867
    Y/A sensor installed.
    Attachment 505866
  15. #75
    Oct 2009
    867
    X sensor installed.
    Attachment 505872
  16. #76
    Oct 2009
    867
    And the Z sensor installed.
  17. #77
    Oct 2009
    867
    Install front drag chain shelf bracket for the Y/A axis.
    Attachment 505914
    Push in aluminum angles into slots of bracket.
  18. #78
    Oct 2009
    867
    Repeat on the other end.
  19. #79
    Oct 2009
    867
    Install bolt.
    Attachment 505920
  20. #80
    Oct 2009
    867
    Snap on mounting plate onto bolt.
    Make sure it can rotate freely on the bolt.
    Attachment 505922
Page 4 of 8 23456
  1. David A's Benchtop CNC Version 2
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 09-09-2021, 02:08 PM
  2. Replies: 0
    Last Post: 06-06-2018, 01:50 PM
  3. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum For Sale Only
    Last Post: 09-18-2015, 09:05 PM
  4. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum News Announcements
    Last Post: 04-28-2015, 11:23 AM
  5. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
