Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/magnus/linuxcnc/configs/CNCdtu'
Machine configuration file is 'CNCdtu.ini'
INIFILE=/home/magnus/linuxcnc/configs/CNCdtu/CNCdtu.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1913
Killing task milltask, PID=1995
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
custom_postgui.hal:17: Pin 'pyvcp.spindle-speed' does not exist
1913
PID TTY STAT TIME COMMAND
1995
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 636.358639] I-pipe: Domain RTAI registered.
[ 636.358645] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 636.358648] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 636.358681] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 636.358684] PIPELINE layers:
[ 636.358686] fc77ce20 9ac15d93 RTAI 200
[ 636.358689] c085cb20 0 Linux 100
[ 636.377475] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 636.377672] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 636.377678] RTAI[sched]: hard timer type/freq = APIC/16612721(Hz); default timing: periodic; linear timed lists.
[ 636.377681] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2126235000 hz.
[ 636.377684] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 636.377759] RTAI[usi]: enabled.
[ 636.424066] RTAI[math]: loaded.
[ 636.483604] config string '0x378 out '
[ 640.750905] RTAI[math]: unloaded.
[ 640.771047] SCHED releases registered named ALIEN RTGLBH
[ 640.800273] RTAI[malloc]: unloaded.
[ 640.900273] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 640.903001] I-pipe: Domain RTAI unregistered.
[ 640.903039] RTAI[hal]: unmounted.
